12-22-2009, 06:56 AM | #1 |
Member#: 84586
TXIC
Vehicle:1995 FRANKNTURD 2012 Tundra DC 5.7L |
GD coilovers in a GC body?
I have a '93 Impreza L that I am currently doing a full STi swap on (using an '07 donor car). My question is how will the stock '07 strut length compare to the '93 struts? Will they be too long, too short or just right?
I am building this for SCCA SM and NASA TTS use so I need to order a new set of AST double adjustable coilovers and I need to know what lengths to get. Thanks, -Paul
12-23-2009, 01:13 PM | #2 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
Length will not be your problem, the brackets that bolt to the knuckles ( fronts ) & the 3 holes in the top will need to be modified ( rears)
It can be done. I'm running a set of 05 STi struts w/ JDM pinks in my swapped 93 L |
12-23-2009, 02:16 PM | #3 |
Member#: 9351
Vehicle:2006 trailblazer SS black |
05 and newer wont work but 04 and older will..
12-24-2009, 12:11 AM | #4 |
Member#: 84586
TXIC
The suspension is from an '07 STi so the later 5x114.3 is correct ('05-'07 STi).
I already have Vorshlag camber plates so I don't need to worry about topmounts either. I need to order AST double adjustable coilovers and I want to make sure I am getting the correct coilover length. I am lowering the car quite a bit so I need shorter bodies, 1.5" shorter front and if the rear GC8 length is the same as the rear STi length then that would be 1.5" shorter also. If it is not the same then I need to determine how it differs from the STi version. Thanks, -Paul |
12-25-2009, 04:44 PM | #5 |
Member#: 150922
Vehicle:97 OBS EZ30R 94SVX LSi Bourduex Pearl |
Just order GC coils with the STi lowers to attach to the STi knuckles. Other than that you can always just use the stock stuff and replace the top hats with GC camber plates and bammo! Done. The later is what I'm doing with mine till I find a coilover I really will feel comfortalbe with for my use and setup. GL with your conversion.
12-25-2009, 05:26 PM | #6 | |
Member#: 84586
TXIC
I think at this point I will just purchase some used '05-'07 STi struts and measure the stock range and ride height. -Paul |
01-04-2010, 12:23 AM | #7 |
Member#: 112759
01-04-2010, 06:45 PM | #8 |
Member#: 185180
TXIC
Vehicle:03 Forester XS PSM |
yea we put my old JIC's in a 1996 just had to mod the wholes a bit
01-04-2010, 10:00 PM | #9 |
Member#: 112759
Similar Threads | ||||
gd radiator in a gc? | cavakilla | Subaru Conversions | 3 | 04-29-2012 03:08 PM |
WTB: Coilovers for the GC body ASAP | gc8awdsti | Private 'Wanted' Classifieds | 4 | 03-06-2009 08:35 PM |
Has anyone installed a JDM GD cluster in their GC? If so... | bsmitty | Interior & Exterior Modification | 8 | 02-19-2008 06:57 PM |
Anyone running GD coilovers on a GC? | jamesfacts | Brakes, Steering & Suspension | 5 | 05-08-2006 04:52 PM |
6Speed MT in a GC Body | subaru_gc8 | Transmission (AT/MT) & Driveline | 1 | 12-15-2004 07:44 PM |
