10-18-2009, 11:34 PM | #1 |
Member#: 123564
Vehicle:2001 Impreza L |
2001 Impreza L swap questions
I have a 2001 Impreza L. It needs head gaskets so I've decided to just replace the motor. If I got a Stage II 2.5L would it just drop in, bolt up, and everything connect and work right as if it still had the 2.2L? or what would I have to do/change to make it work? I tried looking at some FAQs and in the stickys but most people were swapping from an older car with a 1.8L. I couldn't find anything on an '01 2.2L to 2.5L swap.
10-20-2009, 04:19 AM | #2 |
Member#: 128997
Vehicle:97 na2 black |
What do you mean by stage 2 2.5 liter?
10-20-2009, 07:16 AM | #3 |
Member#: 123564
EJ18: Found in Imprezas from 1993-1997. Rated at 110hp and 120 ft-lbs
EJ22 Phase I: Found in Legacies from 1990-1998 and Imprezas from 1995-1998. Comes rated at 130hp and 137 ft-lbs, 135hp and 140 ft-lbs, or 137hp and 145 ft-lbs. EJ22 Phase II: Found in Legacies in 1999 and Imprezas from 1999-2001. Rated at 142hp and 149 ft-lbs. EJ22-T Phase I: Found in Sport Sedan and Touring Wagons (Legacies) from 1990-1994. Turbocharged and non-intercooled. Rated at 160hp and 181 ft-lbs. Closed deck, cast pistons, forged rods, oil squirters: turbo motor. Poor flowing heads. EJ25 DOHC Phase I: Found in Legacies from 1996-1999, Imprezas in 1998, and Foresters in 1998. Rated at either 155hp and 140 ft-lbs in 1996 or 165hp and 162 ft-lbs in 1997-1999. EJ25 SOHC Phase II: Found in Legacies from 2000+, Imprezas from 1999+, and Foresters from 1999+. Rated at 165hp and 166 ft-lbs. There was a slight compression ratio change from 1999-2000 where it went from 9.7:1 to 10.0:1. USDM EJ20: US Domestic Market WRX. Found in 2002+ WRXs. Rated at 227hp and 217 ft-lbs. Turbocharged, intercooled, open deck, and decent heads. EJ25T DOHC: Available in 2004 in the Forester XT. Rated at 210hp and 235 ft-lbs. Turbocharged, intercooled, VVTi (Variable Valve Timing), and drive by wire. EJ25T-STi DOHC: Available in 2004 in the WRX STi. Rated at 300hp and 300 ft-lbs. Turbocharged, intercooled, AVCS (Active Valve Control System), drive by wire, intercooler sprayer, and semi-closed design. That's the one I mean. The one in Bold red letters. I copied and pasted that section from the FAQs. I meant to write Phase II the first time. Sorry. |
10-22-2009, 07:31 AM | #4 |
Member#: 123564
Anyone?????
10-22-2009, 12:02 PM | #5 |
Member#: 151686
Vehicle:2004 GTP Comp G 99 Legacy Sold |
Yes it would be a plug and play swap u would just want to retain your ej22 intake manifold and bolt it up to the ej25 longblock....would also need a dual port exhaust manifold
10-22-2009, 05:09 PM | #6 |
Member#: 123564
So all the wiring and everything will just plug in on the 2.5L? I'll just need a 2.5L ECU right? Why do I have to swap the intake and exhaust manifolds? What's different about them that make's them not work?
11-04-2009, 08:56 PM | #7 |
Member#: 103771
Vehicle:'04 Forester Blue |
I'm running the same phase II 2.5L with the stock 2.2L ECU in my '99 Impreza Outback Wagon.
All the wiring is identical - even the injector part numbers were the same. Is your car an automatic or manual? I even used the 2.5L intake manifold. It was identical to my 2.2L. I did switch to a dual port exhaust manifold (again no big deal). PM me for details or questions regarding this swap. It's been my daily driver for about 4 months now and I'm really impressed with it. |
11-05-2009, 12:18 AM | #8 |
Member#: 123564
My car is a manual which makes it easier. Thanks a lot for the info.
Similar Threads | ||||
Impreza Engine Swap | Viral E | MWSOC Private Classifieds | 2 | 06-05-2010 07:42 PM |
98-2001 impreza RS/L/LS/OUTBACK Doorcards | hail2theTheif | RMIC Private Classifieds | 1 | 06-04-2010 01:59 PM |
FS: NOVA 2001 Impreza RS swapped $8000 | Tirpitz56 | Private Vehicle 'For Sale' Classifieds | 64 | 05-15-2010 10:24 AM |
96 2.2 impreza auto swap question | nurvcom | Newbies & FAQs | 0 | 12-02-2009 09:57 PM |
99 Impreza engine swap question! | eyeless99prez | Subaru Conversions | 7 | 03-04-2009 08:18 AM |
