Welcome to the North American Subaru Impreza Owners Club Friday September 21, 2018
Old 03-12-2018, 10:11 PM   #1
imblaze89
Member#: 344845
Default Is wrx 5mt same as NA 5mt
Since I cant get my transmission out of gear Im wondering if a NA 5 speed will work. Id love to buy a 6 speed but theres no way I can at this time
imblaze89 is offline   Reply With Quote
Old 03-12-2018, 10:26 PM   #2
monkeyposeur
Member#: 333468
1993 SS
03 WRB GD 205/22T 20G-XT
You would have to figure out if the NA 5mt is hydraulic, push, or pull style. If the slave pushes towards the firewall, it's a push type. If it pushes away, it's a pull type. Some NA 5MTs are cable driven.
It is possible to convert a push to pull.
And whatever transmission you install will need to have a matching rear diff or it will break.
The next best thing to a 6mt is a JDM 5MT. Mine has similar gearing to a 6MT and has a 4.44 FD which makes it super fun to drive. You can get a complete shipped low mileage JDM 5MT from lots of reputable sellers for about $1100 shipped w/rear diff (sometimes with axles). I bought mine from JDM Racing Motors.
monkeyposeur is offline   Reply With Quote
Old 03-12-2018, 10:39 PM   #3
imblaze89
Member#: 344845
Yea wow screw that u could get a 6 speed for a little more. Id rather figure out how to get mine out of first gear
Old 03-12-2018, 11:20 PM   #4
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Well, that's not true, unless you are referring to a 6MT that is junk.
A used, good 6MT, with rear diff & driveshaft is more like $3K+
Old 03-14-2018, 08:38 AM   #5
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
LGT 5speed is better than most JDM 5 speeds. only the JDM RAs had the thicker cogs. all 05-08 LGT 5 speeds have the thicker cogs and 08-14 wrxs have them too.
Titter is offline   Reply With Quote
Old 03-17-2018, 11:10 PM   #6
Mauricemonge
Member#: 425415
66 Bug with ej20g
Here is a link to what Tranny's came with push or pull clutches, and the gearing.
http://www.gearhack.com/myink/ViewPa...ission%20Chart
I think most of the NA transmission used thinner gears, as did the 02 and some of the 03 US wrx transmissions - early wrx uses the wrong clutch type for you anyway.
There is a conversion kit out there to convert a push to pull, but i think it only comes with the clutch kit it's designed for and is $$$
Assuming you have an ej engine, yes it'll work if the driveshaft, diff, and shifter setup are the same. Also, if you currently use male axles at the transmission, and you need female, that's another project (not sure if you need to split the case and pull the stubs, or change axles)
A NA is only good if you want to cruise around while your tranny is getting fixed, and you acquired it cheap. It'll probably break under power.
Did you happen to try rocking the car back and forth with someone pulling on the shifter when it was all together?
Last edited by Mauricemonge; 03-17-2018 at 11:27 PM. Reason: More info and bad English
Mauricemonge is offline   Reply With Quote
