06-13-2001, 07:21 AM | #1 |
Member#: 6372
Vehicle:2004 STI WRB |
Front Speaker Install (door pannel removal)
Does anyone have know of a link that shows the removal of the front door pannels on my00 2.5rs?
06-13-2001, 09:00 AM | #2 |
Homicidal Maniac
Moderator Member#: 1612
Vehicle:2008 STI |
Are you looking for what pieces you need to remove the door panel, or simply a pic of the door panel removed?
-Jon |
06-13-2001, 01:07 PM | #3 |
Homicidal Maniac
Vehicle:2008 STI |
Ah, thats easy. There is a pop clip on the outer door panel up near the dash area. One screw holding the door handle down, two screws hidden behind little plastic covers in the door handle, then a bunch of little clips around the outer edge of the door.
After the screws have been removed, you can pull the trim plate from around the door handle; its just clipped in. The door controls are also clipped in. Then you can just grab the bottom ofthe door and work the clips out. In the picture below, the red arrows are clip locations, and the green arrows are screw locations. [EDIT] I forgot to mention that you have to remove the trim plate behind the side view mirror. It is just above the door panel and is held in by pins being pushed into rubber pieces. Just pull to remove, but remove straight out or you can break one of the pins. [ June 13, 2001: Message edited by: stimpy ] |
06-13-2001, 01:07 PM | #4 |
Member#: 2248
Vehicle:2012 C63 2012 Silverado HD |
06-13-2001, 02:09 PM | #5 |
Member#: 6372
ahhhhh that's it Thanks
06-13-2001, 07:28 PM | #6 |
Member#: 5796
Vehicle:2013 BRZ & 2004 WRX |
stimp are those focals?
06-14-2001, 12:53 AM | #7 |
Member#: 6372
Looking for the screw/fastner locations
06-14-2001, 11:43 AM | #8 |
Homicidal Maniac
Vehicle:2008 STI |
No, they are Planet Audio's, PA-PC64CK, which are about 7" wide, over 3" deep, and will handle 150w RMS/300w peak.
-Jon |
06-14-2001, 01:50 PM | #9 |
Member#: 6372
Was this pic for a 2000?
I have a screw near the front dash (Red arrow) and one near the rear of the door but I do not see the screws near the pull handle (center two green arrows) did not see screw/covers. |
06-14-2001, 05:03 PM | #10 |
Member#: 1503
South East
Vehicle:2012 2012 WRX Sedan Silver |
The covers are there and you don't remove the screw for the door handle. Its two screws and the plastic pushin fastener.
Zee |
06-15-2001, 07:46 AM | #11 |
Homicidal Maniac
Vehicle:2008 STI |
Sunrise City Rider: correct, the screw on the door handle usually doesn't need to be removed. I have needed to remove it to get a little more play in the trip plate for re-installation sometimes. The screws on the armrest are hidden behind two different plastic clips.
-Jon |
06-15-2001, 11:41 AM | #12 |
Member#: 6372
The two on the arm rest are what I don't have... No hidden screw covers/clips. Could it be under the power window buttons..?
06-15-2001, 01:11 PM | #13 |
Homicidal Maniac
Vehicle:2008 STI |
Here is a pic of the screws and locations:
You don't have those screws there? -Jon |
06-15-2001, 02:28 PM | #14 |
Member#: 1503
South East
Use a big fat Philips Screwdriver.
Zee |
My version of front speaker install | outback_97 | Car Audio, Video & Security | 28 | 09-07-2009 08:09 PM |
6.5" front speaker install in 2004 STi | Signa | Car Audio, Video & Security | 7 | 09-17-2003 08:38 AM |
Front speaker install questions for sti | philw007 | Newbies & FAQs | 2 | 06-30-2003 10:59 PM |
Just finished front speaker install | cwb124 | Car Audio, Video & Security | 4 | 03-25-2002 02:07 PM |
Maximum depth for front speaker install on a 99 GT? | MY99 2.5GT | Legacy Forum | 1 | 06-12-2001 07:36 AM |
