Welcome to the North American Subaru Impreza Owners Club Saturday January 19, 2019
Old 02-16-2017, 01:30 AM   #1
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
Default Rear chassis strut triangulation brace - GD chassis - bolt in
Anyone interested in a bolt-in rear chassis brace for their GD chassis? I only made 1 model to test in my car and it works wonderfully. If anyone is interested I will need to spend some time fabbing up some jigs to cut and weld the parts. I'm not a pro welder and MIG it in my garage. The welds may not be 100% perfect and pretty but are fully functional for the stress that this rig sees.
My first model is using 1.5" OD 0.120" thick wall DOM steel tubing but the thickness is overkill so I plan on sourcing thinner stock for future builds.
The downside is the need to drill through the inner trunk sides and floor to bolt it in. I plan on supplying rubber washers on the outside of bolt mounts to inhibit water and the elements getting into the car. The bottom plate mount is setup to drill and mount via 3 bolts where 2 panels are spot welded, so it mounts into a double thick area that will provide enough support.
I did set up a test to see how much stiffening it provides by mounting a bar to the top seat chassis area to the floor. I tested the chassis flex by jacking 1 corner of the car up at a time, in the rear from under the tire to mimic force coming from the tire through the suspension only. The original flex was about 1/4" and with the support installed decreased to 1/8". I know that doesn't sound like a lot but for chassis flex in the area that the test bar is mounted that sounds like a lot to me and is likely more from the top to the bottom of the car. Photos of that are on my facebook page in the link below.
I know shipping won't be cheap but I can figure that out if anyone is interested. The cost of the raw steel is not that much and I wouldn't charge an arm and a leg to fab it. At the moment I do not have a plan for paint/powdercoat but can get to that in the future if enough people are interested.
I have stiff coilovers, 25mm sway bars, rear subframe lockout bolts, and GroupN rear suspension bushings installed so everything in the rear was ready for this. The rear of my car is very stiff and highly predictable. I autocross and ran a track day with this installed and the car feels like a go cart, with every turn highly predictable with nearly no flex or play in the rear.
https://www.facebook.com/pg/Stiff-Fa...34524586858784
I'm located in Longmont, Colorado. Anyone local is more than welcome to contact to meet up to check it out.
rideAC1 is offline   Reply With Quote
Old 02-17-2017, 02:03 PM   #2
danscomp
Member#: 305358
I really hope you have mount plates underneath or you're going to tear the sheet metal...
Also I didn't quite understand where you measured 1/4" of deflection. Can you take a photo please?
danscomp is offline   Reply With Quote
Old 02-17-2017, 02:36 PM   #3
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
I did not mount plates on the other side of the mounting plates, other than washers. I used 4 bolts on each of the side plates. I do however plan to remove the brace to make a jig for further builds and I will see if any of the holes got ovalized because of that.
The support can ideally be welded in but without stripping out the interior and oem undercoating I didn't want to chance causing any fires, especially on the bottom near the gas tank.
I have to compile the photos of the measuring device to show the flex and changes with-without the brace and post some day soon. Here is how I mounted a bar to the seat top area and a ruler to the floor area to measure the flex between the two.
Old 04-13-2017, 02:14 AM   #4
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
Bump. Any interest? Any constructive criticism? I know the brace would optimally be welded in but unless your chassis is stripped that's difficult and unsafe to do.
I found a noticeable improvement and for the low cost it's a nice upgrade.
Old 04-14-2017, 07:34 PM   #5
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
Oswald and TIC have really good ones that require no sheet metal damage or hole drilling. I have the Oswald and it's well worth the entry fee.
Hoon Goon is offline   Reply With Quote
Old 04-16-2017, 02:15 AM   #6
binny
Member#: 198108
MY98 WRX
Originally Posted by rideAC1 View Post
Bump. Any constructive criticism? .
Get a vendor account before you get banned?? (Unless you have one already?)
binny is offline   Reply With Quote
Old 04-17-2017, 01:23 AM   #7
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
I do not have one but also do not yet consider myself a vendor. Thanks for the heads up!
Old 04-17-2017, 01:23 AM   #8
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
Thanks for the input.
Old 04-18-2017, 04:17 PM   #9
kaos200
Member#: 2692
Pretty cool.
If you made something for the GC/GF chassis you may have less competition.
Then again who said competition is a bad thing. Plenty of cars out there.
kaos200 is offline   Reply With Quote
Old 09-06-2017, 02:21 AM   #10
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
bump!
Old 09-06-2017, 11:51 PM   #11
Monkey king
Member#: 209401
2005 Sti
How much are you selling these for?
Monkey king is offline   Reply With Quote
Old 09-08-2017, 02:13 AM   #12
rideAC1
Member#: 210441
2002 WRX 6MT RA-ish
$100 + shipping, including the hardware to mount. Makes a nice difference. No issues with my install and I even ran an autocross, a track day, and took it on a spirited drive up Pikes Peak.
