Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 03-06-2019, 06:02 AM   #26
greygonzalez
Member#: 461647
209 STI
ISM
Just send it...
Tuned at 6 miles, FBO e85 at 1k miles, upgraded to fp red at 5k miles. Running strong at 450 hp
greygonzalez is offline   Reply With Quote
Old 03-06-2019, 06:04 AM   #27
greygonzalez
Member#: 461647
209 STI
ISM
Just send it...
Old 03-06-2019, 09:49 AM   #28
Maine Jim
Member#: 480596
19 STI
Maine Jim is online now   Reply With Quote
Old 03-06-2019, 10:26 AM   #29
ROTORCRAFT230
Member#: 385360
2014 Impreza WRX
Plasma Blue
Default New 2019 STI Break Procedure?
Originally Posted by MagicDoorHinge View Post
I went full throttle a few times every day, just keeping it between 3500 and 4500 RPMs (except for a few choice spirited driving moments where I may have gone up to 6k rpms...) for the first 500 miles. Miles 500 to 1000 I varied revs a lot, engine braked a lot, made sure to cool down in between pulls--just like in the first 500 miles, but raised my 4500 RPM limit to 6500.
I'm only at 2300 miles now and haven't gotten a compression/leakdown test or anything so it's certainly too early to say whether my break-in worked.
I'll probably catch some flak for this but my manual says I don't need to change oil at 1000. I check it every time I fill the gas tank; no glitter and it's a lovely amber color so I suppose I'll change it at 3k or so. I'll make sure to remind everyone of my break-in procedure in my "stupid ej25 engine blew up" post.
This is how I broke in my 2014 WRX. I believe in hard break ins. Iíve had plenty of new cars and have always done it like this. Maintenance is the key.
Have fun with it and donít worry
Mark
Edit, my car doesnít use any oil what to ever. 24000 miles so far.
ROTORCRAFT230 is offline   Reply With Quote
Old 03-11-2019, 11:43 PM   #30
ericsson
Member#: 208672
2013 WRX STI Limited
Obsidian Black
Originally Posted by Tk421STI View Post
Thanks guys!
Someone mentioned setting a shift reminder on the dash? How do i do that?
Also, I'm always going to put 93 gas. Do i really need to worry about engine issues? I thought we were passed this with the updated 19 models?
It will be a good idea if you start a repair bank account. STIs engines break without any warning, specially if you start modifying it. Dealership / Subaru tend to blame the driver for any defect damage found.
If you are going to modify it, your first mod should be AOS (air oil separator). STI engines take in a lot of blow-by and causes the car to misfire / detonation. ECU doesn't report it unless it's a major misfire and by then the damage is already done.
ericsson is offline   Reply With Quote
Old 03-12-2019, 08:36 AM   #31
Burn all four
Member#: 358683
2019 Subaru WRX STI
World Rally Blue
I just broke in my 19 STI by following the recommended break in period. I am going to keep my car stock for now. Modifying is fun though as my previous 2011 STI was stage 2.
Burn all four is offline   Reply With Quote
Old 03-12-2019, 12:57 PM   #32
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Even if you don't do a full oil change before the first scheduled one, changing only the filter (and topping the oil level off) ought to be better than doing nothing at all.
Norm
Norm Peterson is offline   Reply With Quote
Old 03-12-2019, 01:45 PM   #33
D-rock240
Member#: 284221
2011 WRX GV SSM
01 Legacy/03 Outback wgns
Norm
Wat
Change the oil if you replace the filter
D-rock240 is offline   Reply With Quote
Old 03-12-2019, 02:30 PM   #34
carsebuco
Member#: 482289
2018 STI
Originally Posted by D-rock240 View Post
Wat
Half the oil is coming out as soon as you pull the thing anyways, might as well finish the job...
carsebuco is offline   Reply With Quote
Old 03-12-2019, 02:36 PM   #35
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
True. STI is still a bottom mount oil filter.
SirBrass is offline   Reply With Quote
Old 03-12-2019, 04:33 PM   #36
rtv900
Member#: 428511
2016 STI
yeah but it's not below the pan.
I'm pretty sure it's just what's in the filter like anytime you remove a filter, although I've never actually pulled one on a car with a full pan
never the less, on the STI 90% of the work is removing the underbelly pan to access the filter so there's really no motivation to leave the oil in there after all that work
Oil and no filter change, there's motivation for that since you don't have to remove the pan.
rtv900 is offline   Reply With Quote
Old 03-12-2019, 07:28 PM   #37
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Wat
It's not like you're always going to be changing only the filter midway through your regular oil change interval. Just partway through the first one, when you can expect engine operation has generated more debris than it will over any later span of a thousand miles. Unless it does go "boom", anyway.
Getting at the 2.5L STi engine oil filter appears to be identical to getting at the 2.5L Legacy 2.5GT's oil filter. Access really isn't all that bad, not even for an old guy like me working with ramps and a creeper.
There are a few tricks to minimizing the amount of oil that dribbles over your hand and any components located lower than the filter seat (exhaust tube?). It might even be worth doing the filter only the first time just so you won't be working with a drain pan already half full right where your arm needs to be and where a dropped oil filter would . . .
Norm
Old 03-13-2019, 09:59 AM   #38
Burn all four
Member#: 358683
2019 Subaru WRX STI
World Rally Blue
On my 2011 STI I changed my own oil and hated taking that underbelly tray off that was most of the work and it is a pain in the rearend. Oil and filter were easy. I think on my 19 STI I am just going to pay and have it done. I have a $10.00 off coupon from Subaru.
Old 03-13-2019, 11:55 AM   #39
rtv900
Member#: 428511
2016 STI
^tell me about it
I do the filter every other oil change which eases the pain.
ridiculous they didn't make an access for the filter, removing the tray sucks it
Old 03-13-2019, 05:42 PM   #40
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
There's two ways to break your car in. Like Subaru tells you to, or every other way listed in this thread. The only one that is "right" is Subaru's recommendation. Everything else is just anecdotal.
My personal opinion of hitting the 1000 mile mark is that you're ready to go after that oil change. Burn it up.
bdubblu is offline   Reply With Quote
Old 03-13-2019, 06:07 PM   #41
bluesubie
Member#: 767
04 FXT
If Subaruís recommendation is right in regards to break-in procedure why do refer to a 1,000 mile oil change when Subaru does not?
Old 03-13-2019, 07:56 PM   #42
Norm Peterson
Member#: 498642
2019 WRX Limited
Dark Grey
Keep in mind that 'anecdotal' includes the opinions of people who have assembled engines from piles of new-in-the-box parts and freshly machined major components. Even within this thread's small population, guaranteed.
Norm
Old 03-19-2019, 11:16 AM   #43
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Because of the two words in that very same sentence which are "my opinion".
I hear ya Norm. Engine builders as a group are not necessarily consistent with their recommendations. Meaning my builder said 1K miles of gentle driving, where as another says 1,500 miles with varying rpms, another says 500 miles, blah blah blah. If one is building an engine with all stock parts and tolerances, then the factory recommendations would hold. If one is building a motor perhaps with aftermarket performance parts, and different tolerances, then that's something different.
However, we're talking about a new car in this thread. From the factory.
