03-12-2013, 05:14 PM | #126 |
Member#: 292364
Vehicle:2011 WRX ISM |
Car is going back in the garage for a week..when i get back from Texas I'm gonna pull the drivers side valve cover and see what the hell is goin on
03-12-2013, 10:00 PM | #127 |
Member#: 175898
South East
Vehicle:2002 Impreza WRB |
I have been following this thread for a while because my built long block ticks but my tuner assures me it is noisy injectors. I double checked the lash on the heads because it has cams but everything is within spec, will contine to beat on it until it blows and let you know if tuner is correct, 5k miles on it so far and no problems.
03-12-2013, 10:05 PM | #128 |
Member#: 292364
I took it to a Subaru tech and had him listen and he told me to double check the valve lash on the cyl 2 exhaust valves
03-14-2013, 05:23 PM | #129 |
Member#: 171471
SWIC
Vehicle:2002 35r wrx Silver |
Here is what i have had in the past with subaru dealer ships installing the intake cam gears wrong. The came gear is not fully on the cam pin. So what ends up happening is, the cam gear cannot spin the cam all the way over causing a slapping sound. Take the cam gear off on that side and make sure its in the right spot.
03-14-2013, 06:00 PM | #130 |
Member#: 261447
NWIC
Vehicle:2004 Impreza WRX WRB |
^ If his cam wasn't rotating all the way, then he would be bending valves/ hearing all kinds of bad news.
Also I think he said earlier that he had re-assembled the motor, so i doubt improper cam gear assembly. OP did you check rod bearings while the motor was out? Its possible that when your wrist pin went out, it was putting added stress on the bearings. |
03-14-2013, 06:06 PM | #131 | |
Member#: 292364
03-15-2013, 10:47 AM | #132 |
Member#: 171471
SWIC
You would think that it would bend the valves but it doesn't. the cam never spins over allowing the valves to open. That is not rod knock. far from from it. Check your cam gear. it does not matter that he has taken it apart if the pin hole is messed up, it will allow the cam gear to slip. Put a scope on it and listen to where the noise is coming from.
This video is rod knock . https://www.youtube.com/watch?v=sik-OddhWzo |
03-15-2013, 11:38 AM | #133 |
Member#: 182375
SWIC
Vehicle:2013 Sti World Rally Blue |
If the valves don't open then it runs on 2 cylinders which would be obvious immediately.
03-15-2013, 12:24 PM | #134 | |
Member#: 292364
03-20-2013, 12:28 AM | #135 |
Member#: 292364
Valve lash on the drivers side head is all in spec except cyl 4 intake valves which measured at .010-.011 where all the others were about .006-.008. Is this really enough to cause the noise I am hearing?
03-20-2013, 12:14 PM | #136 |
Member#: 190729
NWIC
10 intake and 11 exhaust WILL cause lots of noise.
03-20-2013, 02:47 PM | #137 |
Member#: 292364
03-20-2013, 03:06 PM | #138 |
Member#: 190729
NWIC
The bigger the cam and the faster the ramp rates the more noise it will make.
03-21-2013, 10:14 PM | #139 |
Member#: 292364
So if I were to say that my valve lash wasn't the problem what would be the next thing to look into?
03-21-2013, 10:17 PM | #140 |
Member#: 292364
I'm wondering if I have a problem with a valve spring or retainer. There's just nothing else left to be bad lol
03-21-2013, 10:23 PM | #141 |
Member#: 170602
Vehicle:06 Wrx RWD Auto 76MM-AEM-2200's |
Seems like you'd notice a retainer issue though when you reassembled
03-21-2013, 10:26 PM | #142 |
Member#: 292364
I didn't pull the valves out though. Also have been reading tons of issues with weak Brian crower valve springs
03-21-2013, 10:29 PM | #143 |
Member#: 170602
Hmm good point. Maybe that's something you could try if/when you get back in there. Disassemble head and check everything. Maybe aspiring is weak or broken or retainer binding up
04-02-2013, 07:47 PM | #144 |
Member#: 251524
NESIC
Vehicle:2005 Sti Psm |
Any updates? I have bc cams and springs and I am also experiencing some of these issues as well.
04-02-2013, 08:06 PM | #145 |
Member#: 292364
04-23-2013, 04:05 PM | #146 |
Member#: 292364
No cracked retainers, valve springs look ok. One weird thing however is on all of the exhaust valves the valve locks seemed to be stuck in the retainers and I had to hit the retainers fairly hard to get the locks to pop out. I'm about to just order all new springs and retainers and replace all of the buckets.
04-24-2013, 12:14 AM | #147 |
Member#: 256810
NWIC
Make sure the heads are torqued to the block when you measure and adjust the valves. Otherwise they can be adjusted out of spec.
04-24-2013, 02:16 AM | #148 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Check your AVCS values in RomRaider or whatever logger you use. If the values are off between left and right you could have an AVCS gear or solenoid issue.
04-24-2013, 02:35 AM | #149 |
Member#: 292364
Thanks for the idea, thought about that and checked them in my aem and they were fine. Also swapped solenoids between heads and nothing changed
04-24-2013, 09:10 PM | #150 |
Member#: 292364
I'm going to take the drivers side avcs gear apart tmr when I get to work and see if its possibly sludged up. I did have a bearing failure on my old engine and ended up reusing these cam gears without cleaning them
