Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 06-03-2011, 11:54 AM   #51
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
try logging MAP instead of MRP and subtracting off absolute pressure after the fact. Some of the MRP parameters have internal limits in the ECU. I know one of them saturates at ~18 psi.
Old 06-03-2011, 03:52 PM   #52
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ok that sounds good. I will give it a go after work tonight.
medamullet is offline   Reply With Quote
Old 06-06-2011, 02:06 PM   #53
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I logged everything. my AP is 12.48 where I am at. When I do the math and log everyting else it comes out around the same. I am afraid to turn up the boost any more in fear of blowing it up. Both 3rd and 4th gear logs have the exact same peak boost. I know that can't be right. Any help would be great....
Old 06-06-2011, 10:14 PM   #54
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
isn't the pressure output from the stock ECU constrained to ~24 psi, even though the sensor can be changed so it reads higher and the ECU uses the actual higher pressures?
Frank A is offline   Reply With Quote
Old 06-07-2011, 07:58 AM   #55
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
If the correct peram is logged then the only constraint is within the sensor itself. If you are logging a 16 bit you should log mrp direct, if you are logging a 32 bit you should log mrp 4 bit. If the correct peram is logged and you still can't log correct boost then
1) the multiplier/offset is incorrect
2) the sensor itself is the limit.
The AEM 3.5 bar has no problems with being logged correctly. I have only tried the omni on a 16 bit, it would not work on the 16 bit for whatever reason. If someone wants to mail me there omni I will mess with it on a 32 bit but, I'm not going to drop my dime on one just for testing. I personally recommend the AEM over the omni from experience.
fastblueufo is offline   Reply With Quote
Old 06-07-2011, 09:35 AM   #56
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
I haven't heard of any issues with the Perrin/Omni unit and I was getting ready to buy one because its so easy to install. Can you expand on what you experienced with it?
Old 06-07-2011, 09:52 AM   #57
fastblueufo
Member#: 212154
02 billet crank
As I stated, my only experience was on a 16 bit ecu. The car had a high idle (1500 rpm). I changed different o-rings and tried a few different multipliers/offsets, nothing would correct the high idle. I'm not sure about a 32 bit ecu if the same problem would persist.
Old 06-07-2011, 10:01 AM   #58
Nuke209
Member#: 108089
2003 WRX
NF Performance
32bit are fine.
I've tuned one on the 04sti (4bar one) using Perrin's values. Working fine
Nuke209 is offline   Reply With Quote
Old 06-07-2011, 03:39 PM   #59
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
It runs just fine. When I log it seems to be peaking around the stock values. I will post up a long on my way home.
Old 06-13-2011, 04:23 PM   #60
wayfastwhitey517
Member#: 242460
2007 wrx tr
obp
is there any issues with using the 4 bar on a 07wrx?
wayfastwhitey517 is offline   Reply With Quote
Old 06-13-2011, 05:58 PM   #61
Nuke209
Member#: 108089
2003 WRX
NF Performance
should be just fine. it's also 32bit
Old 06-13-2011, 07:20 PM   #62
wayfastwhitey517
Member#: 242460
2007 wrx tr
obp
i have the 4 bar on the wrx and i'm using atr for tuning and i set the offset and multiplier to .506 and 11.98 and while cold the car runs fine but warmed up it idles at 400 and dies. any help would be appreciated.
thanks
joe
Old 06-13-2011, 07:59 PM   #63
Nuke209
Member#: 108089
2003 WRX
NF Performance
thanks
joe
sure you don't have a leak?
if you put the stock map sensor and calibrations back, does it happen?
Old 06-13-2011, 08:06 PM   #64
wayfastwhitey517
Member#: 242460
2007 wrx tr
obp
it runs almost fine. the stocker was broken so it doesnt go into the tb very much 1/8" but at idle it feels and sounds normal... 4 bar and remapped and it runs like crap. ive been looking for a leak for 3 hours so i dont think there is one ive also returned the sensor for a new one incase the first one was defected
Old 07-18-2011, 11:55 PM   #65
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
ok I looked everything that has to do with air pressure let me know what's going on. my gauge reads 27psi peak. I checked it with my air compressor up to 40psi and the gauge and the compressor reads the same.
