Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 06-10-2012, 06:11 PM   #1
luftpirate
Member Sales Rating: (16)
Member#: 270358
2002 WRX Wagon
Midnight Black Pearl
Default Cracked Invidia Up Pipe (Pics)
After dealing with issues of late spool, poor power under boost, inconsistent power, etc I finally found my problem. This part is around two years old has been put through normal stresses of a daily driver. All the support brackets were in place. Both the pipe and welds cracked.
I did some research and found out there are others that have had similar issues. I contacted Invidia and they will only give a 1 year warranty.
FYI to anyone looking to buy an Up Pipe. Perrin's are not much more and they stand by their product for 5 years. That's who I went with this time around.
luftpirate is offline   Reply With Quote
Old 06-10-2012, 09:34 PM   #2
hudson-cowell
Member#: 281773
2002 wrx
blaze yellow
Not saying what uppipe is best but wouldn't you think a uppipe like grimmspeed with a flex joint would keep this from happening. The stock one has one so shouldn't your replacement have one
hudson-cowell is offline   Reply With Quote
Old 06-11-2012, 01:15 AM   #3
luftpirate
Member#: 270358
2002 WRX Wagon
After reading many posts it seems the flex joints have an even higher failure rate.
Old 06-11-2012, 01:35 AM   #4
alva8193
Member Sales Rating: (3)
Member#: 318755
2012 Phatbotti Tuned
I've always found invidia products to be of cheaper quality
alva8193 is offline   Reply With Quote
Old 06-11-2012, 01:39 AM   #5
ssp
Member Sales Rating: (1)
Member#: 322815
2003 WRX Wagon
World Rally Blue
that sucks, least you found the problem, how did you even find it?
ssp is offline   Reply With Quote
Old 06-11-2012, 09:23 AM   #6
NitroTrike
Member Sales Rating: (2)
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
I've had a STi catless uppipe on mine for 10 years. Can't beat OEM fitment...
NitroTrike is offline   Reply With Quote
Old 06-11-2012, 12:44 PM   #7
luftpirate
Member#: 270358
2002 WRX Wagon
I crawled under the car planning to pull spark plugs and check them, then I saw the exhaust stains on the up pipe from where it had been leaking.
Old 06-11-2012, 01:21 PM   #8
Izero
Member Sales Rating: (6)
Member#: 121332
2004 STi
Platinum Silver Metallic
when I had Invidia header on my car it cracked in the exact some place in the exact same way, and also cracked and bent itself out of the flange that meets the head. not surprised to see this happen to someone else.
Izero is offline   Reply With Quote
Old 06-11-2012, 09:47 PM   #9
luftpirate
Member#: 270358
2002 WRX Wagon
I have seen several others with the same issue as well. It's possible that when these are layed up in the jig the dimensions are not close enough to spec. Regardless I think it's pretty hard to blame the customer in most cases.
Here are a few others with similar issues.
http://legacygt.com/forums/showthrea...pe-132071.html
http://www.rallysportdirect.com/revi...SW1UPP-Cracked
http://forums.nasioc.com/forums/show....php?t=1849777
http://forums.nasioc.com/forums/show....php?t=2333595
http://shop.edoperformance.com/invid...rx-p-5688.html
Not related but speaks to quality control.
http://forums.nasioc.com/forums/show....php?t=1479406
Note my Perrin is the 1.75 ID, much smaller than the Invidia pipe. The Perrin piece has thicker flanges as well.
Old 06-13-2012, 11:35 AM   #10
Rodwrx23
Member Sales Rating: (76)
Member#: 170948
Crap, I just bought a used Invidia on here! I also had a flex section in a GS EWG uppipe fail after quite some time, they replaced it no questions asked.
Rodwrx23 is offline   Reply With Quote
Old 04-07-2013, 10:58 AM   #11
JonnyV2889
Member#: 197384
2006 WRX Ltd
+1 for the crack.
I noticed a decent amount of undercut on the welds when the pipe came in. Going to pull it when I swap in gtspec headers.
JonnyV2889 is offline   Reply With Quote
Old 10-01-2013, 02:59 PM   #12
PSSSHHH
Member#: 227187
2004 WRX Premium
Found mine cracked after 2 years of use. almost 50% of the pipe was cracked near the weld.
PSSSHHH is offline   Reply With Quote
Old 06-03-2015, 04:00 PM   #13
BTurc
Member#: 201599
2017 WRX
Lapis Blue Pearl
Mine is beginning to crack too...Definitely not getting one again.
BTurc is offline   Reply With Quote
FS : Invidia up pipe, aftermarket down pipe, stock up pipe Missionmtman Engine/Power/Exhaust 0 03-14-2011 10:58 PM
FS : Megan Axel Back/Mid Pipe & Invidia up pipe Todd234 Engine/Power/Exhaust 0 07-15-2010 03:34 PM
F.S. Stock STI VF39, Invidia up pipe, stock TGV's, stock down pipe... 03clipsegts Engine/Power/Exhaust 36 09-30-2008 05:22 PM
FS, CT, Invidia Up pipe, Turbo XS race pipe AWD-247 NESIC Private Classifieds 4 06-05-2008 08:48 PM
invidia up Pipe and hks Uppipe....invidia is cheaper....?? yub2da Newbies & FAQs 4 02-14-2006 06:52 PM
