Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 08-13-2020, 10:30 PM   #76
Juan Ma
Member#: 247861
2004 FXT
Gold
Installed a Ball Bearing Arashi 20g. Today during tuning the turbo was overboosting to over 25 plus punds. Not sure why because according to specs, the turbo has a 1.1bar actuator on it, which equates to 15 psi. Is it possible an incorrect spring was used?
Juan Ma is offline   Reply With Quote
Old 09-10-2020, 01:21 AM   #77
splitoris
Member#: 433063
How’s everyone’s holding up?
splitoris is offline   Reply With Quote
Old 09-10-2020, 09:53 AM   #78
kingsalami
Member Sales Rating: (9)
Member#: 206257
2009 WRX 5-door
OP here. Still lovin’ it @ 146K miles.
kingsalami is offline   Reply With Quote
Old 09-12-2020, 01:12 PM   #79
Jchustla
Member Sales Rating: (10)
Member#: 116284
2006 STi
RBP
Been running mines now for 3+ years 30K+ miles with no issues.
Running EWG and meth injection at 24 psi making 415 whp and 380 wtq Dynojet (I have seen 440whp and 390 wtq on road dyno on a much cooler night).
Turbo is about capped out there in terms of efficiency.
Jchustla is offline   Reply With Quote
Old 09-13-2020, 03:46 AM   #80
splitoris
Member#: 433063
Tuner says to go with td05 20g as td06sl2 is laggy for 350whp
But what about the ball bearing td06sl2?
Old 09-14-2020, 05:51 PM   #81
Jedi03
Member#: 491095
2009 STi Blue
i have the journal bearing with 11 blade exhaust and its about as responsive as the stock vf48...when it goes i am going to do the same turbo ball bearing and would expect it to spool a little better!
Jedi03 is offline   Reply With Quote
Old 10-01-2020, 11:30 PM   #82
Deadeye22
Member#: 479539
I had Ball Bearing TD06SL2 20G and now I have TD05H 20G, about 250RPM difference is spool on EL headers
Deadeye22 is offline   Reply With Quote
Old 10-05-2020, 06:33 PM   #83
Timmer24
Member#: 519150
Weird
Timmer24 is offline   Reply With Quote
Old 10-07-2020, 02:57 PM   #84
Jedi03
Member#: 491095
2009 STi Blue
do you prefer the 5 or 6? And on EL i agree the spool is much better!
Old 10-21-2020, 01:06 PM   #85
lowbee
Member#: 254317
2011 STi
Just making sure I am reading this right, so you are saying your current TD05-20G spool 250rpm faster than your previous TD06SL2-20G ?
lowbee is offline   Reply With Quote
Old 11-28-2020, 11:50 AM   #86
saaiello21
Member#: 501997
2011 WRX
gray
Been running my td06 sl2 20g now for about 20,000 miles now all in all great turbo for the money. Took me a little to get used to driving it with the lag at first, but once your able to keep it in that sweet spot with your shifts its a beast. I am thinking about switching out the compressor housing to a 3in anti surge style to see if it helps it with lag will update this thread if I do.
saaiello21 is offline   Reply With Quote
Old 11-28-2020, 01:02 PM   #87
lowbee
Member#: 254317
2011 STi
Originally Posted by saaiello21 View Post
.......Took me a little to get used to driving it with the lag at first.....
I see you're running this turbo with a 2.0 engine. How many psi are you boosting ? What is your boost pressure at 3500 rpm? 4000 rpm ? Just trying to get a sense on how boost build with this turbo. Thx.
Have you consider swapping out the journey bearing cartridge with a KBT bolt-on ball bearing to help with spool, I think Arashi offer this as an option.
Old 11-28-2020, 02:26 PM   #88
saaiello21
Member#: 501997
2011 WRX
gray
Originally Posted by lowbee View Post
I see you're running this turbo with a 2.0 engine. How many psi are you boosting ? What is your boost pressure at 3500 rpm? 4000 rpm ? Just trying to get a sense on how boost build with this turbo. Thx.<br>
<br>
Have you consider swapping out the journey bearing cartridge with a KBT bolt-on ball bearing to help with spool, I think Arashi offer this as an option.<br>
<br>
<br>
<br>
<br>
This on a 2.5l fully built with FMIC it hits 21psi at 3700 sometimes a little earlier depends on my driving. Will definitely hit higher boost but my trans will definitely not handle what this turbo has potential to do. Holds my 19 psi I have it set at til 7000 rpms no problem and pulls great. I stuck with a journal style turbo for reliability I drive too many miles to have to worry about rebuilding turbo every 20,000 miles
Old 11-28-2020, 03:47 PM   #89
lowbee
Member#: 254317
2011 STi
.....I stuck with a journal style turbo for reliability I drive too many miles to have to worry about rebuilding turbo every 20,000 miles
Is this statement based on personal experiences ? Or is this type of failure specific to Subaru or a particular brand of turbo ? I ask because a quick Google didn't show a lots of hits.
If this is a concern, check out RHB turbo in Canada. They have a patented triple ball bearing design that float on oil film that might just be the best of both worlds.
https://rhbturbochargers.ca/pages/fu...e-ball-bearing
Old 12-06-2020, 10:58 AM   #90
Seangraz
Member#: 518909
For anyone that’s ordered a turbo from arashi how’d it go and how was communication. I’m trying to order one right now but having a lot of problems. Their website is having issues and I’ve gotten a few messages back and forth through Instagram dms, I’ve sent multiple emails but nothing in response. Any tips?
Seangraz is offline   Reply With Quote
Old 12-06-2020, 07:41 PM   #91
Jedi03
Member#: 491095
2009 STi Blue
Just did a little research on the dsm site, td05 spools faster an td06 has more topend
