Welcome to the North American Subaru Impreza Owners Club Monday October 14, 2019
Old 05-28-2013, 02:56 AM   #101
imppu2001wrx
Member#: 137499
2002 STi Wagon 60-1
How do you set positive offset on 16bit ECU?
imppu2001wrx is offline   Reply With Quote
Old 09-14-2013, 08:18 AM   #102
peglegsteve
Member#: 209987
2009 Slow WRX
Slower Prius
My tuner told me my factory sensor needed replacing, as it was reading incorrectly. Installed this, adjusted the values...and it didn't start.
peglegsteve is offline   Reply With Quote
Old 01-30-2014, 07:12 PM   #103
delmardale
Member#: 122349
2008 Outback XT
Gray
Originally Posted by Clark Turner View Post
32 Bit 2.5 ECU:
OmniPower 3 bar (Part #MAP-STI-3BR) -> MULTIPLIER = 9.122 psi, OFFSET = 0.164 psi
OmniPower 4 bar (Part #MAP-STI-4BR) -> MULTIPLIER = 12.086 psi, OFFSET = 0.169 psi
16 Bit 2.0 ECU:
OmniPower 3 bar (Part #MAP-STI-3BR) -> MULTIPLIER = 9.123 psi, OFFSET = 0.155 psi
OmniPower 4 bar (Part #MAP-STI-4BR) -> MULTIPLIER = 12.085 psi, OFFSET = 0.174 psi
Lots of failed 4 Bars. Never a failed 3 bar. Use 3 bar unless you are going over 35 psi. better resolution for SD.
C
Sorry for the braindead question here. I have AccessTuner Race. If I get the OmniPower 3 bar, do I simply need to go in and set the Multiplier and Offset? The screen for the multiplier looks like this. Seems odd that stock is 0.686 and should be replaced with 9.123. I was wondering if there was some other conversion I'm missing. Thanks for any help. The reason I need the new MAP sensor is I recently got tuned at 23 PSI and car's now throwing a P0108. If I can easily update the tune myself that will save me a trip back to the Tuner.
delmardale is offline   Reply With Quote
Old 01-30-2014, 07:24 PM   #104
Clark Turner
Member#: 178047
02 WRX STI Spec C
Yes. That is correct. The sensor is a large change. Just enter the mult and the offset. Save file, Reflash to car.
C
Clark Turner is offline   Reply With Quote
Old 01-30-2014, 07:26 PM   #105
delmardale
Member#: 122349
2008 Outback XT
Gray
C
Appreciate the quick response man.
Old 01-30-2014, 07:27 PM   #106
Clark Turner
Member#: 178047
02 WRX STI Spec C
Anytime man. Good luck
Old 07-22-2014, 10:21 AM   #107
fzturbo
Member#: 43482
2004 JDM 2 litre STI
Sorry to bring this post back from the grave but i have a problem with the omni power 4 Bar MAP. I installed it on an MY08 EDM STI, seted up the multiplier at 0.833 and offset to 0.012 (ecuflash is in BAR), lowered the low input voltage to avoid the cel and it reads great. iddles perfect but when logging with romraider, it still reads up to 23 psi and nothing further even when the turbo is at 28 psi read with an AEM boost gauge.
Am is missing something?
Hope to get some usefull input.
Regards.
fzturbo is offline   Reply With Quote
Old 07-22-2014, 11:28 AM   #108
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Are you logging with the correct manifold pressure setting? One of them wont go past 23psi when logging. I believe I use Manifold Relative Pressure (4-byte) for my 05 STi...that's off the top of my head, might need someone to confirm that.
TyranosaurusWRX is offline   Reply With Quote
Old 07-22-2014, 11:48 AM   #109
marangua
Member#: 248833
I have the exact same reading from my 08 STI, same multipliers, whit AEM gauge reading up to 28 psi and the log upo to 23psi every time.....did you figure it out??
Regards.
marangua is offline   Reply With Quote
Old 07-22-2014, 01:27 PM   #110
fzturbo
Member#: 43482
I only tested with MAP relative 4-byte. I'll give a try logging with all the MAP sensor options.
