Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 05-23-2004, 04:15 PM   #1
cm1wrx
Member#: 33413
03 WRX
Default Help! Need pics of factory boost solenoid lines
Could someone please post pics of their factory boost solenoid set up. I'm removing my Blitz dual solenoid EBC and I cant remember how to return it to stock. ( I should be getting my accessport soon and I want to be prepared (note: ordered it on March 24, still not have not heard from them). I took off all the lines and capped everything so I will need pics of the lines to the solenoid as well as the lines to the turbo and turbo inlet pipe. I'm pretty sure I know how everything hooks up to the turbo but I dont know which line goes on top of the solenoid and which goes on the bottom. I already did a search and came up with only picks of the lines to the turbo. Any help would be appreciated. Thanks
Chris
cm1wrx is offline   Reply With Quote
Old 05-23-2004, 06:31 PM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
check Oakos' site, they have the how-to pics for their MBC, and they show the stock lines pretty well. heres the link
http://www.oakos.com/wrx/installs/OAMBC/index.htm
Chris N is offline   Reply With Quote
Old 05-24-2004, 02:28 AM   #3
cm1wrx
Member#: 33413
03 WRX
thanks Chris N but I still cannot see what lines go where. the pics aren't clear enough. Does anyone have pics of their stock set up? I would really appreciate it.
Old 05-24-2004, 03:43 AM   #4
clsmooth71
Member#: 15552
'87 Hutch TRICKSTAR
babyblue on pinkTuff II's
bump
I'd like to see these pics too!!
clsmooth71 is offline   Reply With Quote
Old 05-24-2004, 04:48 AM   #5
clutchcargo
Member#: 58881
05 Impreza STi
Hey guys, I just did an apexi AVCR install How-to, you should be able to follow it in reverse Note this is an Australian Spec WRX (driver side is passenger side!!!) but should make no difference for your purposes.
http://forum.wrx.com.au/topic.asp?TOPIC_ID=6926
Note the hose that tees off to the actuator/turbo runs to the solenoid nipple pointing DOWN, whereas the hose running from the intake pipe runs to the solenoid nipple pointing right (if facing the engine).
I hope this helps.
clutchcargo is offline   Reply With Quote
Old 05-28-2004, 03:17 PM   #6
cm1wrx
Member#: 33413
03 WRX
Thanks clutchcargo! Your note at the bottom really helped. I should be able to take care of everything from here. Thanks again!
Chris
Old 05-28-2004, 05:57 PM   #7
clsmooth71
Member#: 15552
'87 Hutch TRICKSTAR
yeah, thanks for the pics, clutchcargo!!
Help intall 02 wrx factory boost solenoid prlblkwrx02 Normally Aspirated Powertrain 2 02-25-2006 06:26 AM
Looking for a Pic of Factory boost solenoid lines tsquare Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-13-2005 11:40 PM
Need pics of factory speakers and tweeters. cwcaudio Car Audio, Video & Security 3 06-28-2003 03:22 AM
HELP! Need pics of the rear of Subaru Casablanca. Stickee General Community 11 01-20-2002 03:52 PM
HELP! Need pics of Oz P1s or Superleggeras on Silverthorn Rs's JaiMak Interior & Exterior Modification 3 04-05-2001 04:16 PM
