Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Old 02-27-2018, 04:37 PM   #51
HoeLeeFuQQ
Member#: 465158
2016 Subaru WRX STi
Pure Red
Dumb question will this work on my old rusty 2016 sti EJ motor or will it burst into flames?
HoeLeeFuQQ is offline   Reply With Quote
Old 02-27-2018, 06:18 PM   #52
maperformance
Vendor Sales Rating: (80)
Member#: 141043
2011 STI
black af
Very large purple flames I am afraid....
We may have this option for the 15+ STI's down the road. But those will also require upgraded injectors and fuel pump.
__________________
Leo Vishnyak
651-348-8811 x 107
I want to earn your business, PM me and tell us how we can become your one stop shop for performance parts today!
ACL / AEM / ACT / Cosworth / Grimmspeed / Invidia / Ksport / Manley / Mishimoto / PTE / Tomei / Turbosmart / Wiseco
maperformance is offline   Reply With Quote
Old 02-27-2018, 11:04 PM   #53
Zanna-K
Member#: 457525
2017 WRX Limited
I assume that the parts requirements for this E30 map is pretty strict?
For example, if someone had an upgraded intercooler and charge pipe and/or Upper/Lower TGV's done, would that throw off the tune or actually decrease performance since the tune wasn't done with those mods in mind?
Zanna-K is offline   Reply With Quote
Old 02-28-2018, 09:53 AM   #54
maperformance
Member#: 141043
2011 STI
black af
An intercooler wouldn't be a huge deal. But EGR/TGV deletes are a no go with our tunes at this time.
__________________
Leo Vishnyak
651-348-8811 x 107
Old 02-28-2018, 03:23 PM   #55
Zanna-K
Member#: 457525
2017 WRX Limited
Would an intercooler essentially be a "worthless" mod in that case?
Old 03-05-2018, 04:21 PM   #56
iGamerC
Member#: 482545
Default E30
I also have a gas station near my that has an e30 pump. Could it be possible to just fill up with just the e30 for this tune or stick to the 2:1 ratio?
Also, how is this wear and tear wise? This sounds like an awesome tune and Iím nearly ready to pull the plug and get it! Thereís still just some concerns I have.
Originally Posted by Jamiewrx18 View Post
Also just wondering. I have a station near me that pumps E30. So does this mean I can just pump this in without mixing like E85
iGamerC is offline   Reply With Quote
Old 03-08-2018, 01:41 PM   #57
martinbonds
Member#: 481868
2017 WRX Limited
WR Blue
Default E30 tune
Just wondering if after running E30 tune for a half a tank now with an occasional feedback knock of -2.11. Is this a safe number for fbk? 4.5 gallons E85 them topped off with 93 Oct. DAM stays at 1.
martinbonds is offline   Reply With Quote
Old 03-09-2018, 09:46 AM   #58
maperformance
Member#: 141043
2011 STI
black af
If that's during cruising, I probably wouldn't panic about it.
__________________
Leo Vishnyak
651-348-8811 x 107
Old 03-12-2018, 08:41 AM   #59
martinbonds
Member#: 481868
2017 WRX Limited
WR Blue
Thanks, actually it's a -2.81 fine knock learn occasionally on hard acceleration.
Old 03-14-2018, 05:49 AM   #60
Oreoboi1993
Member#: 480425
My 16 WRX MT hits 207-219įf when I do some pulls on the highway that's heat soak right? I feel a loss of power what's a good temperature it needs to stay at? If I decided to get a fmic would I not need a charge pipe? Would a turboxs tmic be good enough for 500-600hp?
Oreoboi1993 is offline   Reply With Quote
Old 03-15-2018, 11:52 AM   #61
nine5raptor
Member#: 473534
15 WRX Prem. w/ HK
CWP
Are you talking oil temps on the Multi-function display or intake manifold temps as read by the AP?
nine5raptor is offline   Reply With Quote
Old 03-16-2018, 01:35 PM   #62
Oreoboi1993
Member#: 480425
Oil temps on the multi function display
Old 03-16-2018, 07:48 PM   #63
iGamerC
Member#: 482545
Default AF1 Learning 1
Curious what should this be at? Iím spiking occasionally when I let off the gas, last readings were -21.87/7.8. .xx could be slightly off.
Old 03-19-2018, 10:30 AM   #64
maperformance
Member#: 141043
2011 STI
black af
Are you using the stock intake currently?
__________________
Leo Vishnyak
651-348-8811 x 107
Old 03-19-2018, 11:55 AM   #65
iGamerC
Member#: 482545
No I have the ets intake
Old 03-19-2018, 04:54 PM   #66
martinbonds
Member#: 481868
2017 WRX Limited
WR Blue
Default Safe fbk and fkl safe range on wot?
I'm still getting a fbk or fkl of -2.81 on wot. Should I be concerned?
Old 03-21-2018, 11:12 AM   #67
Oreoboi1993
Member#: 480425
I get 1.41 and 2.81 all the time have been with this tune the day it was released I would say it's fine so far I'm not to worried.
Old 03-21-2018, 12:00 PM   #68
ragman
Member#: 268642
2017 WRX Premium
I don't get either type of knock events at WOT on the MAP E30 tune.
My WRX knocked one time when I was at about 10,000 feet by Loveland Pass, at a stop and go light to get on the highway. Other than that one event, it has been spot on.
If you have a stock 2015-2018 WRX, an accessport, and proximity to E85 at the pump, I highly recommend this tune.
ragman is offline   Reply With Quote
Old 03-21-2018, 05:31 PM   #69
Sam425
Member#: 483678
Default Stock fuel pump
Will our stock fuel pump eventually give out running e30 mix just like it did on e85??? Any body have insight??
Sam425 is offline   Reply With Quote
Old 03-22-2018, 09:40 AM   #70
maperformance
Member#: 141043
2011 STI
black af
I don't recall seeing any major issues with stock pumps running a mix...Ugh, my DW65 pump has failed more times than my stock one ever did lol.
__________________
Leo Vishnyak
651-348-8811 x 107
Old 03-24-2018, 09:28 PM   #71
nine5raptor
Member#: 473534
15 WRX Prem. w/ HK
CWP
If you add a little more e85, does it go away? (when you fill up, add an additional gal of E85 instead of 1 gallon E10).
Old 03-26-2018, 09:46 AM   #72
Sam425
Member#: 483678
Default Got some fbk on full WOT
HELP I got some feedback knock -1.41 to -2.81
I've sent my log to Ian to look at.
is it time to sit on a corner and cry????
*1st pic w/ some web browser is the legend and the following screenshots are my logs
File Type: jpg Screen Shot 2018-03-26 at 5.32.56 AM.jpg (37.4 KB, 46 views)
File Type: jpg Screen Shot 2018-03-26 at 5.31.12 AM.jpg (78.5 KB, 45 views)
File Type: jpg Screen Shot 2018-03-26 at 5.31.44 AM.jpg (76.7 KB, 39 views)
Old 03-26-2018, 09:48 AM   #73
maperformance
Member#: 141043
2011 STI
black af
If this is just cruising around, there is nothing to worry about at all.
*1st pic w/ some web browser is the legend the following screenshot are my logs
__________________
Leo Vishnyak
651-348-8811 x 107
Old 03-26-2018, 02:04 PM   #74
Sam425
Member#: 483678
Itís 3rd gear full throttle from 3.6k to redline
Old 03-26-2018, 02:49 PM   #75
maperformance
Member#: 141043
2011 STI
black af
How may gal of E85 did you start out with?
__________________
Leo Vishnyak
651-348-8811 x 107