Code:
Time	RPM	WOT	MAP (4-byte)* (psi absolute)	MRP (4-byte)* (psi relative)	AP (psi)	MAP (psi)	MRP (psi)	MRP (Corrected) (psi)	MRSLP (4-byte)* (psi relative sea level)	MA (g/s)	MASV (V)
0	2148	8.24	4.67	-7.98	12.62	4.64	-7.98	-7.98	-10.03	12.18	1.56
221	2160	26.27	6.01	-4.91	12.62	7.69	-5.95	-6.67	-8.69	25.53	2.12
445	2192	100	12.87	0.26	12.62	12.91	0.29	0.29	-1.82	41.55	2.38
664	2328	100	13.33	0.74	12.62	13.35	0.73	0.73	-1.37	44.52	2.42
898	2481	100	13.77	1.18	12.62	13.78	1.16	1.16	-0.92	47.82	2.52
1113	2538	100	14.24	1.67	12.62	14.36	1.74	1.6	-0.45	50.68	2.5
1349	2644	100	14.76	2.2	12.62	14.8	2.18	2.18	0.06	55.32	2.66
1575	2776	100	15.37	2.76	12.62	15.38	2.76	2.76	0.67	61.4	2.62
1804	2943	100	16.1	3.56	12.62	16.25	3.48	3.48	1.41	73.1	2.8
2035	3013	100	17.03	4.49	12.62	17.12	4.5	4.5	2.34	80.41	2.92
2259	3184	100	18.15	5.61	12.62	18.28	5.51	5.51	3.46	87.34	3.04
2476	3355	100	19.47	7.03	12.62	19.73	6.96	6.96	4.77	99.79	3.14
2713	3468	100	21.36	8.95	12.62	21.62	8.85	8.85	6.66	113.39	3.32
2943	3714	100	23.85	11.45	12.62	24.38	11.32	11.32	9.15	150.41	3.54
3157	4013	100	27.32	15.1	12.62	27.86	14.95	14.8	12.62	180.68	3.8
3380	4196	100	31.49	19.41	12.62	32.21	18.43	19.15	16.8	233.36	4.06
3616	4501	100	35.21	22.95	12.62	35.69	18.43	22.64	20.51	282.45	4.2
3827	4810	100	36.38	23.94	12.62	36.71	18.43	23.8	21.68	301.82	4.32
4060	5207	100	36.17	23.48	12.62	35.98	18.43	23.51	21.47	304.74	4.36
4303	5471	100	35.46	22.77	12.62	35.4	18.43	22.93	20.77	324.48	4.4
4526	5805	100	35	22.41	12.62	35.11	18.43	22.35	20.31	331.14	4.44
4761	5995	100	34.8	22.14	12.62	34.68	18.43	22.2	20.1	334.9	4.46
4979	6291	100	34.65	22.01	12.62	34.68	18.43	22.05	19.95	336.77	4.46
5214	6574	100	34.71	22.1	12.62	34.68	18.43	22.2	20.01	334.48	4.46
5438	6811	100	34.92	22.09	12.62	34.82	18.43	22.35	20.22	327.01	4.42
5658	6921	100	35.06	22.28	12.62	35.11	18.43	22.35	20.37	341.71	4.52
5894	5944	26.27	27.43	11.4	12.62	22.2	12.33	13.49	12.74	184.91	3.74
6120	5350	10.59	5.82	-7.25	12.62	5.22	-7.11	-6.96	-8.88	9.12	1.4
6344	4851	9.8	3.72	-9.1	12.62	3.48	-9.14	-9	-10.97	19.36	1.74
6569	4474	9.02	3.07	-9.59	12.62	3.05	-9.58	-9.58	-11.62	14.74	1.66
6787	4098	8.24	2.97	-9.63	12.62	2.9	-9.58	-9.58	-11.72	13.73	1.62
7025	3814	9.02	3.15	-9.4	12.62	3.19	-9.43	-9.43	-11.55	13.8	1.62
7255	3436	10.59	4.02	-8.54	12.62	4.06	-8.56	-8.56	-10.68	17.54	1.72
7480	2836	9.8	4.68	-7.97	12.62	4.64	-7.98	-7.98	-10.01	17.34	1.72
Old 07-19-2011, 12:03 AM   #66
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
I know it's jacked up, but quote it and paste it into excel. If I change the headings to much you won't be able to tell what you are actually looking at.
regardless what ever value you minus absolute pressure you don't get 27 psi anywhere. WHAT GIVES?
Thanks
Old 08-19-2011, 12:12 AM   #67
dub c
Member#: 145069
Keep It Sleazy
Regarding the problems with the MAP sensors in Wrx's...
Does the problem lye with the ECU's being 16 bit's or does it lye with the style of the intake manifold mount itself?
