Welcome to the North American Subaru Impreza Owners Club Wednesday January 23, 2019
Old 09-16-2017, 04:43 PM   #1
unekmikesti
Member#: 414765
2005 WRX STI
Default Stainless Steel oil restrictor help
Hi sooo I have a huge problem, while installing my oilfeed line into the turbo somehow it became stripped... So the hole in the turbo is toast and I see no way of tapping it and iv heard a lot of bad things about helicoils so my preferred option is to just weld that sucker on there but I can't seem to find a Stainless Steel oil restrictor fitting anywhere
The turbo is a blouch dom 3.0 with a gt28/30/35r chra and I have no idea what restrictor size I need. 0.040?? I just know that the fitting is -4 AN that screws into the actual oil line
Anybody that can help, please do I'm out of ideas at this point
unekmikesti is offline   Reply With Quote
Old 09-16-2017, 05:38 PM   #2
n2oiroc
Member#: 141952
18 golf arrrr!
use a timesert, they are better than helicoils and the best repair for your problem.
http://www.timesert.com/
n2oiroc is offline   Reply With Quote
Old 09-19-2017, 02:24 PM   #3
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Problem is unekmikesti apparently doesn't want to use the drill and tap method due to metal shavings going into the turbo (?).
Call Blouch and ask them what you need. They have been pretty good in the past with over the phone service
Samurai Jack is offline   Reply With Quote
Old 09-21-2017, 04:24 PM   #4
rtv900
Member#: 428511
2016 STI
if it's just a restrictor why not just get a stainless plug and drill it, then weld it if you want
rtv900 is offline   Reply With Quote
