Welcome to the North American Subaru Impreza Owners Club Wednesday December 2, 2020
Old 06-18-2020, 10:15 AM   #1776
SkateAndDestroy
Member#: 133893
2011 BMW 328i Xdrive
EJ255 02 Wagon (retired)
Originally Posted by elib8922 View Post
Hi my name is Eli I have a 2012 subaru impreza wrx hatch. I have had the car for two years now its been running strong but i recently started to do more work on the car the mods are, grimspeed uppipe with 38mm tial wastegate controlled by 3-port grimspeed EBCS, invidia catless divorced do to a full cutback ark grip exhaust, Stock fuel pump stock injectors stock fuel pressure regulator. I have noticed that when the weather gets hotter it tends to skyrocket to +25% with AC on and when its cooler +14.84%. I have done a boost leak test before and fixed the problem i have not done a vacuum leak or smoke test. Just very confused why the numbers are skyrocketing way above the values it is supposed to be in.
mod list condensed
grimspeed up-pipe
38mm tial wastegate running 1 bar springs (pushing 18psi regular 18.5-19 if freezing cold)
grimspeed 3-port EBCS to control wastegate actuation and boost.
invidia catless divorced dp
ark grip cat back exhaust
stock pump injectors and fpr
WOT log
https://docs.google.com/spreadsheets...it?usp=sharing
idle log
Do you have a custom tune for the EWG? Aftermarket intake or stock airbox? (didn't see intake listed in the mods)
SkateAndDestroy is offline   Reply With Quote
Old 06-18-2020, 04:21 PM   #1777
elib8922
Member#: 515635
Yes I do have a custom tune for my ewg my apologies completely forgot that. Its a cobb short ram front portion to a tomioka 2.75" or 3" inlet to turbo not sure the actual size but i know its one of those.
elib8922 is offline   Reply With Quote
Old 06-24-2020, 10:21 PM   #1778
SuperDrewb
Member#: 516113
2005 WRX
Hello. I've got an issue with some serious hesitation and afterfire on 3rd gear WOT pulls. I'll post two logs, any feedback is really appreciated. I've just changed over my last two ignition coils (all four are now new), expecting that to have fixed the issue.
2005 WRX 5spd Sedan
Mods:
Invidia Catless Turboback
Perrin up-pipe
Stock airbox, snorkel delete
Cobb EBCS
Cobb Stage2+ Tune 93 EBCS
Serious hesitation on WOT. DAM drop.
WOT Attempt 2, major visible bucking of the car. RPM, boost, etc, go up and down at WOT
SuperDrewb is offline   Reply With Quote
Old 06-24-2020, 11:07 PM   #1779
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
4th, 5th, 6th pull at 25psi on a stock Ej20
https://datazap.me/u/terryjr/133mph?log=0&data=8-11-14&solo=11&zoom=24-261
no694terry is offline   Reply With Quote
Old 06-25-2020, 12:40 PM   #1780
Southern Boost
Member#: 388065
2008 WRX
Rolling Timebomb
I am getting random -11 FBK in low RPM ranges. Maybe once every 3 days or so. I have not been able to pin point it to a temperature, shift, phantom knock. I deleted any loose heat shields and zip tied any loose cables in the engine bay. It didnt start happening until my new clutch. Recently went 6 puck. I am leaning towards it being a temp thing since i do not remember ever seeing it at night. I live in Florida were day temps are in the 100+ right now. The tune is done by Torqued Performance. Eric said everything looks fine as far as tune goes after i sent him some 3rd gear WOT logs.
https://drive.google.com/file/d/12mh...ew?usp=sharing
Southern Boost is offline   Reply With Quote
Old 08-07-2020, 10:51 PM   #1781
Haevn
Member#: 495950
2011 WRX
here is mine with fp blue with 84mm housing
https://drive.google.com/file/d/1vkh...ew?usp=sharing
Haevn is offline   Reply With Quote
Old 08-14-2020, 06:44 PM   #1782
gonzotr
Member#: 517418
Default Interesting
gonzotr is offline   Reply With Quote
Old 09-17-2020, 12:30 AM   #1783
wrxlr_8
Member#: 518643
2012 WRX
white
Default 2012 wrx IAG short block
TGV delete
MISHI TMIC
Cobb Up-pipe
nameless cat back
IAG comp AOS
mishi radiator
perrin BPV
https://drive.google.com/file/d/135j...ew?usp=sharing
wrxlr_8 is offline   Reply With Quote
Old 09-20-2020, 08:29 PM   #1784
lbrown39615
Member#: 515256
2006 WRX
Hey, I'm new here. I've been using the forum mostly for research. I figured I should start posting. Here's a log I did today. I'm not sure what the knock is all about, it's not much though. The IAT was 100* and it's 70* outside today, so that could be why? Is there anything to worry about in this log? My wideband shows around 10.3-10.8 at WOT.
