Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 01-05-2009, 02:53 AM   #1
Daniel's05WRX
Member Sales Rating: (7)
Member#: 93798
2005 WRX Hybrid
Crystal Grey Mettalic
Default just installed the cusco motor mounts
i stayed up tll 8am today and installed the cusco motor & tranny mounts, since my stockers were klankin around @ 75k... the hours of aggony were definetly worth it though, car feels amazing when cornering and shifting. there a good deal louder in the car though, but well worth it.
Daniel's05WRX is offline   Reply With Quote
Old 01-05-2009, 09:07 AM   #2
Unabomber
👏 Big Ron 👏
Member Sales Rating: (11)
Member#: 18062
on car parts so PM
me b4 j00 buy
How was the install? I've heard that one of them was in/out easy and one of them is a whore to swap out as something or other is in the way during the install.
Old 01-05-2009, 09:48 AM   #3
Ralliart4
Member Sales Rating: (21)
Member#: 135927
2002 Impreza WRX RA
I have them in my WRX and have used the Kazama/Cusco set in a couple of my 240sx's and love them evey sporty car i have will probably have a set if they make them.
Ralliart4 is offline   Reply With Quote
Old 01-05-2009, 02:35 PM   #4
Gfunk720
Member Sales Rating: (33)
Member#: 42549
E92 M3 M\\\
2017 Outback Limited
Thats what I have heard as well... that there are 1-2 bolts that are almost impossible to get at.
How many hours for install start to finish?
Gfunk720 is offline   Reply With Quote
Old 01-06-2009, 01:35 AM   #5
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
install was a bitch... theres 2 bolts and 1 nut per mount and the back bolts suck much penis...lets see, the steering column and the downpipe, and the steering rack are all in the way... drivers side was actually easier then the passenger... total was 4 hours, totally worth it though just wish i'd done it sooner
Old 01-06-2009, 11:26 AM   #6
hex2bit
Member Sales Rating: (5)
Member#: 135072
2004 FXT, 19t-td04
The install isn't too bad. I've done mine 3 times. The key is to remove the pitch mount so the engine remains lined up when you drop it back down. Also, having a socket wrench with a bendy head helps reach the back bolts, which you can get from the rear under-side of the steering rack/cross support. You can get your other hand in there to help from the front outer side of each mount. You just don't have a lot of rotation space with the wrench, so it's a little slow. I did it with a fixed box wrench the first time and that was really slow, and tiring.
I've run the cusco motor and tranny mounts. For a sport oriented car, they are fantastic. It's not too bad for a daily driver, and provides a lot of engine presence, without much vibration. If you're running the stock softy tranny mount, your car will shake a lot at low RPM. The upgraded tranny mount brings everything together.
However, I went to the group-n motor mounts because my car is mostly used as a daily driver. The group-n has half of the "presence" of the cusco mounts, but are stiff enough to control engine movement well. I'm still using my cusco tranny mount, so that keeps the shifting locked down well, with the only negative being the added gear whine noise. I may move to a group-n tranny mount at some point to see the difference in feel and gear whine.
hex2bit is offline   Reply With Quote
Old 01-06-2009, 01:54 PM   #7
bzbuzz
Member Sales Rating: (18)
Member#: 116052
2011 STI ( Sold )
IMO, grp N engine+tranny mounts are more than adqueate for mostly DD car. one of my fav mods so far.
bzbuzz is offline   Reply With Quote
Old 01-06-2009, 04:38 PM   #8
Daniel's05WRX
Member#: 93798
2005 WRX Hybrid
yeah but my car is gettin up there performance whise and its not stiff enough to really bother me. ive had a clutch masters full kevlar clutch and fidanza flywheel for like a year but never was able to enjoy it... my car feels awsomely firm shifting,just have to make sure i dont slam 2nd too hard or the 5spd will grenade probably.
Old 01-18-2009, 10:59 PM   #9
ScooobaSeth
Member#: 165607
02 Wagon
40k original miles
i just wanted to say i installed new group n sti motor mounts and the transmission mount. feels much much better but i still get a rock when i let on and off the gas....although its not nearly as bad as before.
i noticed some small rubber bushing on the cross member where the trans mount was. seems like it doesnt really need to be there, could that be causing it still to move? is there anything i can replace that stupid rubber busing with?
do you think a new pitch mount would stop the movement?
ScooobaSeth is offline   Reply With Quote
Old 01-19-2009, 10:26 AM   #10
bzbuzz
Member#: 116052
2011 STI ( Sold )
yes the pitch stop mount will help a lot. but a lot NVH will come along as well.
Old 01-20-2009, 11:53 AM   #11
Kaldar142
Member Sales Rating: (19)
Member#: 151090
S197 boosted V8 FTW
i would recommend cusco motor / tranny mounts to ANYONE... even on a DD car. But then again my definition of a DD car is a lot different than most people :P
install isn't too bad if you have the proper tools
Kaldar142 is offline   Reply With Quote
Old 01-24-2009, 07:56 PM   #12
Cmckinnonr
Member#: 201042
2003 WRX
Does it make your car shake hella bad? my friend had thoes in his 240. they shook so damn bad they felt like solid motor mounts. how do they work?
