Welcome to the North American Subaru Impreza Owners Club Monday December 17, 2018
Old 09-13-2006, 03:08 PM   #1
Bala
Member#: 112510
2006 WRX, Black
Default Please help me decide on what fuel injectors and pump to get? Please help.
Hi,
I have a 2006 WRX and i also have a brand new Dead Bolt Big EVO III 16g. I will eventually go with this turbo setup in the near future and I need your help to decide what fuel injectors and pump to get.
I would like a set of injectors that will allow me to get maximum power from my 16g, same goes for the fuel pump, donít want something over kill and expensive though, I need just enough flow to handle my 16g on its limits.
Please help and advise me.
Thank you, Bala
Bala is offline   Reply With Quote
Old 09-13-2006, 03:13 PM   #2
Yoo Shin
Member#: 87327
2017 Heron White SS
I still kill threads
Going for that nasty quick spool ey.
Your 16G compares pretty close to an 18G, and you'll hear both from folks that run stock injectors (though almost maxed) and do fine and folks that bump them up to something like 750s. I'd go w/ some 750s or something in that range just to be safe, plus if you ever want to go w/ a bigger turbo, you'll be better prepared.
Search on "18G" and "injectors" and see what you get.
Yoo Shin is offline   Reply With Quote
Old 09-13-2006, 05:46 PM   #3
Bala
Member#: 112510
2006 WRX, Black
Please give me some more advises
Old 09-13-2006, 06:36 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
for the pump just run what everyone else does - a walbro 255.
for the injectors you have TONS of choices. Personally, we've been very happy with the modded and flowmatched ones that Andrew, Russ, and Phil over at gearbox tech have been doing.
Old 09-14-2006, 01:24 AM   #5
taerron
Member#: 75744
2k2 low boostin
evo3, for now....
the evo III 16g may be too small for the 2.5l. you might want to consider something a little bigger
taerron is offline   Reply With Quote
Old 09-14-2006, 01:33 AM   #6
affinity1
Member#: 97266
'15 Forester 2.5i
Touring DGM
get the deutsch (sp?) injectors
i hear good things
affinity1 is offline   Reply With Quote
Old 09-14-2006, 01:47 AM   #7
kx02wr
Member#: 59112
02 wrx
+1 for modded stockers. Your 06 injectors are already 550's so you might be able to get away, but I would upgrade. The 16g will not be too small for the 2.5. Stock turbo is ALOT smaller. The 2.5L 16g setup will make for a killer autox machine. I am in the same boat, and debating the 16g super 16 over an 18g.
kx02wr is offline   Reply With Quote
Help me decide on an exhaust setup and tune. fiveightandten Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-21-2009 11:32 AM
Help me decide on wich EM to get. ( Hydra, AEM, Power FC, Autronic) AXA Other Engine Management 7 04-01-2006 04:38 AM
Help me decide on what to get 03mbpREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-10-2005 05:06 PM
Help me decide on which rims to get mykrrrr Interior & Exterior Modification 7 03-04-2003 03:36 AM
help me decide on exhaust please!!! S-WRX Normally Aspirated Powertrain 4 10-29-2001 06:58 PM
