11-08-2009, 05:44 PM | #1 |
Member#: 146696
Will '05 STI crossmembers (both) fit a '00 GM6 + suspension swap questions
I did a quick search and didn't see this question asked.
The rear, I believe will work but if anyone has done this and can confirm it would be appreciated. The front, I have no idea if it will work. I plan on retaining the NA motor. The reason I am considering doing this is because I will be installing the front control arms from an '05 sti, and would rather not have to replace the front bushing if I don't have to. Further, I am concerned about sway bar / endlink fitment. Will I be able to run an sti front / rear bar with sti endlinks if I retain the original crossmember in the front? I believe the rear will work fine, but once again confirmation would be great. Thanks for your help guys!
11-08-2009, 06:34 PM | #2 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
Tha front, Yes it will fit no problem.
If you run different sways, you need to be sure they bolt up, So no, you will need new endlinks if you run USDM WRX/STI (non wagon) control arms. If you run the wider track of an STI you CAN get them to fit, but you need to jimmy rig it. MOst RS and WRX/STI parts will mix, but unless you do your homework and make sure they fit, you will need to do some on the fly work. I"m running an 02 front crossmemeber, with an 02 sedan front sway bar, 01 2.5RS front control arms. The endlinks dont' fit 100%. I used a few washers and some force to make them fit. Works fine, but isn't ideal. catch my drift. (I have what's called pre-load, which is the sway bar is under load or already under some stress.) Last edited by DHRDAN; 11-08-2009 at 06:44 PM. |
11-08-2009, 06:41 PM | #3 |
Member#: 204358
SCIC
The crossmemeber will work, but your swaybars SHOULD match your control arms.
But you can make it fit, if you need too. |
11-08-2009, 07:35 PM | #4 |
Member#: 146696
sweet! the only thing though is that you seem to be running a turbo motor with the turbo crossmember. will a na motor work with the turbo crossmember? from what I recall, it seems that the main differences are:
larger opening for the front control arm mount a notch to accomodate the turbo motor how will this affect fitment on a NA motor? |
11-09-2009, 01:37 AM | #5 | |
Member#: 54026
Will an STI shift knob fit on my '05 wrx? | tbcboo | Interior & Exterior Modification | 1 | 11-12-2009 09:04 PM |
Three-Way Suspension swap question, menage a toi if you will | mattminer | Brakes, Steering & Suspension | 8 | 11-28-2006 11:33 AM |
Will '05 WRX rear struts fit an '04 STi? | Damian | Brakes, Steering & Suspension | 1 | 11-21-2006 10:59 AM |
will '05 STi springs fit on an '05 92x? | shemoves | Brakes, Steering & Suspension | 3 | 01-17-2006 05:11 PM |
will '05 STi dp fit '03 WRX? | mtnbikeracer | Interior & Exterior Modification | 6 | 12-27-2004 10:28 PM |
