01-18-2015, 06:10 PM | #1 |
Member#: 330174
RMIC
Vehicle:2002 wrx wagon black |
turbo upgrade (don't want a Dino queen)
i have bean racking my brain and doing a lot of reading. it is about time for me to increase the power on my car. i am not looking to create a dino queen i don't want to crack the block. i am looking to create a build that will give me great low to mid range power i am not too worried about top end. i drive the car year round mostly in the mountains, and when it snows bad it drives to work. i have modified the suspension brakes cooling (new hoses and aluminum radiator) and exhaust ( manifold, up pipe, and catles 3" turbo back). i have a 4ate and plan on doing a high stall the the same time i do the turbo. i understand that i need to do all the supporting mods (injectors, tvg deletes, sti tmic, fuel pump, intake, protune, and inlet {already have}).
so over all i am tossed up between 1. td04 tith a 19t conversion 2. Vf39 3. td05 18g/20g (less hot) i was hoping to hear some of your opinions on this. p.s. the care is well looked after and has 150k on the clock.
01-19-2015, 06:15 PM | #2 |
Member#: 312980
SWIC
Vehicle:2002 WRX Blue |
VF34 or 16g
01-20-2015, 01:03 AM | #3 |
Member#: 331119
19T, or VF would be good choices. I had a small 16G on a 2.0 and felt it was too laggy. Definitely don't go larger than a small 16G.
01-20-2015, 09:23 AM | #4 |
Member#: 353137
Vehicle:2002 WRX JDM 207 Silver |
01-20-2015, 11:36 AM | #5 |
Member#: 79934
E. Canada
Vehicle:02 WRX MBP |
I had a Blouch EVOIII-16g and it was my favorite DD turbo to run on a 2.0L WRX and I've run:
VF39 VF24 TD04 a few rpm later spool than a VF39 but pulled hard till 6500rpm. |
01-20-2015, 05:27 PM | #6 |
Member#: 167338
TXIC
Vehicle:11 Wrx hatch Dgm |
16g 7cm feels way better than any VF out there
01-21-2015, 11:43 PM | #7 |
Member#: 330174
RMIC
I am probably going to rule out the vf39 the cracking issue is punting me off. On the 16g is there much difference from the 7cm to the 8cm? Also has any one actuly dun the 19t conversion were there any fitment issues?
01-22-2015, 02:10 AM | #8 |
Member#: 202895
the wastegate cracks have not shown to effect performance of the turbo
01-22-2015, 09:59 AM | #9 | |
Member#: 79934
E. Canada
The 7cm 16g is perfectly suited for DD, it's a good balance of compressor wheel size and hotside. An 8cm 16g would be a nice track setup and would pull harder uptop as you're flowing more exhaust gases but then will be limited shortly after by the 16g compressor wheel. |
01-22-2015, 08:11 PM | #10 |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
01-23-2015, 02:30 PM | #11 |
Member#: 107179
Vehicle:S4, WRX 1.27 60', 9.37 1/4 |
Of all the turbos I have ever driven or owned on EJ20's, I always preferred a 40-44 lb/min turbo. I wanted a fairly broad powerband but don't autocross so I didn't prioritize spool. The 16GXTs I have played with have tended to be my favorites and my old 7CM 20G was amazing.
You would have trouble convincing me this is a bad powerband for a 2.0L making that much power: Green - Old Jorge 20G tune, ~20-21 psi Blue - New Jorge 20G tune, 93 octane, but added big maf intake and wrapped header, ~21 psi Red - New Jorge 20G tune, 100 octane, ~25 psi Yes, this was on a stock EJ205 (intake, full exhaust w/wrapped header, DW 750s, APS top mount, inlet, IWG Deadbolt 7cm 2.4" td05 20G). I should also note these were like 4-5 years ago or something. Last edited by RexFTW; 01-23-2015 at 02:38 PM. |
01-24-2015, 08:27 AM | #12 |
Member#: 319257
I have noticed the vf turbos make better power under 20psi. The TD05 20G makes better power 20+psi.
01-24-2015, 10:50 PM | #13 |
Member#: 331119
That's my opinion. You have yours. I can say that I've actually owned a 2.0 with a small 16G - have you? In my opinion it was a great turbo in general, and it totally rocked from 3K RPM all the way to redline. However, from 0-2K RPM, there was virtually no spool or power or torque. 0-2K RPM, you may as well have been driving a Smart car.
