Welcome to the North American Subaru Impreza Owners Club Wednesday May 23, 2018
Old 06-17-2017, 05:34 PM   #1
HoneyChamp
Member#: 463155
2002 WRX Wagon
Midnight Black Pearl
Default Kartboy Short Shifter Help
SO I just picked up a kartboy short throw shifter for my 02 wrx wagon from a guy parting his car out. The problem is it was the narrow barrel model but I have the wide linkage in my car. He was nice enough to throw in the linkage with the linkage to fit the narrow barrel shifter.
My question is would it be possible for me to just install the narrow shifter with some washers or rubber spacers of sort to fit my existing linkage? If so what is the size difference between the narrow and wide.
HoneyChamp is offline   Reply With Quote
Old 06-17-2017, 05:51 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Best to do it the right way, either install the linkage that is compatible with the shifter you bought, or sell that one and purchase the one that fits. Not a good idea to try and rig something up.
Old 06-17-2017, 06:08 PM   #3
HoneyChamp
Member#: 463155
2002 WRX Wagon
That's what I was thinking but I wasn't sure if it was a waste of time or not. Thanks for your input
Old 06-17-2017, 06:26 PM   #4
[email protected]
Member#: 67
1999 Outlasting
the competition.
Best way is like mulder said, if not. you can try and find some nylon or teflon washers to take up the gap if you are short on coin.
tom@kartboy is offline   Reply With Quote
Old 06-17-2017, 06:32 PM   #5
HoneyChamp
Member#: 463155
2002 WRX Wagon
Thank you Tom. I will just replace the whole linkage since I already have it. Would you suggest buying the new bushings for when I do?
Old 06-17-2017, 06:44 PM   #6
[email protected]
Member#: 67
1999 Outlasting
the competition.
I would, you're already there. Might want to look at the super whammy jammy kit from Turn in Concepts. they have our bushings along with some pivot bushings. it'll make it better than new.
Old 06-17-2017, 06:53 PM   #7
HoneyChamp
Member#: 463155
2002 WRX Wagon
I'll have to look into that. There is a lot of side to side wobble room in my shifter while in gear and that's why I'm looking to upgrade it.
Old 06-17-2017, 07:47 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
How much side play are we talking about? If it's something like an inch or more, the main problem may not be at the shifter but rather the u-joint at the transmission. In that case you'll be needing one of these-
http://turninconcepts.com/driveline/...ge-update.html
They have complete bushing kits that also include that linkage so you can just do everything at once. Be sure to get the right version (wide or narrow) depending on which setup you end up keeping.
Old 06-19-2017, 06:33 PM   #9
HoneyChamp
Member#: 463155
2002 WRX Wagon
It's pretty bad, probably an inch or two. That's probably what I really need. I'll order that/the bushings and do the whole shifter assembly at once since I wanted a short throw anyway. I was told the bushings would help with the slop but that's probably just up/down and not the wobble. I will definitely get one of those too. Is that better than the oem one? I just googled that part and the OEM is about half the price
Old 06-19-2017, 07:15 PM   #10
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yes the TIC linkage replacement is an upgrade from the factory part. It's explained in the description on their website.
Old 06-20-2017, 01:01 PM   #11
HoneyChamp
Member#: 463155
2002 WRX Wagon
I read it wrong initially. I thought it was saying it's an upgrade over your old worn out linkage. Thanks for all of your help Mulder. I'm still fairly new to the wrx life (maybe 9 months). My 99 OBS was a bit less complicated when purchasing parts