Regards.
PS: Marangua, that might be your problem too. Try logging and give us some feedback.
Old 08-01-2014, 08:05 AM   #111
methaddict
Member#: 159738
2004 WRB STi 620awhp
OFCD V3, FR TS, BW8374EFR
Since this thread was bumped: I like the AEM 3.5 bar the best out of all of the sensors. I dont use the Omni much anymore if I can help it. I have not used the perrin so I cannot comment on it yet.
C
Clark, have you had problems with the AEM 5 bar sensor? It runs about the same price as the 3.5 bar. It's for my Borg Warner 8375 EFR build.
methaddict is offline   Reply With Quote
Old 08-01-2014, 11:58 AM   #112
Clark Turner
Member#: 178047
02 WRX STI Spec C
I would run the 3.5 bar Stainless model for E85 use. The Brass one is ok for gasoline. But will fail with E85. I would not run the 5 bar unless you planned on maxing the 3.5 out with serious boost.
C
Old 08-01-2014, 04:14 PM   #113
methaddict
Member#: 159738
C
Thanks Clark, when am I really going to tune past 50 psi anyway. I have another question for you, I'll be running dual Aeromotive in tank fuel pumps. Are these able to take E85? I opted to do this to keep it stealth as opposed to a swirl pot setup.
Old 08-01-2014, 05:00 PM   #114
Clark Turner
Member#: 178047
02 WRX STI Spec C
I would not use the 340 with E85. They suggest changing the filter every 10 hours. This makes no sense. I think they use this to get away from warranty claims with E85 failures.
On your car, I would use a single walbro 460 fuel pump. Install new bulk head fittings onto the factory fuel pump hanger for 10 or 12 AWG wire. DO NOT use the factory wire and plug. Use 10AWG from battery to 50 amp relay. Or a 70 amp relay if you get a good one. Cheap 50 amp relays run hot with this pump.
If the car is over 550whp, I suggest you use a -8 bulk head fitting and install that on the factory pump hanger. Do not use the factory small metal fitting. Its a serious restriction.
I would completely remove the factory fuel pump controller from the car. Use the power feed to that controller to turn the relay on. Cobb AP has the ability to properly tune and delete the factory fuel pump controller.
C
Old 09-15-2019, 07:08 PM   #115
Red_wrx18
Member#: 498844
Default Omni Power 4 Bar MAP sensor on 18 WRX
Hey guys, ive been trying to get the calibrations for this sensor, but as of right now i can only think of trying out the offsets and multiplier combinations that ive seen in this post. do you guys happen to know if there is any other? to add it to the list. as off right now i have this ones to try.
OFFSET psia/ MULTIPLIER psia/V
0.506/ 11.98
0.506/ 11.97
0.504/ 11.982
0.5279371056703949/ 11.63202077500488
0.168/ 12.087
0 / 12.087
0.174/ 12.085
0.012/ 0.0833
Red_wrx18 is offline   Reply With Quote
Old 09-16-2019, 07:53 AM   #116
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
0.506/11.98
0.506/11.97
0.504/11.982
0.5279371056703949/11.63202077500488
0.168/12.087
0 / 12.087
0.174/12.085
0.012/0.0833
This works for my 16b in so far
12.78 multiplier
-2.9 offset
I run 35psi no problem
gaby is offline   Reply With Quote
Omni Power Stock location Map Sensor 3bar 4bar 7bar TopSpeed Engine Management 79 06-15-2011 05:46 AM
Weird idea--3bar/4bar map sensor on stock ECU? HamFist Engine Management & Tuning 5 12-28-2009 12:46 AM
FS (NY): TurboXS UTEC Delta v03 + TXS 4BAR MAP Sensor + Remote Map Switch bbong Engine/Power/Exhaust 5 04-08-2008 05:46 PM
Omni Power Coilovers? SeattleWRX Brakes, Steering & Suspension 0 06-07-2005 05:48 PM
Any one vouch for Omni Power coilovers? dubba you are ex Brakes, Steering & Suspension 15 03-19-2005 08:54 AM
