10-15-2008, 12:18 AM | #1 |
Member#: 126787
HIIC
Vehicle:2015 WRX STI Crystal White Pearl |
Project EJ18T
i don't normally post alot here but just thought i'd share this project in a place of massive subie traffic. enjoy
joe http://www.rs25.com/forums/showthread.php?t=81773
10-15-2008, 02:04 AM | #2 |
Member#: 74907
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
Took me an hour or so to read all that thread, very nice indeed. I sure as hell wasnt envying you when you ripped out that harness...
Got me thinking about going turbo......eventually... ~Josh~ |
10-15-2008, 06:57 AM | #3 |
Member#: 126787
HIIC
thanks,
yep, it was a bit of a journey to get her running. i was so pissed during the build when things went wrong. but in the end, it was worth it after firing it up and hearing her roar. going turbo?...go for it!! |
11-18-2008, 11:35 AM | #4 |
Member#: 145242
TXIC
Vehicle:1994 Impreza L EJ20K powered. |
You and I have similar mods.
The only issues ive run across are boost creep and the stock L clutch that screams at me every time boost hits 9psi or greater. I also asked you a question in that thread, but ill post it here too. Why didnt you do a full standalone ecu? Also, I have a custom intake that fits a clocked td04, specifically made for the 1.8l engine, its actually pretty trick, im going to get some better pics this weekend, but i just wanted to get your thoughts on FMU and also, did you end up keeping the stock L tranny? |
11-19-2008, 01:14 AM | #5 | |
Member#: 126787
HIIC
check rs25 for my reply. the boost creep is probably the wastegate not letting enough gases through, that's whay i went with the tial 38mm ewg route. but i'm still creeping with the 38mm, should've went with the 44mm. i'm still on the stock L fwd tranny with a a 11lb flywheel and clutchmasters stage 3. shifting is tight, feels perfect. also fwd axles are thicker than awd axles, however i tore my outer cv boost on both sides when trying to do a burnout. left a huge mess, haha. like i said, my wife would've killed me if she found out that a standalone costed north of $1000. post some pics up, cant wait to see it. |
Similar Threads | ||||
3 year project ej18t | '93Impreza1.8T | Normally Aspirated with bolt-on Forced Induction Powertrain | 26 | 07-22-2008 06:18 PM |
ej18t project | manuelmatias | Subaru Conversions | 5 | 04-09-2007 01:02 AM |
Pics of my EJ18T | scoobyimprza | Normally Aspirated with bolt-on Forced Induction Powertrain | 13 | 11-01-2003 11:14 PM |
Pics of my EJ18T | scoobyimprza | Subaru Conversions | 8 | 10-02-2003 11:16 PM |
finalizing EJ18T fuel system setup | scoobyimprza | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 06-26-2003 07:06 PM |