06 WRX
93 octane non-ethanol
XPT stage 2 tune
STI TMIC
Catless megan downpipe
cobb ss 3" exhaust
tgv delete
tomei intake tube
3rd Gear, both logs were after ECU reset.
Edit... Here's a new log from a few minutes ago. I don't see any knock this time, so that's good. It keeps spiking a little over 19psi though. I think that started after I added the TGV delete, not positive though.
lbrown39615 is offline   Reply With Quote
Old 10-20-2020, 05:00 PM   #1785
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
06 WRX
XPT stage 2 tune
STI TMIC
cobb ss 3" exhaust
tgv delete
tomei intake tube
Knock is minimal and timing is pretty tame. Without knowing actual AFR, it's a guess as to what's causing it... Real or not. You'd probably benefit from a WBO2 and a custom tune. I'd do a VF39 or the like as well.
yamahaSHO is offline   Reply With Quote
Old 10-22-2020, 04:29 PM   #1786
Conster102
Member#: 519178
2003 WRX 5mt hatch with k&n short ram air intake. Runs were done at 4200 ft above sea level on flat ground. I do not know if the car has been tuned I just got it. I am using a tactrix openport 2.0 and RomRaider logger. I cannot connect to the ECU using ECUFLASH though. Log: https://drive.google.com/file/d/1Z_HIPWNeY_DSkLXNEcjXPNPRe_-EzD_p/view?usp=sharing
Conster102 is offline   Reply With Quote
Old 10-22-2020, 06:01 PM   #1787
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Currently on my 5-6th revision of this self-tune, trying to get the boost smoothed out, getting some spike and oscillations.
-2004 Subaru WRX Wagon
-Stock 5 speed
-Stock EJ205 motor, Grimmspeed 3-port EBCS, VF-37 turbo, OEM jdm twinscroll headers/up, Tomioka catless DP, Greddy catback 3", JDM STI Pink inj, V10 JDM TMIC, Perrin Turbo inlet 2.5", stock airbox/filter
-3rd gear pull
Run was on a flat straight away
*forgot to log IAM but its staying at 16...
murrdogg24 is offline   Reply With Quote
Old 10-22-2020, 06:46 PM   #1788
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
I would add Target Boost to that log. The WGDC is making a lot of correction.
Old 10-22-2020, 07:23 PM   #1789
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
I'll do that next pull, going to lower my WGDC, I think you're right it's overshooting...
Old 10-22-2020, 11:07 PM   #1790
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Did about 8 rev's tonight trying to dial in WGDC...best I could do for now...15.38psi stable without overshooting...was hoping to get at least 18psi out of this turbo but I don't know what else to look at here....I'm at about 6000ft above sea level where I'm at, should I look at my boost compensation table?
Edit:
Stoopid me...I checked my boost compensation table and had values in there that needed to be zero'd out since I'm at 6000ft and 11.3 atmospheric pressure....once I did that now my boost is hitting target dead on. Now whether to turn it up more or stay ....https://docs.google.com/spreadsheets...it?usp=sharing
Old 10-23-2020, 01:11 PM   #1791
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
You have major A/F correction which tells me that you need to tune your MAF scaling for probably both closed loop and open loop. This is probably attributed to your short ram intake...it's much easier to tune the MAF on the stock intake.
Originally Posted by Conster102 View Post
2003 WRX 5mt hatch with k&n short ram air intake. Runs were done at 4200 ft above sea level on flat ground. I do not know if the car has been tuned I just got it. I am using a tactrix openport 2.0 and RomRaider logger. I cannot connect to the ECU using ECUFLASH though. Log: https://drive.google.com/file/d/1Z_H...ew?usp=sharing
Old 10-23-2020, 01:14 PM   #1792
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Is this even a WOT pull? Your log doesn't show 100% throttle open position anywhere in it....
Originally Posted by wrxlr_8 View Post
TGV delete
MISHI TMIC
Cobb Up-pipe
nameless cat back
IAG comp AOS
mishi radiator
perrin BPV
Old 10-23-2020, 01:18 PM   #1793
murrdogg24
Member#: 50586
2020 STI
Crystal White Pearl
Based on the AF corrections and your snorkel delete I would recommend doing some MAF sensor scaling to alleviate the corrections issue...once you do that then move on to tuning the boost control..
2005 WRX 5spd Sedan
Mods:
Perrin up-pipe
Cobb EBCS
Old 10-24-2020, 10:52 PM   #1794
Conster102
Member#: 519178
Aight dope thank you and that is something I can change with Romraider Editor and ecuflash right? Or do I need to go to a shop? Sorry I am a noob than you
