Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 04-26-2018, 08:23 PM   #251
mikeyPSF
Member#: 236475
I didn't get a notification of a reply either. That's odd. I'll try to see if I can figure this out tomorrow for you. Yes, I do recall us swapping a support email last week.
mikeyPSF is offline   Reply With Quote
Old 04-27-2018, 09:31 AM   #252
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Thanks!
I'm anxiously awaiting my DLP....
TyranosaurusWRX is offline   Reply With Quote
Old 04-30-2018, 07:03 PM   #253
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
My 05 ECU is unbricked (albeit not worth much atm) and my 04 is unCobbed, I'm super grateful! After 7 years this thread still provides.
Old 04-30-2018, 08:35 PM   #254
teds-rex
Member#: 400886
2004 STi
Originally Posted by TyranosaurusWRX View Post
Actually that was my original ecu, I have an 05. There are about 6 different wires to move to make the 04 work per the pinouts. So to clarify, the 05 ecu is burnt, the 04 from the scrap yard appears to be locked.
Yeah but I don't think that the 04 is "locked"... The 04 didn't have an emobilizer and the 05 does, so not sure on compatibility.
teds-rex is offline   Reply With Quote
Old 04-30-2018, 09:23 PM   #255
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Yeah the 04 was locked. I couldn't even connect to it via ecuflash, it would reject it every time. I can ID it now and I flashed my speed density map. The car is running on the 04 as we speak. With the 04 not having the immobilizer it bypasses it in the newer models as long as you rewire the harness per the 2004 pinouts, which was 6 wires. You just cant go the other way, and use a 2005+ without the chipped key, key barrel, and immobilizer box to go with it.
Old 06-28-2018, 09:01 PM   #256
Scotty4
Member#: 487723
Anyone still available to unbrick a 2004 STI ECU? I haven't got the time to build a kit.
Scotty4 is offline   Reply With Quote
Old 07-12-2018, 07:45 PM   #257
MadmanSean
Member#: 488256
Hi Scotty, this may or may not help you.
I'm able to do this, however i'm located in Australia. For anyone that might be interested and needs help with a bricked ECU please feel free to PM me
Here's a link to more Info: Subaru ECU Unbrick, Unlock, Recovery Service
http://forum.liberty.asn.au/viewtopic.php?f=56&t=35489
MadmanSean is offline   Reply With Quote
Old 07-12-2018, 09:14 PM   #258
teds-rex
Member#: 400886
2004 STi
Where are you located? No info in your profile
Old 07-23-2018, 05:23 PM   #259
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
04 WRX 16 Xtrek
19 XSR900
Had an interesting one today. 2011 WRX. Tried using FDT and got the following:
Code:
Configuration:
'BOOT Mode' connection - using emulated interface
Opening port 'COM3' ...
Loading Comms DLL
Loaded Comms DLL
Initiating BOOT SCI sequence
Attempting 9600
Received immediate response from device: 0x80
Attempting 4800
Attempting 2400
Attempting 1200
Error No 15024: Boot failed
Error No 16132: Device does not support Protocol C
The board on this ECU is different from others I've done. I gave the ECUFlash SH boot mode recovery a shot but I got an error about
there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
This is the 2nd ECU that I've had troubles reflashing. Has anyone seen a similar issue?
Noah is offline   Reply With Quote
Old 09-13-2018, 10:24 PM   #260
badfrogg
Member#: 376447
2004 Legacy GT
Trying to unlock a Cobb/ECUtec Flash on my 08 WRX. I bought the car with this already done and it is running very poorly. No shops around me will unlock it.
was wondering if I can use FT232R board. If so what pins on this board do i jumper? they are not quite the same names.
badfrogg is offline   Reply With Quote
Old 09-18-2018, 12:20 PM   #261
rozsko
Member#: 442541
First of all, thanks for all the information contained in this thread.
I already had to unbrick my ecu twice and I thought to share an updated schematic for UM232R as 232M is not available any more.
