Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 03-13-2019, 11:12 PM   #1
Turvey17
Member#: 498089
Default Compression test numbers high?
Got a compression test done on a 11 sti hatch that Iím looking at purchasing.
The numbers came out
Cylinder 1. ~ 169
Cylinder 2. ~ 170
Cylinder 3. ~ 169
Cylinder 4. ~ 171
Leakdown test
Cylinder 1 - 0
Cylinder 2 - 4
Cylinder 3 -0
Cylinder 4- 3
Are the compression numbers high? Iíve seen a lot of people saying around 140-160 is ideal.
Any help is apprectiated
Turvey17 is offline   Reply With Quote
Old 03-14-2019, 06:21 AM   #2
rtv900
Member#: 428511
2016 STI
yes, WAY too high, you need to pull those heads and score up the cylinders with a file. Too much compression is horrible, you want that power leaking out.
Come on man.
Too high?
plus, I think somebody kind of bamboozled you because they tell you that two of your cylinders have ZERO percent leakdown?
That isn't possible so they lied or are totally incompetent in that kind of test.
rtv900 is offline   Reply With Quote
Old 03-14-2019, 06:39 AM   #3
Ryandorres
Member#: 497878
Come on man.
Too high?
+1
Ryandorres is offline   Reply With Quote
Old 03-14-2019, 08:27 AM   #4
Exit 37
Member#: 475618
2006 WRX
World Rally Blue
They look consistent which is important.
Exit 37 is offline   Reply With Quote
Old 03-14-2019, 08:43 AM   #5
Turvey17
Member#: 498089
Come on man.
Too high?
I got it done at a reputable Subaru shop. I doubt they are lying to me, the engine was recently rebuilt 12k ago and they remachined the heads which could cause slightly higher compression. Same with having basically a brand new engine
Old 03-14-2019, 08:59 AM   #6
rtv900
Member#: 428511
2016 STI
the compression numbers aren't outrageous and certainly not impossible.
Zero leakdown however is impossible
So I don't think that is not true, I know it isn't true.
