Welcome to the North American Subaru Impreza Owners Club Sunday December 16, 2018
Old 12-11-2017, 11:20 AM   #26
Crawford Performance
Member#: 42075
Originally Posted by lowbee View Post
Got the V3 installed in my GR finally and everything works like it is supposed to. Now, what are some good inspections (things) to do regularly to ensure the AOS is working properly ?
Our AOS is designed to install it and then enjoy the benefits without any need for inspections or maintenance of any kind.
If you would like to check periodically to give yourself peace of mind, then pulling off the hose from the top port in each chamber where it meets your engine and checking for oil build up is the best way.
QC
Crawford Performance is offline   Reply With Quote
Old 12-14-2017, 02:36 PM   #27
lowbee
Member#: 254317
2011 STi
So today the temperature drops to about 8F and after a 20 minutes drive and watching oil temp reaches 180F, I stopped the car, open the hood and just wanted to feel how warm or cool the V3 AOS is.
Well the AOS is not warm but it is not chill either, it feels to my bare hand to be about 60F. A litter cooler than I expected but I guess it is OK.
lowbee is online now   Reply With Quote
Old 12-14-2017, 04:37 PM   #28
Member#: 42075
Thanks for sharing this info and it's very good to hear!
Also keep in mind that our Dual chamber design has constant air flow through it so there is no condensation buildup inside of the system.
QC
Old 12-15-2017, 05:57 PM   #29
SLY_WRX
Member#: 398867
2013 WRB WRX HATCH
2008 Suzuki RMZ250
I wish I knew about this group buy!!
SLY_WRX is offline   Reply With Quote
Old 12-30-2017, 09:53 PM   #30
QCSMAX
Member#: 457809
2010 WRX
Ok so I got my Crawford V3 today and opened the box.... upon examination I notice the "mounting arm" has a slight bend to the right towards the bottom (the arm is not a flat piece of metal) and I am assuming that it is designed that way and the bend is not damage from shipping. Can anyone with a V3 or Crawford confirm that ?
Btw, what are the 2 (1 small, 1 big) plastic caps for ?
tried putting mine on today. I don't think mine is bent enough can't get it close enough to the injector cover to bolt it on...
QCSMAX is offline   Reply With Quote
Old 01-03-2018, 03:55 AM   #31
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
I'm still waiting on the V3 installation instructions for the 2008-2014 WRX. Will these be released any time soon?
xabre1200 is offline   Reply With Quote
Old 01-07-2018, 12:40 PM   #32
MC77wrx
Member#: 349972
2013 WRX
Tried installing on my Ď13 WRX and Iím running into fitment issues before I even get to running hoses. Has anyone successfully gotten this installed that can shed some light on the process that doesnít refer to the instructions from Crawford?
MC77wrx is offline   Reply With Quote
Old 01-11-2018, 03:13 AM   #33
xabre1200
Member#: 259591
2011 WRX sedan
WR Blue
Crawford are you going to ever release the install instructions you promised for the 08-14 WRX? You advertise your V3 AOS for this model car and then fail to provide any install instructions.
Old 01-11-2018, 02:10 PM   #34
Capital
Member#: 320493
1995 M3
Here's my V3 Install on an EJ255.
EJ255 Crawford V3 https://imgur.com/gallery/teuB0
Let me know what questions you have and I'll do my best to explain each picture. The one that threw me for a loop was the "to intake". This line was run to the white plastic part just above the PCV.
Capital is offline   Reply With Quote
Old 03-10-2018, 06:47 PM   #35
Skabs
Member#: 420796
2013 WRX hatch
Plasma Blue
I have questions.
To start, I looked at your photos and if "to intake" (port 3) goes to the white PCV connector, where does port 4 connect?
The Crawford "instructions" say to "white valve", and what you have port 3 connected to is the only "white valve" I can find.
Second, where is the 17" hose supposed to go? "Instructions" simply say FROM right valve cover vent hose extension, but doesn't say where it's supposed to connect TO.
Third, what is the 1/2' straight fitting for?
Skabs is offline   Reply With Quote
Old 03-17-2018, 06:17 PM   #36
danielsti
Member#: 483498
Default PCV delete ????
just checking to see if any body knows, can i delete the pcv valve completely and remove the in throttle body side
run a pipe from crank case to catch can inlet and have a return line back to turbo inlet
danielsti is offline   Reply With Quote
Old 04-13-2018, 01:25 PM   #37
tcoffin014
Member#: 173734
2007 STi
So what's going on with the V3 for the GD cars? Noticed they said something about the hood not clearing? Is that the only issue? Does it hit a spot that's easy enough to cut out some of the support to get it to fit?
tcoffin014 is offline   Reply With Quote
Old 04-13-2018, 06:13 PM   #38
Member#: 42075
The bracket comes with the bend.
When bolting up the bracket, the hardest part is lining up the bolt holes if they have shifted after removing the bolts. If you have someone around that can pull back on the cover, use a mirror to determine when the holes are lined up, have them hold it there, then re-insert/tighten the bolts.
Old 04-13-2018, 06:18 PM   #39
Member#: 42075
The V3 AOS will only work as intended it if it is installed per the instructions. The design utilizes the vacuum within the PCV system, so without it, it will not function properly.
Old 04-13-2018, 06:44 PM   #40
Member#: 42075
Hood clearance is the only issue. That being said, nothing can be trimmed on the car to make it fit. We are working on R&D for a new can for the GD's.