Cmckinnonr is offline   Reply With Quote
Old 01-25-2009, 01:50 AM   #13
Kaldar142
Member#: 151090
S197 boosted V8 FTW
these pretty much ARE solid motor mounts.
i had them in my 240 too, it was alot worse in the 240.
there are vibrations but its nothing serious at all... pretty subtle IMO
Old 01-25-2009, 09:24 PM   #14
IIdiceII
Member Sales Rating: (88)
Member#: 90438
anyone wanna trade their cusco motor mounts for my groupN's?!
IIdiceII is offline   Reply With Quote
Old 01-31-2009, 04:28 PM   #15
rexworx
Member Sales Rating: (66)
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
This is one of the best feeling mods you can do. really connects the car.
Makes some NVH But its hard to say how much because ive replaced "EVERY SINGLE" bushing in the car front to back with either Kartboy, whiteline, or super pro poly bushings and subframe locking bolts Etc.
Glad your happy with your purchase...
Ian,
rexworx is offline   Reply With Quote
Old 01-31-2009, 07:45 PM   #16
GimmickMotorsports
Vendor Sales Rating: (10)
Member#: 39592
The new act to
follow.... Get in line...
In having installed these and others yes, they are all a PITA to swap especially on the ground. The 2 rear bolts are the worst of all and very hard to reach, not to mention the danger involved by sticking your hand between the engine and crossmember to get to them.
The STI mounts are a bit easier to get in than the Cuscos but both are great as an upgrade.
the Cusco's seem to have a longer section where the lower bolt is and make it a tighter squeeze.
I think this is a nessesary upgrade for anyone that drives, shifts and corners agressively.
__________________
Nino
Gimmick Motorsports
[SIGPIC]http://forums.nasioc.com/forums/signaturepics/sigpic39592_2.gif[/SIGPIC]
GimmickMotorsports is offline   Reply With Quote
Old 02-02-2009, 10:14 AM   #17
Kiwi Fella
Member Sales Rating: (4)
Member#: 27323
2000 RSTi
Just had these installed on the legacy. Vibration is pronounced when you are going from 1rpm - 2k rpm but after that it disappears
Kiwi Fella is offline   Reply With Quote
Old 04-15-2009, 06:54 AM   #18
KLBOWRX
Member Sales Rating: (1)
Member#: 143159
Is the general thought that the cusco engine and transmission mounts too harsh for a DD?
Im really debating between these and the group N mounts.
KLBOWRX is offline   Reply With Quote
Old 04-15-2009, 11:59 AM   #19
bzbuzz
Member#: 116052
2011 STI ( Sold )
if you really worry about harshness, i would go with grp N.
Old 04-16-2009, 10:11 AM   #20
PolarisSnT
Member#: 85905
2004 WRX
Ive had my Cusco set in the car for 2 years now and I love them. Very firm feeling but not overly harsh.
Install is not terrible. A rathceting-offset wrench makes the process a lot easier. When I did mine I used a standard offset box wrench and it was slow going but if I had a gear wrench type it would of been a lot easier. Took about 3 hours when I did it but with the right tools 1.5 to maybe 2 hours tops.
PolarisSnT is offline   Reply With Quote
Old 04-16-2009, 12:31 PM   #21
gotsol
Member#: 17346
08 Cayman S
I've still got the scar on my index finger to prove that is a bad idea
gotsol is offline   Reply With Quote
Old 10-29-2010, 12:14 AM   #22
Hellish_STi
Member#: 216160
Install was easy, 30 mins tops. I don't like them for daily driving. I'm extremely picky about how the car rides and I don't like the Cusco's for that aspect, but I keep splitting the stock one's and group-n's at the track, so It's my only option. I get the vibration at idle to about 2K, then it comes back around 6K. Has anyone else gotten this? I think it may have to do with the harmonic balancer. I'm still using the stock one and it has 75K on it.
Hellish_STi is offline   Reply With Quote
Old 06-25-2015, 03:41 PM   #23
Fierysun
Member Sales Rating: (109)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Having had both Group-N and Cusco engine and tranny mount in the same car. I'm sold on the Cusco. The NVH isn't much more than the Group-N and at certain RPM's the car is smoother and quieter with the Cusco's. I use to get a drivetrain clunk on up shifts with the Group-N's, but not with the Cusco's.
Fierysun is offline   Reply With Quote
Old 07-15-2015, 11:19 AM   #24
BraveSTi
Member#: 262030
Had CUSCO engine/tranny mounts- They're good!
Now I have Beatrush(Laile) mounts- I like em better!
BraveSTi is offline   Reply With Quote
Cusco Motor Mount Install help 06 WRX DarkNiteTR Transmission (AT/MT) & Driveline 15 11-11-2008 05:42 PM
Cusco motor mount install question Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-20-2008 07:55 PM
Cusco motor mounts install, should i swap spt plate? drrice Transmission (AT/MT) & Driveline 1 06-09-2006 08:09 PM
Cusco Motor Mount Set WRX/STI simprezl25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-24-2006 10:15 AM
Cusco Motor mounts Spectre23 Normally Aspirated Powertrain 3 11-22-2000 08:39 AM
