Welcome to the North American Subaru Impreza Owners Club Saturday December 15, 2018
Old 04-10-2007, 04:29 AM   #1
al3xgonz
Member#: 124214
06 WRX TR
Default Help: Installed HID on 06 fogs and dont turn on!
Had oem fogs on my 06 wrx and decided to install my h3 hid kit that was sitting in my room. All wires hook up right. I do not hear the ballast at all so i think that it is not getting enough power. Do i need to install some relays in order for this to work? If someone knows plz let me know i want them to work.
al3xgonz is offline   Reply With Quote
Old 04-10-2007, 11:39 AM   #2
Drowner
Member#: 49297
17 WRX Limited
Is this a kit? I would assume not since you dont have relays. How did you power the ballasts?
Drowner is offline   Reply With Quote
Old 04-10-2007, 02:48 PM   #3
al3xgonz
Member#: 124214
06 WRX TR
i used the existing connector from the rear covers from the fog lights, what i did to them was that i cut them out so that i wouldnt have to cut the actual factory fog light harness/plug and use connectors. it is an hid kit. All fuses have been checked from the engine bay and the bottom of the driverside dash and none are out.
Old 04-10-2007, 04:26 PM   #4
TxWrX
Member#: 108276
2014 WRX Limited
If you get this to work... PICS.
TxWrX is offline   Reply With Quote
Old 04-10-2007, 06:52 PM   #5
al3xgonz
Member#: 124214
06 WRX TR
for sure ill post some pics.
Old 04-11-2007, 12:43 AM   #6
al3xgonz
Member#: 124214
06 WRX TR
What can be the problem?
Old 04-11-2007, 01:32 AM   #7
4sevens
Member#: 142808
If you don't need your stock fogs let me know.
my driver's side is cracked
4sevens is offline   Reply With Quote
Reverse lights dont turn on MJBrowny21 Transmission (AT/MT) & Driveline 6 03-22-2010 06:25 PM
cruise control lights dont turn on. scoobynoobEMT Electrical & Lighting 4 02-04-2010 11:58 AM
'06 WRX foglights added but dont turn on RBelcher00 Electrical & Lighting 4 02-08-2006 11:20 PM
Reverse Lights Dont Turn On - Help michyous Legacy Forum 5 04-16-2005 11:54 PM
Help! Fog lights won't turn on after HID install aspenwhitewrx Electrical & Lighting 17 03-30-2004 02:48 AM