I will be using a JDM V7 Sti ECU (32 bit) with my 02/03 Wrx, so I'm wondering if I will have the same idling problem...
dub c is offline   Reply With Quote
Old 08-22-2011, 10:35 PM   #68
lil'redwagon
Member#: 10854
'02 WRX; '08 OBXT;
'08 G37 (S/C'd); '09 XF
jdm v7 ecu's are 16 bit. at least my v8 is. i'm guessing it's not going to work for you.
lil'redwagon is offline   Reply With Quote
Old 10-04-2011, 06:56 AM   #69
Nisstrust
Member#: 255202
The Perrin link to their instructions is down, anyone got a copy on their PC? that they can host?
http://www.perrinperformance.com/sha...mapsti4bar.pdf
Nisstrust is offline   Reply With Quote
Old 01-14-2012, 07:12 PM   #70
rasheedn
Member#: 123333
2009 STi
DMG
im confused!
which one should i use with my 08 STi and 4 bar sensor
rasheedn is offline   Reply With Quote
Old 05-05-2012, 02:33 PM   #71
jays05
Member#: 78165
05 STI 35r + e85
I installed the Omni 4bar map sensor in my 05 STI today. I couldn't find any numbers on here or elsewhere for the TXS UTEC. I ended up with:
Gradient 234
Intercept 140
For the ECU I am using the numbers from Perrin and they seem pretty much dead on.
jays05 is offline   Reply With Quote
Old 05-05-2012, 03:52 PM   #72
renosubby
Member#: 152576
2009 GTR [email protected] 133
Mayhem Tuning!!!!!
mine: It reads -.029 when the car is in the ACC position.
Offset (psia) 0.5279371056703949
Multiplier (psia/v) 11.63202077500488
Hope this helps everyone.
Cory
renosubby is offline   Reply With Quote
Old 06-04-2012, 03:55 PM   #73
JustD
Member#: 180517
06 WRX Wagon
So what are the proper values for 3 Bar Omni Power MAP using the Cobb AP2 ?
Is this right or was it decided the numbers are off ?
http://forums.nasioc.com/forums/show...46&postcount=7
JustD is offline   Reply With Quote
Old 10-13-2012, 02:34 PM   #74
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I'm using the 4bar on my 05 sti. Using the values posted on the first page - my car barely can start and instantly wants to die and I get the p0107. Why would my car work any differently? I made double sure the values were entered correctly. I soon as I go back to stock setup it starts right up and runs like you would expect.
edit.......woops missed this, it actually worked.
Originally Posted by adeliciouspizza View Post
I am running a 4 bar Omni. When I first put it on it was throwing codes. Turns out the Omni runs a lower "minimum voltage" than the stock sensor. The stock ecu programming will throw a code below .25 volts or so (check a stock rom to see what I mean). I changed it to .05 volts and re-flashed and I haven't had a single problem with it after that. It reads spot on with my boost gauge using the calibration posted above.
TyranosaurusWRX is offline   Reply With Quote
Old 11-29-2012, 04:47 PM   #75
f85stealth
Member#: 133492
2006 Legacy Spec.B
I drive a Subaru Legacy that has been fully built for quite sometime now. I recently decided to take it to the next level with a bit larger turbo (20g), injectors, pump, meth, ebcs...... you know the fun stuff.
It has been to two shops so far and no one has seemed to get the car to run right. So it has been inoperable for 8 months.
I recently reached out to Nasioc and I got a wealth of people trying to help and even some local, which I greatly appreciate.
I provided a data log from my Cobb v2 AP to 3 of these new separate "tuners" that i found and they all came back with my tune was way off but this is a comment I have always heard about my car and it ran fine before.
However, one of them mentioned I needed to add this 4bar map sensor. I mean the thing is cheap so I am all for trying it but what exactly does it do and why do I need it? I didn't know many people did this type of an upgrade.
Just trying to grow my knowledge a little bit. Thanks!
f85stealth is offline   Reply With Quote
Omni Power Stock location Map Sensor 3bar 4bar 7bar TopSpeed Engine Management 79 06-15-2011 05:46 AM
Weird idea--3bar/4bar map sensor on stock ECU? HamFist Engine Management & Tuning 5 12-28-2009 12:46 AM
FS (NY): TurboXS UTEC Delta v03 + TXS 4BAR MAP Sensor + Remote Map Switch bbong Engine/Power/Exhaust 5 04-08-2008 05:46 PM
Omni Power Coilovers? SeattleWRX Brakes, Steering & Suspension 0 06-07-2005 05:48 PM
Any one vouch for Omni Power coilovers? dubba you are ex Brakes, Steering & Suspension 15 03-19-2005 08:54 AM
