12-10-2001, 05:43 PM | #1 |
Member#: 1765
Vehicle:2000 WRX Blue |
Adjustable cam sprockets
One of the most usefull tuning devices.... but !incredible! not available for WRX yet. I wonder why has it taken so long to be in the market . Anybody has valid info about quick future availabilty??
Kikos |
12-10-2001, 05:57 PM | #2 |
Member#: 1829
AEM makes them.. You wouldn't catch me putting that junk on my car ever since I seen what someone showed me at SEMA..The stuff is garbage. HKS makes then..NOT CHEAP... UR racing will be making them soon.. You have my word on it ...Gerry
12-10-2001, 06:08 PM | #3 |
Member#: 1765
AEM says they make them, but they don't. They won't give you price neither deliver compromise. SOO.. they do not have them.
UR has been playing the game of ' availbility.....soon' and that is it. Will check on HKS..... Kikos |
12-10-2001, 06:17 PM | #4 |
Member#: 1765
NOPE...... HKS do not list this neither for WRX . So ,, anybody else??
Kikos |
12-10-2001, 07:57 PM | #5 |
Member#: 9327
its yet to prove a worthwhile mod on Ej20's for as long as I can remember....stock WRX cams, and STi cams as well, have a bit of overlap in them, so cam gears are really not a necessary mod.
Once you go with aftermarket cams 9ie custom grinds), they might yiled more benefits, as you wold have a more custom derived setup (in the samwe vein, cams tend to not be a very popular mod for the car either, maybe due to cost?) |
12-11-2001, 10:37 AM | #6 |
Member#: 1765
Z1..perf...
I work daily with this engines. Since this are quad cams set up I have found ALWAYS a big difference in timining between both intakes or both exahust cams. You can easyly see 116 deg on one of the intakes and 109 deg on the other ( max lift method for check out) and same happens with the exhaust. I have corrected that to certain specs that work great BUT , removing the dowel pin and tighten harder than specs the bolt . Nothing I would trust for continous hard work. So, it is not only the capability to choose your degreeing preference but to obtain proper specs. Not to mention that rertarding a little the intake IT WILL give you some extra nice mid to top HP. Kikos |
07-19-2002, 01:07 PM | #7 |
Member#: 1765
Update.... anyone?
Its been a few months since i posted this. Anyone have news on this?
Kikos |
07-19-2002, 01:49 PM | #8 |
Member#: 7822
SCIC
Vehicle:2002 WRX Multi layer snot green |
jun
07-19-2002, 05:05 PM | #9 |
Member#: 1765
Well if this is the case i want to contact them but the JUN internet site(www.junusa.com) does not seem to be working.
Anybody knows the correct one? Kikos |
07-19-2002, 07:28 PM | #10 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
um don't hold your breth ...
perhaps thet fact that the ej20 is 10 years old.. and no one in that time has made adjustable gears.. would lead a person to think that they are just not nessiary |
07-19-2002, 07:41 PM | #11 |
Member#: 7190
You won't need adjustable cams on a boxer engine. The idea is not quite to tune the cams. Its to bring them back into spec when you have decked the head or the block. Because doing that on a Subaru boxer engine may cause fitment issues with the intake and exhaust manifold, its not normally done. Hence there not being a need, and therefore not a product.
07-19-2002, 10:32 PM | #12 |
Member#: 11396
Vehicle:2002 impreza blue |
Here you go, and if you think I'm wrong go ask Subaru
Cam tuning is a critical part of any performance tuning. Through cam tuning you can adjust your hp and tq peaks and you can tune for larger turbos, increase exhaust energy. For stock computers you can advance intake cams so that where you once ran lean you will then run richer. If you go to Barnes and Nobles, and performance manual will include cam tuning, everybody in the world does it including the STI VVT Engine. That's What VVT is!!! If it isn't neccasary in boxers why would Subaru put it in their top end engine and in their WRC car. One of few race cars capable of VVT at 40+ psi boost! The reason that adjustable cam gears aren't made for the WRX!!!! Drumroll please!!!! The Wrx has one cam gear per bank and one parasite cam. One cam is driven by gear off of the other. So if your one gear was adjusted, it would adjust both whether or not you wanted it to. Now in order to make this work, you need three new pieces. An adjustable initial cam, and both gears(primary, and parasite) adjustable. Which would make, this product very expensive. And dificult to install and tune for all but well trained mechanics. More to follow, I may possibly have an engine builder who is willing to R&D and produce just this, with a good enough buy in. But give me time as this is just a possibility right now. |
07-22-2002, 10:54 AM | #13 |
Member#: 1765
William......
What do you mean ? there is NO parasite cam in a WRX. This is a quad cam engine and all four cams are driven independely by the belt. With a proper camsprocket on each cam you can easly adjust them to whichever speccs you choose and YES , there is much to gain by doing this. I have done it by installing offset bushings ( i would really like to do it with adjstable sprockets) and you can inmediatly feel the gains in mid to high RPM by retarding a little the intake cams. Kikos |
Similar Threads | ||||
NON AVCS cams and EJ257 heads ADJ cam sprockets | saintluciascooby | Built Motor Discussion | 12 | 01-23-2012 09:12 PM |
who makes adjustable cam sprocket sets for our engines??? | WRXINTX | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 28 | 12-10-2005 09:19 PM |
Cams and cam sprocket for STI? | hauvis | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 05-11-2005 10:43 PM |
F.S. JUN adjustable cam sprockets for wrx | boogerwrx | Private 'For Sale' Classifieds | 0 | 06-29-2004 06:48 PM |
WRX oil pan, Cam sprockets, Cam Cover's etc | fimotorsports | Private 'Wanted' Classifieds | 0 | 10-30-2003 01:19 PM |
