Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 08-18-2019, 08:22 PM   #1
ascendr
Member#: 462136
02 Bugeye
Default Added a switch for Test mode and Flash
Got tired of crawling under the dash to connect the green test mode and the flash jumper so I wired up a switch and installed it in the fuse door. I chose a 3 way DPDT switch so center is "off", down is test mode, and up is flash mode. Hot glued in my abs panel for now I might get something 3d printed in the future, maybe add a led to show status or something too.
ascendr is offline   Reply With Quote
Old 08-26-2019, 09:58 PM   #2
Homemade WRX
Member#: 33782
96 in the garage
search FIRST, then PM!!!
That's a good idea that I'm going to borrow.
Old 09-10-2019, 08:21 PM   #3
contaminatrix
Member#: 435611
2002 SG5-2.0-XT-JDM
45A, originally 18L
very nice! now quick q, can you kindly show the wiring? i'd like to do the same and crawling on my back looking for switches is becoming untenable seeing that i'm aging
contaminatrix is offline   Reply With Quote
Old 09-10-2019, 08:32 PM   #4
no694terry
Member#: 220816
2018 Exotruck
EJ22e 415whp/398wtq
Is all that wiring needed? Mine just grounds a single wire from ECU. But I also don't have any abs or tcu or anything
no694terry is offline   Reply With Quote
Old 09-18-2019, 12:54 PM   #5
Nettalp
Member#: 93812
2004 Wrx wagon
Platinum Silver Metallic
Bought this switch and plug and play wiring from a guy on FB. He sells them. Super easy install since everything clips in.
Nettalp is offline   Reply With Quote
Old 09-18-2019, 12:56 PM   #6
Nettalp
Member#: 93812
2004 Wrx wagon
