Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 06-22-2013, 06:40 AM   #2076
onewhitewrx
Member#: 357369
Will i have any problems running Enkei RPF1s 17x9 5x100 +35. I know I have to roll my rear fenders. I drive a 2012 WRX (Non Sti) and was wondering if I will have wheel bearing issues?
onewhitewrx is offline   Reply With Quote
Old 06-22-2013, 02:15 PM   #2077
PearlRex11
Member#: 284420
2011 WRX Sedan
Originally Posted by gsrcrxsi View Post
It doesn't change the angle of the hub to the strut.think about it.
How come wheels camber in when you put on lowing springs then? When the spring compresses the wheel doesn't move straight up and down does it?
PearlRex11 is offline   Reply With Quote
Old 06-22-2013, 02:38 PM   #2078
sc00by4life
Member#: 97135
Actually, it does.
Someone who might dump their car without getting an alignment might run into issues.
Regardless, camber numbers were what I was after.
I'm pretty sure I understand wheel/suspension .
Dynamic changes in height always effect camber and toe. When you lower a car, the wheels will gain natural negative camber.
Old 06-23-2013, 12:00 AM   #2079
MrImprezaWRX
Member#: 277139
2011 Impreza WRX
Satin Pearl White
just had my wheels install enkei nt03 18x9.5 +40 on swift springs tire size 255/35/18. Their is no rubbing at all.
MrImprezaWRX is offline   Reply With Quote
Old 06-23-2013, 01:08 AM   #2080
NWsoobie
Member#: 289516
2012 WRX
ISM
Any pics?
NWsoobie is offline   Reply With Quote
Old 06-24-2013, 11:19 AM   #2081
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
Originally Posted by sc00by4life View Post
Actually, it does.
try this thought experiment
take a stock height car. that does not have any wheel/strut clearance problem
remove the strut and hub as one piece, hell leave the wheel attached.
replace the springs with lowering springs. and re-assemble.
you will have lowered the car without changing the wheel/strut clearance AT ALL and gained camber from lowering (the whole strut assembly angles, taking the hub and wheel with it)
this is neglecting small variances for changes to alignment (that will be needed to correct toe) of course. but just playing devils advocate that ride height alone makes almost no difference in strut clearance. if you try add a lot of camber via the camber bolts that will lessen your clearance. but camber changes via moving the strut angle do not affect inner strut clearance.
gsrcrxsi is offline   Reply With Quote
Old 06-27-2013, 02:37 PM   #2082
mrkyle3
Member#: 272675
2011 WRX
2002 Corvette Z06
Originally Posted by mrkyle3 View Post
Ok, thanks. I'm a noob when it comes to wheel fitment.
I'm getting 17x9 +42 rota titans wrapped in 245/40 direzza ZII's for autocross. My plan is to see if they rub in the rear and if so then I'll get the fenders rolled.
Ok thanks a lot man, I appreciate it!
I will be sure to take pics and post them here but it'll about a week. Wheels are shipping from CA so will take a bit.
So I was at subaru dealer to get alignment and mount/balance but they told me the wheels rubbed. They test fit a wheel (minus tire) and there was about 5-6mm of clearance from strut... maybe the tire would make it rub? They are 245s on 9" wheels so I doubt it. This is after I put aftermarket camber bolts on and before the alignment so the negative camber was pretty large. I reiterated that the wheels had clearance and it should not rub but the service manager pulled the plug because he didn't want to be responsible for anything.
I called IAG performance and they told me it would fit fine so I made an appt with a performance shop for tomorrow morning. Is all the research I've done wrong? I feel like these wheel should fit without spacers. Perhaps I should have alignment done first to get my neg camber down to -2 instead of whatever it's at.
mrkyle3 is offline   Reply With Quote
Old 06-28-2013, 12:24 PM   #2083
mrkyle3
Member#: 272675
2011 WRX
2002 Corvette Z06
The subaru dealer had no idea what they were talking about.
Had a performance shop put them on and they fit completely fine. It remains to be seen if a fender roll is necessary in the rear but I don't think so.
These are Rota Titans 17x9 +42 with Dunlop Direzza ZII in 245/40
Old 06-28-2013, 03:25 PM   #2084
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
I hope the stealership didn't bill u for the alignment unless they told u already that they will only align to factory specs meaning they will not do a performance alignment due to liability.
trev762 is offline   Reply With Quote
Old 06-30-2013, 10:18 PM   #2085
j3pwrx
Member#: 361041
Default 18x8.5 vs 18x9 vs 18x9.5 (which one?)
Hi!
I need your opinion. which fitment better suits a 2012 wrx on stock suspension? I've been reading this thread for awhile and doing comparisons with the offset calculator but still undecided. I wouldn't mind rolling the fenders but would like to stick with the stock camber (if ever possible).
Now these are my options:
(a) 18x8.5 +40 with 245/40/18 (-13 from stock STI offset)
(b) 18x9 +38 with 245/40/18 tires (will it stick out the fender?)
(c) 18x9 +38 with 235/40/18 (might be too stretched?)
(d) 18x9.5 +40 with 255/35/18 tires (this might still need fender rolling from what i've read)
(e) 18x9.5 +40 with 265/35/18 tires (one of the common set ups here)
My concern for 9.5 is that it's not practical for daily driving plus I don't want it sticking out the fender. I'll be lowering it with BC BR's when I get more funds.
Right now I'm leaning towards (a), and (b). Please help me decide. Any inputs will be greatly appreciated!
Thanks a lot!
j3pwrx is offline   Reply With Quote
Old 06-30-2013, 11:10 PM   #2086
GrumpyPitbull
Member#: 313311
No issue with bearings.
