Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 12-12-2017, 05:19 AM   #1
dankap99
Member#: 471361
Default 2005 Legacy GT Transmission Options
My '05 LGT's transmission has developed an issue where it will grind like there'e a pebble in it in 1st-4th, then in 5th it sounds like there's a handful of gravel in it. My assumption is that it't totally shot, but I'm gonna have a local shop confirm that this week.
In the mean time, assuming I need to replace it, I'd rather use a 6 speed from an STI rather than another 5 speed, if possible. I'm hoping that the dimensions would be nearly identical between the carious models, given that so many Subi motors use at least the same shaped short blocks and motor mounts.
I've already done a short block swap, stage 1 tune, and new wheels, not to mention that I love the car, so selling isn't an option.
Can anyone confirm that an STI 6 speed (US or JDM) would fit in my LGT?
dankap99 is offline   Reply With Quote
Old 12-12-2017, 09:56 AM   #2
relative4
Member#: 203132
2005 LGT 5MT Stg2
Yes, but you'll need to consider final drive ratios and various small parts. Full info here:
http://legacygt.com/forums/showthrea...ad-107137.html
http://legacygt.com/forums/showthrea...es-229267.html
relative4 is offline   Reply With Quote
Old 12-12-2017, 07:46 PM   #3
Max Capacity
Member#: 149347
05 LGT,09 SpecB
Black/silver
Join that forum, you'll get lot's more help there for your car.
See Ya,
Max Capacity is offline   Reply With Quote