Our website newsletter is a great source for product info, sales, racing news, and new product releases. Sign up if you'd like to be kept up to date!
Old 04-14-2018, 10:46 AM   #41
Fndragn
Member#: 470845
04 Fxt
Wow I’m trying to decide what AOS to buy. The Crawford was on the top of the list. Not now!! I see they answered some of your guys questions but they failed to address the hard to answer ones like when will you provide the instructions with the $400 part you sold.
Fndragn is offline   Reply With Quote
Old 04-14-2018, 03:22 PM   #42
atreftz
Member#: 473988
2012 WRX Hatch
Dark Grey Metallic
Glad to see I'm not the only one having issues with MY08-14 WRX. Any updates on the install for the V3 yet? Don't mind taking her in to the guys at Fine Line, but would rather save that $$ for more parts..
atreftz is offline   Reply With Quote
Old 04-16-2018, 10:47 PM   #43
Member#: 42075
Originally Posted by Fndragn View Post
Wow Iím trying to decide what AOS to buy. The Crawford was on the top of the list. Not now!! I see they answered some of your guys questions but they failed to address the hard to answer ones like when will you provide the instructions with the $400 part you sold.
We have added a WRX specific amendment to the instructions while we wrap up the WRX specific install video.
In addition, this statement along with a port diagram is on the backside of all parts lists in each kit, which applies to either model:
1. The original Subaru hose from the crankcase vent to the intake manifold is removed, then the open port at the manifold is connected to Port 1 on the AOS, and the open port on the crankcase is connected to Port 2 on the AOS.
2. The original Subaru hose from the crankcase vent to the intake tube before the turbo is removed, then the open port at the intake tube is connected to Port 3 on the AOS, and the open port on the crankcase vent is connected to Port 4 on the AOS.
Any of our customers are welcome to email [email protected] for one-on-one assistance with their installs.
Old 04-16-2018, 10:52 PM   #44
Member#: 42075
See instructions here: https://cdn.shopify.com/s/files/1/11...22103953975123
The WRX specific video should be released in a few weeks.
Please email us at [email protected] for any further assistance in the meantime.
Old 04-20-2018, 12:25 AM   #45
Ljspeed
Member#: 467853
2018 STI
ISM
Will you guys ever make a v3 for FMIC? (S0699) Or offer for us current STI v3 owners a relocation kit? Almost all aftermarket FMIC kits have piping that goes thru the current AOS v3 mounting location.
Ljspeed is offline   Reply With Quote
Old 04-21-2018, 03:45 PM   #46
Member#: 42075
We will continue R&D for all vehicles and fitment options. Sign up for our newsletter on our website for product release updates.
We thank you for your patience as we perfect our kits before releasing them to the market!
Old 04-22-2018, 02:38 AM   #47
DrickyBobby
Member#: 472925
How many people have had hood fitment issues so far?? Not looking forward to putting this in going “ohhh nice 500$ doesn’t fit anymore....”
DrickyBobby is offline   Reply With Quote
Old 04-22-2018, 11:58 PM   #48
Member#: 42075
The mounting bracket on the S0699 is location specific, so it cannot be relocated. Upon proof of purchase of the TMIC kit, we can offer an upgrade discount for those who would like to purchase the FMIC kit when released.
We have only come across one instance of a hood clearance issue, from a customer who had some sort of aftermarket spacers that raised his intake manifold higher than stock.
The question from tcoffin014 was in regards to retrofitting our current kit that is meant for a 2008+ STi/2008-2014 WRX vs. the older 2007 models. Only reason it cannot fit is because of the hood height, and the kit is not advertised for those cars. 2002-2007 WRX and STI's will get their own kit, currently in R&D.
As a tip, the kit is only $337 on Rallysportdirect.com
Last edited by Crawford Performance; 04-23-2018 at 12:05 AM. Reason: Forgot detail
Old 04-27-2018, 05:31 PM   #49
keiksmt
Member#: 295243
2011 WRX 5 door
Gun Metal Gray
Yoohoo finally some update on thread...
This is where it got me and confusing area with WRX(2011). I think i am done it right way the only time I got feedback from, but it was not easy as just written. I can't wait to see the Video update on this.
"Open port on the crankcase vent" is "f" shape split come out and connect to white sensor piece correct? That with 5"x1/2" hose will not reach. so I had to remove that zigzag shape hose from intake (under manifold which is really hard to get into) and basically extend out to port4.
Anyway, after couple of month driving, I started to see the "oil smear" on Duct (right after intercooler). So I took out intercooler, and of course there are oil(Blowby) inside duct.
Cleaned off duct, outside and inside, re-checked all the tubing by AOS etc...
Couple days after, I already start seeing "Smear" look on the same area.
I am hoping it just some left overs oils in the system is recirculated to cause those. (I did clean most of the area in initial but.... there is not really a way to check if AOS is really cacthing the oil and sending it back.
I am guess quick check will be Port #1 and #3 should be completely dry, when #2 and #4 can be bit wet.... is my understanding correct?
Oh and even stock WRX does rub on the Hood insulation pad, but that doesn't count right? ha
keiksmt is offline   Reply With Quote
Old 04-30-2018, 09:46 PM   #50
keiksmt
Member#: 295243
2011 WRX 5 door
Gun Metal Gray
