Welcome to the North American Subaru Impreza Owners Club Thursday December 1, 2022
Old 09-27-2004, 05:51 PM   #1
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
Default Avo 600
i am getting a turbo upgrade.
i have seen good numbers with the greens.
so i decided i want to go bigger than a green to get more off pump gas.
i seen one forum with 450whp, anyone else know what kind of numbers im gonna be looking at,...
also,
is it worth eliminating AVCS for 272 cams
SuperSTI is offline   Reply With Quote
Old 09-27-2004, 06:21 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
No not without doing some headwork and beefing up the bottom end. Uh...that goes for the turbo and the cams.
Soon2Bgreat is offline   Reply With Quote
Old 09-27-2004, 06:22 PM   #3
bikerboy
Member#: 5477
2007 R171.473
2009 SWP Spec B
bikerboy is offline   Reply With Quote
Old 09-27-2004, 07:23 PM   #4
carguyx
Member#: 66850
04 green'd STI
11.41 @ 117mph 93 oct.
That turbo is not made to run with a stock bottm end.
carguyx is offline   Reply With Quote
Old 09-27-2004, 08:38 PM   #5
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
That turbo made 450whp on 2 cylinders. It will devistate the stock STi pistons. Broken ring lands here you come.
Back to your question. With supporting mods and proper tuning 500whp will not be a problem. If you haven't already start looking at forged pistons.
Silver-Bolt is offline   Reply With Quote
Old 09-28-2004, 01:10 AM   #6
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
I gotta disagree on this. Sponaugle runs that turbo at 26psi. You don't have to do that. I run my SBGT30R-14 (basically the same turbo, its a GT35R, 65lbl compressor) at 20-22psi, and its fine on the stock bottom end. I wouldn't call it uber-reliable, but at 22psi (on pump gas btw) it'll last a LOT longer than at 26psi obviously.
Tune in baby steps, be conservative with your timing and enjoy the boost. And, start saving for better pistons (and a clutch, and better fueling, and.... ) so you can turn the boost up.
For your question on the 272cams - don't do it. You need all the help you can get to spool that thing up, last think you want to do is pull the last little bit of bottom end out from under you for more top end. Those cams are made to run cars to 9000rpm, and with the stock bottom you're not gonna want to push much past 7500rpm. Personally, I have my rev limiter set at 7300rpm soft, 7500rpm hard. Its just not worth it.
500whp will be cake for the turbo, but is the rest of the car up to it?
DarthChicken is offline   Reply With Quote
Old 09-30-2004, 01:44 PM   #7
SuperSTI
Member#: 67182
2004 Subaru STi
i know gadeil made 504whp with the UR KIT, i woundered if i could make more than that with the AVO 600
FS : 05 Impreza Rs $9,600 davecamp21 Private Vehicle 'For Sale' Classifieds 2 06-02-2010 07:48 PM
FP RED vs AVO 600 SuperSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 02-01-2005 07:39 PM
AVO 600 or ULTIMATE RACING GT35 KIT SuperSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 10-16-2004 07:22 PM
what do you think avo 600 will cost ? BoostdBoxer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 07-16-2004 10:47 PM
Where to purchase an AVO 600? BoostdBoxer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-16-2004 12:21 PM
