Welcome to the North American Subaru Impreza Owners Club Saturday February 24, 2018
Mid Atlantic Impreza Club
Old 06-04-2010, 09:55 AM   #1
bluesbrother
Member#: 209724
2005 WRX
Unhappy Help!
Alright so I took off my tmic to install a gauge (which was broken anyways) and now as I'm trying to put it back on the Y-Pipe won't reconnect to the turbo inlet.
Is there a special way of putting it back on?
Or am I just a tard?
Flame Suit on.
bluesbrother is offline   Reply With Quote
Old 06-04-2010, 10:13 AM   #2
ArkansasDave
Member#: 234363
2015 Katie Em 250 XC
Dirty bike
try lube? thats my only suggestion
ArkansasDave is offline   Reply With Quote
Old 06-04-2010, 10:18 AM   #3
silverwerx
Member#: 81246
. .13 EVO X MR
.03 Cosworth Wrx, 14 Jeep
lube and luck stick with it
silverwerx is offline   Reply With Quote
Old 06-04-2010, 10:22 AM   #4
bluesbrother
Member#: 209724
2005 WRX
Alright thanks guys. Why do they have always have to make these things huge pita's? haha
Old 06-04-2010, 10:30 AM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I assume this is a stock TMIC with the stock hoses? If so, there should be a sort of tab on the inlet hose that you can grab and pull the hose on. Or get some in there that you can get against that tab to help pry it on. Good luck.
Old 06-04-2010, 10:35 AM   #6
iraj
Member#: 164256
Dont use lube; just pull the tmic towards the left side of the engine bay from underneath and ur gonna have to hold it there and tighten the clamp on the turbo inlet at the same time...itll take some power, if u got a helping hand u can pull it on there while the other person tightens it on the turbo
iraj is offline   Reply With Quote
Old 06-04-2010, 10:48 AM   #7
bluesbrother
Member#: 209724
2005 WRX
Success!!!!
Thanks guys...I used a little lube, but I didn't see that tab until you guys mentioned it.
Thanks for helping with my stupidity! haha
Old 06-04-2010, 11:45 AM   #8
steverx05
Member#: 128269
On my old 05 I always used to use a real long socket extension to stick down against the block and help push the y-pipe back on using that tab and the leverage from the extension. It was always a pain but after you do it a couple times it becomes second nature.
steverx05 is offline   Reply With Quote
Old 06-08-2010, 01:10 AM   #9
bulshavix6
Member#: 193367
2005 lgt limited
abp?
you put that one on first and then put the big one on up top be glad its not an sti or bigger they are a lot harder than a wrx one. i never had that much luck trying to pry that one on when you have the bigger hose on. i've taken my ic on and off and the sti one like 50x i really want to go to a fmic but that will prob suck too bec you would have to take giant pipes off but at least you could check trans fluid.
bulshavix6 is offline   Reply With Quote
