03-26-2007, 10:37 PM | #1 |
Member#: 31900
2002 Morette question
I am working on getting my morette to be twin HID (over one year in so far). In doing so I have lost track with which light is the factory low beam, but because of the housing I want the outter (right and left) most light to be the low. To be 100% sure before I order the $300 HID kit the outter bulbs, housed in the projectors, are H7's, right?
ThankS MCL |
03-26-2007, 10:47 PM | #2 |
Trust no one
Moderator Member#: 11170
Tri-State
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Yes. And you don't need a kit for the H7's, the housings will accept standard D2S bulbs with centering adapters and you can use OEM grade ballasts.
Are you sure about the HID high beams? This isn't the best idea if they see typical use, HIDs aren't good for lights that may be flashed or used for brief periods. |
03-26-2007, 11:41 PM | #3 |
Member#: 125432
Tri-State
Vehicle:2004 E46 M3 http://lightwerkz.net |
if indeed it it h7, no need for a conversion setup.
oem d2s > all. |
03-28-2007, 10:28 AM | #4 |
Member#: 31900
I don't use the highs all that much or the lows for that matter. Plus the lows is the kit I already have installed. Are the D2S a better bulb then the H7? I was going to get another kit from autodoodad.com to match the one I got from them before.
03-28-2007, 07:23 PM | #5 |
Trust no one
Tri-State
D2S are genuine HID bulbs. H7, or H-whatever are halogen bulbs. There are no such thing as Hx HID bulbs, only rebased aftermarket ones that have modified bases to fit into halogen housings.
With H7 lights you have the advantage of being able to use the genuine HID bulbs without having to buy someone's kit with rebased bulbs from who knows where. If you rarely use the high beams there is little reason to put HIDs in them, just get some high-efficacy H1 bulbs like Osram Silverstars or Narva Rangepowers. |
Similar Threads | ||||
Changing City Light Bulb on 2002 Morettes | Dismo | Electrical & Lighting | 2 | 07-24-2006 09:50 PM |
highbeams won't turn off, 2002 Morettes (Yes, i have done a search) | highdensity | Electrical & Lighting | 0 | 04-19-2006 12:37 AM |
Another Morette question - Help | rdrandal | Interior & Exterior Modification | 3 | 04-14-2002 07:47 PM |
Morette question | Texas25RS | Interior & Exterior Modification | 18 | 11-19-2001 11:23 AM |
Yet another morette question | brunetmj | Interior & Exterior Modification | 2 | 08-19-2001 04:38 AM |
