Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 07-15-2010, 02:30 PM   #1
Demon2003
Member#: 129983
2007 STI
Default Omni Power 4bar map Sensor
Anyone have the mulitplier and offset for the omni power 4 bar map sensor
Demon2003 is offline   Reply With Quote
Old 07-15-2010, 11:27 PM   #2
Demon2003
Member#: 129983
2007 STI
Really no one has this? I am surprised for a bolt on plug and play map sensor that is only $30 more then the GM unit and looks OEM i figured someone had it. I wasn't going to buy it until i had the settings because i didn't want to do it myself out of pure lazyness but maybe i will
Old 07-16-2010, 06:58 AM   #3
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
If you want to mail me your omni power I can get the numbers for you and then mail you back the sensor. I run the aem sensor so I really don't need to buy an omni.
fastblueufo is offline   Reply With Quote
Old 07-17-2010, 10:25 AM   #4
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
Try evolutionm.net. If you can't find it on there pm me I tune evos and use that map sensor. I'll try to post them up when I get on my laptop
mxturboracer86 is offline   Reply With Quote
Old 07-17-2010, 08:31 PM   #5
HOLLYW00D
Member#: 44954
2004 FXT
HOLLYW00D is offline   Reply With Quote
Old 07-18-2010, 04:44 AM   #6
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
One of the guys on RomRaider has an omni power map sensor - go post over their and I am sure he will reply when he sees it.
Leslie
wrxsti.l is offline   Reply With Quote
Old 07-27-2010, 11:51 PM   #7
Demon2003
Member#: 129983
2007 STI
4 BAR
Multiplier = 11.97 psia/V
Offset = +0.506 psia
3 BAR
Multiplier = 9.119 psia/V
Offset = +0.164 psia
Big thanks to MRF582 on RR for the information
Old 07-28-2010, 02:36 PM   #8
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
I just got a new omni-map sensor on my new build,and it failed on me.
I wouldnt try another one.
jsnm is offline   Reply With Quote
Old 07-28-2010, 02:52 PM   #9
Demon2003
Member#: 129983
2007 STI
Ill keep an eye on mine
Old 07-28-2010, 02:54 PM   #10
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
I seriously would,i was thrilled when i found one,but as soon as i got on the dyno it was throwing codes.maybe just got a faulty one.
Old 08-13-2010, 05:30 PM   #11
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Other than Omni what are the current nonadapter alternatives?
turboICE is offline   Reply With Quote
Old 08-20-2010, 01:46 AM   #12
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Was it used/secondhand? What do you mean by "when I found one"?
I just find your posts a little odd that's all, as many ppl use the omnipower MAP sensors without any problems...
Old 08-22-2010, 01:21 PM   #13
adeliciouspizza
Member#: 7844
05 STI CGM 450whp
05 FXT CGO Stock
I am running a 4 bar Omni. When I first put it on it was throwing codes. Turns out the Omni runs a lower "minimum voltage" than the stock sensor. The stock ecu programming will throw a code below .25 volts or so (check a stock rom to see what I mean). I changed it to .05 volts and re-flashed and I haven't had a single problem with it after that. It reads spot on with my boost gauge using the calibration posted above.
adeliciouspizza is offline   Reply With Quote
Old 08-23-2010, 02:17 PM   #14
Demon2003
Member#: 129983
2007 STI
Yea I'm having 0 issues with mine the voltage does need to be changed. i am also getting a accurate reading with the above settings.
Old 09-09-2010, 05:56 AM   #15
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
I would like to use this omni power map sensor with my MY02 WRX EJ205 engine. Is it plug&play? I know that I have to change the correct value to my rom.
Thanks.
imppu2001wrx is offline   Reply With Quote
Old 09-09-2010, 02:27 PM   #16
Demon2003
Member#: 129983
2007 STI
Thanks.
Its the same sensor so yes it is plug and play. Mine has 0 issues just remember to change the minimum voltage.
Old 09-10-2010, 02:41 AM   #17
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
Applications: 2004-2007 Subaru STI
My map sensor looks little bit different.. are you sure that this omni power map sensor fits to older MY02 WRX intake manifold? Thanks.
Old 10-01-2010, 03:18 AM   #18
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
So I finally got my 3bar omni power map sensor. I tried to change the multiplier and offset but it is not possible to use positive offset in my 16bit ECU
3 BAR
So I have a useless map sensor right now..
Old 10-01-2010, 11:30 AM   #19
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
3 BAR
Does it mechanically bolt up? .164 psi is pretty insignificant. Can you just set it to zero (I'd check myself by I don't have my laptop with me)? So more or less, your pressure read out would always be .164 psi lower than actual. I don't see that as being much of a problem.
thefoos is offline   Reply With Quote
Old 10-01-2010, 01:48 PM   #20
reid-o
Member#: 103631
2004 STI
Gray
This worries me as I plan to use this map sensor for speed density.
reid-o is offline   Reply With Quote
Old 10-03-2010, 04:12 AM   #21
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
Does anyone know the reason why the offset cant be positive when using 16bit ECU? Yes it is possible to set it to zero. I just would like to use the correct values.
Old 10-04-2010, 12:33 PM   #22
fastblueufo
Member#: 212154
02 billet crank
I tuned the omni 4bar on a 16bit and zeroed out the offset. The car is on the sd group n rom and it exhibited a high idle (1500rpm ) with the omni sensor installed. We even put a different o-ring on the sensor because we thought it was leaking to cause a high idle. Afr was spot on and trim was within 5%. Put the stock sensor back on and it idled normal.
Old 10-06-2010, 06:16 AM   #23
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
Yesterday I tested this omni power 3bar map sensor in my car. I zeroed out the offset. It worked nicely on 16 bit but the high idle was the reason I took it off. In my case the high idle was 1300rpm.
So question is what is causing this high idle? Otherwise it looks like you could use omni map on 16 bit. Manifold pressure direct was almost the same as stock with zero offset. Very small difference.
Old 10-06-2010, 08:00 AM   #24
fastblueufo
Member#: 212154
02 billet crank
Is the ground wire from the map tied in with the ground from the iacv? They are in the same part of the harness. Maybe the omni is causing electrical interferance with the ground on the iacv if they are tied in together.
Old 11-15-2010, 12:47 PM   #25
Bamofo
Member#: 159743
07 STI Limited
TurboMike Tuned 2.35
just as an update to an older thread the settings in here work perfect the way they were displayed originally. idle is normal on the car and required no other changes, other then the boost tables.
Bamofo is offline   Reply With Quote
Omni Power Stock location Map Sensor 3bar 4bar 7bar TopSpeed Engine Management 79 06-15-2011 05:46 AM
Weird idea--3bar/4bar map sensor on stock ECU? HamFist Engine Management & Tuning 5 12-28-2009 12:46 AM
FS (NY): TurboXS UTEC Delta v03 + TXS 4BAR MAP Sensor + Remote Map Switch bbong Engine/Power/Exhaust 5 04-08-2008 05:46 PM
Omni Power Coilovers? SeattleWRX Brakes, Steering & Suspension 0 06-07-2005 05:48 PM
Any one vouch for Omni Power coilovers? dubba you are ex Brakes, Steering & Suspension 15 03-19-2005 08:54 AM