If you actually have driven a 2.0/16G then I might respect your opinion, but you haven't stated what you actually drive or what you actually know. I know first hand. If you think based on experience that a 2.0 liter with a 16G at 0-2K RPM is a rocket ship, then go ahead and live in your fantasy world. |
01-25-2015, 09:56 AM | #14 |
Member#: 330174
RMIC
^^burn
thnx for all the feed back. has any one had experience teh the 19t conversion. i haven't seen it allot on subarus but the volvo and sob guys seen to like them. |
01-25-2015, 02:04 PM | #15 | |
Member#: 234937
SWIC
Vehicle:2004 STi 20G'd Blue |
01-25-2015, 02:58 PM | #16 |
Member#: 330174
RMIC
my stock turbo doesn't even start till 3k. maybe i should get this one it wont take to long to spool. Last edited by gregmyer; 01-25-2015 at 03:07 PM. |
01-25-2015, 05:51 PM | #17 | |
Member#: 331119
There are many other setups (if you do it right) that will experience very minimal lag. |
01-26-2015, 08:47 PM | #18 |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
01-26-2015, 08:49 PM | #19 |
Member#: 16200
ding-ding-ding
01-26-2015, 09:13 PM | #20 |
Member#: 31639
RMIC
Vehicle:99 Impreza White |
1. There is a lot of variability between setups which will affect spool. For some the TD05 is too laggy. I had a 6cm on a big tubular header with a large up pipe and of course it didn't spool until 4k and had nothing down low. I put on a stock ported header with a smaller up-pipe, ported my turbo and dropped my spool by 500 rpms.
2. Everyone's definition of unacceptable or undesirable lag is different. 3. Everyone's expectations for top end is different. Yes the TD05 will have a lots of top end power which does not fall off, but you get this at the sacrifice of some low end spool. 4. Some people are okay sacrificing a little top end power for a little more around the town down low power. I currently am running the TD05 16g 6cm stock V2 STI turbo. It's nice on the freeway and I can pass anything, but it's not that great in town which is where I mostly drive it. I'm working on building a TD04-19t billet. 5. Every TD05 16g is not the same, comparing a Blouch with a billet wheel and ported polished housings is not the same as a generic MHI model. 6. Looking at Uncle Scotty's posts around the forum, either his definition of spool is different than everyone else's or he has some magic tune juice which lowers spool. Thus, if you have any different results than he has, you must be incompetent, and if you have a different opinion than him you must be wrong. Thus, I would base your decision on what turbo to buy on Dyno results on motors with similar setups. You will be able to see where they spool, where the peak torque is, and the shape of the power band. All you're gonna get here is people's opinions which are, of course, all different. All you need to do is google for the dynos. |
01-27-2015, 01:32 AM | #21 |
Member#: 16200
01-27-2015, 01:44 AM | #22 | |
Member#: 16200
I road tuned my car almost every time I drove it for a year or so and I did ALL the 'breathing mods' and did all the tricks in the book to get it the way it was which wasnt really all that much or that hard... I just had to pay attention and figure it out. this isn't difficult......just a lot of idiots go about it all wrong and then most idiots don't really do the right combination of mods and tuning and get poor results and I did it with a UTEC with an AP and their race tuner software....it would be a piece of cake most tuners don't touch the maps below 3k rpm or do just a little tweek or 2 and call it good.....that is bull**** the meat of the map needs to be off idle to 3k...which took me months to get right and I was at sea level....well...the area where I lived was less than 20' ASL and I got good 93 octane which DID make a bit of a difference as well. why do you think I tell people they are idiots so often around here |
01-27-2015, 10:18 PM | #23 | |
Member#: 331119
I agree with everything Scotty said except for his recommendation that 16G is the best. Scotty agrees with me 100% - he just doesn't know that he does. As Scotty said, most tuners will not tune to the level he would, and most would not necessarily know the best combination of modifications to make the 16G on a 2.0 liter the best it can possibly be. Therefore, you shouldn't get a 16G. I agree with Scotty that a 16G is the optimal turbo if everything else is PERFECT(the perfect tune, and the perfect mods), but everything else won't be perfect because 99% of us don't road tune our car for "months", nor do most tuners know the perfect headers, or whether to port of polish, or whether to ceramic coat, etc. There are so many decisions to make when modifying and all of them have to be perfect with the 16G to keep low end power. You will definitely always get high end power from a 16G - no doubt. Keeping the low end power is the trick. Therefore my advice is be conservative and go with a 19T or a VF as the biggest to keep more low end. I personally would also add meth. A VF or 19T on meth will beat the 16G without meth. So I agree Scotty is right, but nobody is going to tune their cars as carefully and methodically as Scotty, so go more conservative. |
01-28-2015, 03:39 PM | #24 |
Member#: 341649
International
The best damn turbo for a street DD 2.0 according to concesus is an evo III 16G or 18G. Turbo spool up / late boost threshold would be forgotten the moment that thing hits and u stay in boost through the gears.
What many refer to as turbo lag is boost threshold rpm |
01-29-2015, 12:10 AM | #25 | |
Member#: 16200
sweetie the 19t is the BIGGEST POSSIBLE waste of ALL INVOLVED there EVER was it is the BIGGST FALLACY in turbodom for the 2.0 its an IDIOTS terbo waste of time. forever. a competent build with a competent tune using a 16g will smoke the 19t for breffast, lunch and dinnna and cost......the same or LESS FORGET THE 19T....ITS A L00000000SERS TERBO |