Regarding fitament, it will depend on tire choice. I run those exact wheels with 245/40 BF Goodrich Comp 2 and I did not even have to roll.
GrumpyPitbull is offline   Reply With Quote
Old 07-01-2013, 10:21 AM   #2087
Evil XT
Member#: 102801
14 Rubicon
RIP "Silver Fridge"
^^ that looks awsome. Just found my new everday wheels. No drop right?
Evil XT is offline   Reply With Quote
Old 07-01-2013, 12:19 PM   #2088
texascanuck
Member#: 317045
2012 WRX Hatchback
Originally Posted by j3pwrx View Post
Hi!
Thanks a lot!
OK, this is a DD on stock height/suspension and you are leaning towards a) and b) ... so based on those requirements - how about doing a) but with the tire choice in c) .... that is an 18x8.5 wheel with the 235/40-18 tire.
texascanuck is offline   Reply With Quote
Old 07-01-2013, 01:16 PM   #2089
mrkyle3
Member#: 272675
2011 WRX
2002 Corvette Z06
I have RCE yellows on bilstein struts, so maybe a 3/4" drop.
Old 07-01-2013, 07:03 PM   #2090
j3pwrx
Member#: 361041
Hi texascanuck! thanks for the reply. so you think that's a better fitment? It's more narrow than the STI tires, but would the stretch be alright? thanks again!
Old 07-02-2013, 01:12 PM   #2091
texascanuck
Member#: 317045
2012 WRX Hatchback
not neccessarily a better fitment just different. The 245 is wider but taller. The 235 will not be a huge stretch on the 18x8.5 wheels.
If you go back to your original choices of a) vs b)
I would go with a) 18x8.5 w/ 245/40-18.
Old 07-03-2013, 12:21 PM   #2092
TryHonesty
Member#: 346323
2013 WRX on E85
I'm looking to get Rota Grids for my 2013 WRX and would like an opinion:
Stock
Offset: +53
Bolt pattern: 5x100
Tire: 235/45R17
Choice(s) below
Grid 17"
Offset: +44
Bolt pattern: 5x100
Tire: OEM 235/45R17?
or
Grid 18"
Offset: +44
Bolt pattern: 5x100
Tire: 235/40ZR18 or Will OEM 235/45R17 fit?
The 17" look like they would fit no problems, any ideas on the 18"?
TryHonesty is offline   Reply With Quote
Old 07-03-2013, 12:33 PM   #2093
imac6471
Member#: 309481
2011 OBSwirl WRX
2004 FXT "Tucker"
Stock
Offset: +53
Bolt pattern: 5x100
Tire: 235/45R17
Choice(s) below
Grid 17"
Offset: +44
Bolt pattern: 5x100
or
Grid 18"
Offset: +44
Bolt pattern: 5x100
17" Tires will not fit on a 18" wheel. This is not what they mean by "stretch"
imac6471 is offline   Reply With Quote
Old 07-03-2013, 12:34 PM   #2094
deanwrx
Member#: 188997
2007 STI
Well, you can't exactly put a 17" tire on an 18" rim.
Why not go with a 17x9" +42 Grid - would look better.
Stock
Offset: +53
Bolt pattern: 5x100
Tire: 235/45R17
Choice(s) below
Grid 17"
Offset: +44
Bolt pattern: 5x100
or
Grid 18"
Offset: +44
Bolt pattern: 5x100
deanwrx is offline   Reply With Quote
Old 07-03-2013, 01:28 PM   #2095
TryHonesty
Member#: 346323
2013 WRX on E85
That sounds great. I'm just not as familiar with how the width for the tires work in regards to scraping or needing rolling of fenders.
I'd like to be able to get new wheels/tires without having to roll anything.
With the 17x9" +42, offset looks good, 17" around is stock which is nice, but how does the 9" width translate to my 235/45R17 stock tires? Can I use my stock tires on that 17x9" +42 wheel?
Old 07-03-2013, 01:30 PM   #2096
Scnsaracer
Member#: 319511
2013 STI Sedan
Ice Silver Metallic
Yes you can use those tires but hey will be a bit stretched. 255 40 17 would be best
Scnsaracer is offline   Reply With Quote
Old 07-03-2013, 03:01 PM   #2097
le chocolate moose
Member#: 287147
2011 STi HB
Default 18x9.0 on PSS 265/35 on GR STi
Hey Dan,
Awesome thread. I've been through it in its entirety, but it seems examples and pics of this setup have been very sparse. I know 9.5 would be ideal, but the WedsSport I am looking at only comes in 9 and 10. Could do 255/35 but would like to stay closer to stock diameter. What do you think? 265 too much tire for a 9?
Thanks,
Mike
le chocolate moose is offline   Reply With Quote
Old 07-03-2013, 03:19 PM   #2098
sc00by4life
Member#: 97135
Originally Posted by le chocolate moose View Post
Hey Dan,
Thanks,
Mike
We need more information as figment varies greatly.
We need wheel width and offset for any wheel you're looking at.
Old 07-03-2013, 04:02 PM   #2099
Mach V Dan
Member#: 12029
265 is a little wide for a 9" wide wheel, but it can still fit on there. 255/35 is only 1.2% smaller than stock diameter...that's pretty close. I'd go with that.
We need more information as fitment varies greatly.
We don't if we're just judging tire width versus wheel width.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 07-03-2013, 04:15 PM   #2100
le chocolate moose
Member#: 287147
2011 STi HB
Sorry, it was in the title: "18x9.0 on PSS 265/35 on GR STi"
Didn't mention offset since I am confident +36 will work with stock susp and possible slight roll to the rear.
Thanks,
Mike
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 12:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 09:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 04:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 01:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 02:20 PM
