I'm looking for someone to unbrick my JDM V7 STI ECU. I had an issue during reflash on ECU Flash 37% through the Flash I got a window to pop up and say that there was an error and not to shut my ignition off. It told me to retry The Flash the same thing happened for about 10 minutes and then finally it successfully flashed. I turned my ignition off and when I went to start the car I had no injector pulse or Spark. I spent 3 hours trying to figure out the problem, until I plugged in a WRX ECU and the car fired right up. It only stayed running for a couple seconds though because I have installed id1000 injectors and the WRX ECU was still on a stock map thank you for your help in advance. I will pay shipping both ways and pay for the service.
