Welcome to the North American Subaru Impreza Owners Club Sunday August 19, 2018
Old 06-21-2017, 08:29 PM   #26
91 RS RA
Member#: 457410
1991 Legacy RS RA
Originally Posted by albersondh View Post
Im sick of driving all over the place and begging machine shops to do my little one off BS projects. Its getting harder and harder to find a good machine shop that is willing to take on less than production volume work... Been looking at bench top lathes and mills, like this. http://littlemachineshop.com/product...ProductID=4841
At the moment I need to make some small bushings and hold an id/od to +/- .0005 and Im at a stand still until I get this done.
Anybody using these bench top lathes and/or mills for DIY stuff? What about combo lathe+mill/drill machines? From what I understand getting the combo machines set up is a PIA and they require frequent readjustment. Is it even possible to hold .0005 facing, boring, ect, with one of these machines?
Do you have a budget limit you want to spend, also how much spare space do you have for the machine?
This will also help to answer what you need.
How often are you needing to replicate those tolerances as theres no point spending 10k on a machine to get those tolerances every so often, if you can do it on a 5k.
I don't know him or anything about him but I think ALOKIN is the biggest tool in his tool room
91 RS RA is offline   Reply With Quote
Old 06-22-2017, 09:46 AM   #27
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
Originally Posted by chris.trotter View Post
FWIW, I had a limited budget so was only able to get a South Bend 9", and a reaaallly old one at that (1922).
that sounds rad! gotta picture?
the oldest machine in my shop is a early 50's Pratt & Whitney knee mill. we still use it all the time!
Originally Posted by wingman358 View Post
Why do you need that tight of a tolerance? Sounds like poor design if you need it to be that tight.
Relax the tolerance spec and your manufacturing options are much more open.
totally agree!!! i'm more curious what metrology equipment everyone is using to honestly and accurately measure their 5 tenths.
Old 06-26-2017, 03:42 PM   #28
rtv900
Member#: 428511
2016 STI
^you'd be correct
any descent mic will measure single tenths, a cheapo china deluxe can measure 5
rtv900 is offline   Reply With Quote
Old 06-27-2017, 04:23 PM   #29
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
fur-shur, just derpin' on tenths. i have watched way too many "engineers" attempt to "measure" stuff with ZERO concept how to do so accurately.
