Welcome to the North American Subaru Impreza Owners Club Saturday September 26, 2020
Old 01-15-2008, 07:49 PM   #1
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Default Pulls To Right When Driving
Okay, so, 4th time on the laser alignment machine, every single seting is perfect and according to the techs should drive straight as an arrow, but it doest, it pulls to the right, and fairly aggresivley!
Has anyone had this problem with their Impreza's? Never hit a curb, never in an accident, no bent pieces, steering rack is perfect, the only thing that was off was the SIA (I think) which is the steering something aspect.... but off only by a fraction and according to the techs would have no affect on the steering.
Help!!
EagleRockWrex is offline   Reply With Quote
Old 01-15-2008, 07:55 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Rotate tires in the front from side to side and see what happens. Tires can cause this problem. Do you have a print out of the alignment specs?
Tony
Old 01-15-2008, 08:19 PM   #3
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Tires were rotated in all directions temporarily and it didnt fix anything, they are directional Goodyear F1 GS-D3 with less than 4,000 miles on them however I developed this problem before the tire change.
Settings are as follows:
Front Left
camber -0.5
caster 3.2
toe 0.03
SAI 15.1
Included angle 14.6
Front Right
camber -0.9
caster 3.2
toe 0.02
SAI 14.5
Included area 13.6
Rear Left
Camber -1.9
Toe -0.12
Rear Right
Camber -1.4
Toe 0.03
Rear Cross Camber -0.5
Total Toe -0.09
Thrust angle -0.08+
Old 01-15-2008, 08:34 PM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
They couldn't get the camber any closer than that? I would not say that "every setting is perfect". I'm not sure whether .5 difference in the rear and .4 in the front is enough to cause what you're describing (I have never had an alignment that far off personally) but I have to think that they can try harder.
Old 01-15-2008, 08:50 PM   #5
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Every car is different. How was your alignment before this?...if you had those tires on the car or other tires and needed an alignment prior, they could have some abnormal wear on them PLUS with the fact that this alignment is FAR from perfect,..AND your weight in the car. I used to sit in my car when the final settings were tweeked. I can say having been a service writer for a long time that I got to sit in my cars with a half tank and get a "super anal" alignment and yes with -3.0 plus and dead toe and NEW tires, I could get a straight car with a straight steering wheel on the rare level highway or street.
So there could be MANY reasons why. Sway bar links, rear bar could have flipped and no one noticed( highly unlikely), simple things like tire pressure that I have seen techs NOT check or pay attention to. Point is many things contribute to the alignment and while it seems like they would know and watch out for these things...MANY dont.
Oh and sometimes the rack is WAY OFF.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 01-15-2008, 11:10 PM   #6
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
Should I have them tighten up those camber numbers? I will do a search on good setting and have them set it there, I paid for the free alignments for 3 years.
Also, how does the rack get off? That sounds like it could cause it but when they looked under the car for any bent pieces or a loose rack he said he saw nothing looked like it shifted..... This is frustrating!!
Old 01-15-2008, 11:20 PM   #7
Web Foot STi
Member#: 39086
2004 STi
Max balanced camber in the front and 0.00 toe front and back. I ask for a mis alignmet when I go.
Web Foot STi is offline   Reply With Quote
Old 01-16-2008, 04:27 PM   #8
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
The guy who does my alignments once showed me a document discussing OE setups and settings. I recall there being a quarter to half degree less caster in the right front to compensate for crowned roads. Try taking a quarter degree out and see if it improves things.
Scooby921 is offline   Reply With Quote
Old 01-16-2008, 04:50 PM   #9
EagleRockWrex
Member#: 95780
2008 Infinity G37S
Ivory/Black
I will keep everyone posted
Old 01-17-2008, 04:08 AM   #10
Mecanic07
Member#: 126552
2007 STI
Urban Gray
You have more neg camber on the front, so its not supposed to pull on the right since you have the same caster specs on both sides...
Do you have oem wheels? Cheap tires? Why is your thrust angle not at zero? So easy to put at 0, there is the eccentrics bolts in the rear... Swap the front tires with one of your buddy, when I get severe pulling on one side, it`s always the tires ( if all the specs are ok, and all the tie-rords, ball joints, bushings are tight)
Mecanic07 is offline   Reply With Quote
Old 01-17-2008, 11:36 AM   #11
strohausii
Member#: 26770
'02 WRX
midnight black
Yeah, I thought the OEM suspension had unequal caster from right/ left.
strohausii is offline   Reply With Quote
Pulling to Right and Resistance Turning to Left OsirisNEB Brakes, Steering & Suspension 2 06-08-2008 03:08 PM
my car 05 STi slightly pulls to the right when driving tom6 Newbies & FAQs 8 07-14-2007 10:26 PM
Slight pull to right after track day chimchimm5 Brakes, Steering & Suspension 3 03-10-2007 03:35 PM
pulling to right under excelaration bill king Transmission (AT/MT) & Driveline 6 01-02-2006 05:07 AM
Swaping left hand drive to right hand drive??? STIpreza Normally Aspirated Powertrain 8 05-23-2001 05:51 AM
