Welcome to the North American Subaru Impreza Owners Club Wednesday September 26, 2018
Old 12-12-2017, 03:13 PM   #1126
Josh[ua]
Member#: 140189
2007 STI Limited
Satin White Pearl
Originally Posted by JonnyV2889 View Post
Since you disconnected the battery the ecu should've reset. You should be good to go providing you replaced any faulty parts. It's not a question of will it happen again in the future, but when.
3 years later... it happened again... right before i had to renew my registration and smog it too... fuhhh
Josh[ua] is offline   Reply With Quote
Old 12-13-2017, 10:25 AM   #1127
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
that sucks - I'm glad I didn't replace mine.
1 Lucky Texan is offline   Reply With Quote
Old 12-15-2017, 07:48 PM   #1128
chenchar
Member#: 424938
Unhappy 07 sti over boost
so i figured out that the car was in a fail safe mode when the barometric sensor wasnt plugged in, and i would not hit targeted boost. NOW with it in, I over boost and i overboost badly. The car is an 07 sti, the codes are not deleted but with the sensor plugged in there arent any codes. my question is on the valve unit, do you have to block off or plug anything? or just leave the valve ports exposed? other than the airpump idk what could be causing my over boost issue. ive replaced my bcs and my pill already
chenchar is offline   Reply With Quote
Old 12-19-2017, 08:58 AM   #1129
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
You should check the diameter of the hole in the pill.
The pill, and the diameter of the hole in it, are specific to the VF43. Make sure the vacuum line you got with the pill is really meant for a VF43; if it's a pill for a VF39/VF48/TD04 then boost will definitely be off. This pill business can be tricky, unfortunately.
Also, double check your wastegate actuator with something like a Mityvac pressure/vacuum pump; it should push the exhaust turbine flapper door wide open at around 7~8 psi or so. If that's not the case, then something is wrong with the actuator itself or something is preventing the flapper door from opening properly.
neg_matnik is offline   Reply With Quote
Old 02-11-2018, 02:42 AM   #1130
chenchar
Member#: 424938
So I realized the codes turned on and the car is always in a failsafe mode now. although I know i will need these codes to be deleted, and have the car tuned anyways (stage 2 tune), On my accessport, the baro pressure (psi) fluctuates between 11.89 psi up to 12.04 psi. I have the sensor cut out from the actual valve itself. i was curious if there was a certain way to cut it out or if my sensor is just bad in general. I heard that the baro sensor should read very close to 14.7 psi. thanks guys!
Old 03-01-2018, 07:02 PM   #1131
SirRichieLee
Member#: 331655
2006 WRX Wagon
Crystal Gray Metallic
After reading thru a lot of this I saw that the pump exploding isn't a common thing.
Edit: I was going to post a picture of it but it says I don't have permission to post attachments.
SirRichieLee is offline   Reply With Quote
Old 09-09-2018, 03:28 PM   #1132
Josh[ua]
Member#: 140189
2007 STI Limited
Satin White Pearl
5 years later it has happened again... well... happened 2 years ago, i just havent gotten around to changing it till now.. lol
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 03-10-2018 03:40 AM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
