Welcome to the North American Subaru Impreza Owners Club Friday January 19, 2018
Old 12-09-2017, 07:00 PM   #1
vwvt
Member#: 439926
Default 11-14 WRX Bolt Identification
Ok, so been searching and canít find an answer. Looking for specific bolts for timing belt tensioner bracket. I got my car back in a box now the long haul to rebuild. Never done this before😬🙏🏼🖖🏻 Anyone out there that can take a pic or help me figure out which three bolts I need would be really great!! Iím sure Iíll have 100 more questions🤦 Thank you, Mat
https://ibb.co/eSBN0G
vwvt is offline   Reply With Quote
Old 12-10-2017, 12:14 AM   #2
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid Swapped WRB
parts.subaru.com
Have fun
Valarius Starchaser is offline   Reply With Quote
Old 12-14-2017, 07:44 PM   #3
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
That or opposedforces.com
Hoon Goon is offline   Reply With Quote
Old 12-16-2017, 04:57 PM   #4
vwvt
Member#: 439926
Originally Posted by Valarius Starchaser View Post
parts.subaru.com
Have fun
Yeah, been there. 😊
Finding the correct bolts seems to be the most time consuming part of rebuilding this motor. Itís more of a challenge than thought it would be. My local Subaru dealer doesnít have any of the bolts in stock to look at. Iíll figure it all out but geez not so simple.
Old 12-16-2017, 05:30 PM   #5
bp05obxt
Member#: 459799
Part numbers
800708460 need 2 of these
808208380 need 1 of these
This can been seen under model (2014 wrx) category (engine and cooling) and sub category (camshaft & timing belt. Timing) on parts.subaru.com
It would be in your best interest to learn how to navigate and search for parts on there for yourself. It will save you time in the long run and you wonít have to rely on someoneís reply here..
bp05obxt is offline   Reply With Quote
Old 12-16-2017, 05:32 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Cool
Originally Posted by vwvt View Post
Yeah, been there. 😊
As an "engineer", figure 2 bolt diameters into soft metal (like aluminum). The better the grade (none, vs. 4 vs. 6 etc) the higher the torque.
Lots of Subaru is 8.8 or better.
Most of what you need for simple stuff is available locally, just the diameter and pitch correct and then go for equal or better grade.
Not too hard if you know what it all means.
Old 12-17-2017, 10:36 AM   #7
vwvt
Member#: 439926
Originally Posted by bp05obxt View Post
Part numbers
Yeah! Not sure why I didnít find that site. I was on various other Subaru sites all of which didnít seem to show any bolts, thought that was odd. Parts.subaru.com is most definitely the only one to visit. I have located all the numbers I need with images🙏🏼. Now I can get this saga completed.
Thanks for the push in the right direction.
Old 12-30-2017, 11:24 PM   #8
vwvt
Member#: 439926
Default Air pump bracket bolts??
Anyone know if there is a shoulder bolt for the black cast iron air pump bracket? Iím down to minimal bolts as I get this motor back in and seem to be missing all the right bolts. Please note I didnít take this car apart. It looks like the hole in the bracket is a bit wider than the threads in the block.
Old 12-30-2017, 11:26 PM   #9
vwvt
Member#: 439926
I have been looking everywhere for an image or video but canít find anything except an image of the bracket, no bolts.
Thanks
Old 12-31-2017, 12:24 AM   #10
Valarius Starchaser
Member#: 459312
2004 WRX Wagon
Hybrid Swapped WRB
Just get another bolt from a hardware store itís not like itís holding anything takeing side load or supper critical
Just get a flange headed bolt grade 8.8 or 10.9 if your really anal about this pitch M8x1.50 or whatever it is take a bolt out and test if it threads by hand then go to the store with that to make sure you canít muck it up
it shouldnít be this hard I found identical matches neigh for the finish at my local ace hardware
