Welcome to the North American Subaru Impreza Owners Club Saturday March 23, 2019
Old 03-14-2019, 12:00 PM   #1
Typpi
Member#: 499058
Default EBCS Over Boosting
I recently purchased my 4th wrx. im no stranger to a boxer. but my 02 wrx 5 speed was having some boost osolation issues so i changed all the vacuum lines. same problem. so tried changing the map and ended up with the same problem and now a misfire code for cylinder 4. so decided to change my stock bcs to a cobb EBCS, and installed the cobb stage 2+ EBCS tune which states should be at 17 PSI i hit 19.6 no more boost osolation but ended up with a misfire on cylinder 2 & 4 now. im lost at this point not sure if im not getting enough fuel or if there is something im missing. any advice is appreciated. and after searching the forums there isnt a whole lot of information on the EBCS and over boosting
Typpi is offline   Reply With Quote
Old 03-14-2019, 12:46 PM   #2
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
What is the complete mod list for your car?
Turpid Porpoise is offline   Reply With Quote
Old 03-14-2019, 03:21 PM   #3
Typpi
Member#: 499058
02 wrx 2.0 with catless DP and UP pipe 3" straight pipe, Cobb SF intake, Cobb EBCS Cobb AP Stage 2+ EBCS tune
Old 03-14-2019, 06:31 PM   #4
Turpid Porpoise
Member#: 476573
The stage 2 ots map isnt designed for a catless downpipe and Iím pretty sure overboosting wih a catless downpipe is a problem on EJ205s. Im pretty sure thats going to be one of your issues.
When was the last time you changed the plugs or coil packs?
For the moment you can clean and tighten your grounds.
Old 03-15-2019, 08:27 AM   #5
SirBrass
Member#: 207263
2019 WRX Limited
World Rally Blue
This right here. Cobb map notes will specifically state that the OTS tune is not intended for catless DPs, and catless DP depending on region and weather will tend to boost creep more than aftermarket catted.
SirBrass is offline   Reply With Quote
Old 03-15-2019, 09:24 AM   #6
Typpi
Member#: 499058
I just changed all 4 plugs and coil packs not even a week ago.
ill check the grounds but that does make sense. why is spikes and then starts to fluctuate. so looks like its time for a pro tune. only problem the closest tuner is over 2 hours away. thank you very much.
Old 03-15-2019, 09:38 AM   #7
cknowlen
Member#: 189077
2011 STI limited
Correct, it is time for a protune. But keep in mind that you don't necessarily have to drive somewhere to get a protune. There are plenty of reputable Subaru tuners who provide E-tuning services where they will send you a base map, you datalog and send results back via email, tuner adjusts map and resends...rinse and repeat...Usually a lot cheaper too.
cknowlen is offline   Reply With Quote
Old 03-15-2019, 09:45 AM   #8
Typpi
Member#: 499058
ya i know. The last time i did a tune. like that on my Golf GTI the engine blew up in the middle of the adjusting the tunes from predetonation. Now i only use dyno tuners in person lol my Audi has been to a dyno tuner 3 times and its so much nicer.
Old 03-15-2019, 09:55 AM   #9
Turpid Porpoise
Member#: 476573
There are a number of highly reputable guys who do E-tunes on Subarus. The software has gotten much more advanced to the point where there can be a negligible difference between an E-tune and a dyno tune but I personally prefer a dyno tune over an E-tune. There are things that an E-tuner can't feel/hear that may not show up on a log as a red flag.
Old 03-15-2019, 10:34 AM   #10
Exit 37
Member#: 475618
2006 WRX
World Rally Blue
Do you have the lines installed correctly?
Exit 37 is offline   Reply With Quote