UM232R has a little more components and features built into it, so the circuit is more simple overall as there are less external components.
For me Ecuflash did not work, but Reneas FTD worked like charm.
Also, I did not want to mess with powering the ECU externally, so I did the whole process while the ECU was connected to the car.
rozsko is offline   Reply With Quote
Old 09-23-2018, 12:35 AM   #262
MichaelStansell
Member#: 489489
2010 Impreza 2.5i
Subaru Stars electrical malfunction
My Impreza 2.5i Premium will not crank. The engine temperature "dummy light" on the dash is alternately flashing blue and red. All the lights on the dash illuminate when the key is turned to the ON position. Also, my generic OBD II scanner, which used to connect without issue to the car no longer displays it's initial screen when connected to my OBD II port.
What does the alternating blue/red flashing coolant light on the dash indicate? I emailed SOA and they quoted the owner's manual back to me saying that there "may be an electrical malfunction." Hoping someone has some experience to provide a more concrete idea about what to check.
Yes, I can take it to a dealership for diagnosis if I must, but my experience with the local dealership has been poor in the past.
MichaelStansell is offline   Reply With Quote
Old 09-25-2018, 01:01 PM   #263
legacy_majdi
Member#: 491919
Originally Posted by The board on this ECU is different from others I've done. I gave the ECUFlash SH boot mode recovery a shot but I got an error about
[IMG
https://i.imgur.com/5REUHYs.png[/IMG]
Any solution for these type of ecu? I got one and it wont work with SH Boot. Do you mind to share FDT software?
legacy_majdi is offline   Reply With Quote
Old 09-29-2018, 09:15 PM   #264
kasipong
Member#: 492098
Anybody have link Flash Development Toolkit for 7055?
Renesas can't download.
Thanks for help
kasipong is offline   Reply With Quote
Old 10-03-2018, 09:36 PM   #265
MadmanSean
Member#: 488256
Edit: All the test points are there, you're doing something wrong. I've successfully flashed this type of ecu many times.
Check the file size of the rom you are trying to flash make sure it is 1MB file.
Old 10-21-2018, 06:47 PM   #266
legacy_majdi
Member#: 491919
Flasing is ok, but somehow it got flashed with wrong version file. Now it bricked. And cannot be un brick. Do you have facing these type ecu bricked?
Old 08-16-2019, 01:21 PM   #267
surpip06
Member#: 399917
2013 STi
greay
Default MY06 help
Hello guys,
First off, thank you for all the info in this thread it has been very informative and helpful. I am trying to un brick my MY06 WRX and i think i have my board and connections done correctly but i think my .bin file might be wrong. i have tried programming both with ECUFlash and the Renesas FDT 4.09 below is the read-back i get from ECU Flash:
[11:46:20.303] J2534 API Version: 04.04
[11:46:20.303] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[11:46:20.303] Device Firmware Version: 1.16.4769
[11:46:20.303] Device Serial Number: TA3PWfF6
[11:46:24.942] sending bit rate sync bytes...
[11:46:26.836] no bit rate adjust response
[11:46:26.843] interface close
[11:46:43.452] FTDI Driver Version 2.12.28
[11:46:44.466] sending bit rate sync bytes...
[11:46:44.587] received bit rate adjust response
sending boot command
[11:46:45.113] got boot response
[11:46:45.255] 1 supported device(s):
[11:46:45.262] 0601 HD64F7058
[11:46:45.279] selecting device 0601
[11:46:45.534] 1 supported clock mode(s):
[11:46:45.541] 0
[11:46:45.553] selecting clock mode 0
[11:46:45.812] 2 supported clock type(s):
[11:46:45.819] 1 ratios for clock type 1
[11:46:45.827] x4
[11:46:45.835] 1 ratios for clock type 2
[11:46:45.842] x2
[11:46:45.982] 2 supported clock frequency range(s):
[11:46:45.990] 1 20000000-40000000
[11:46:45.998] 2 10000000-20000000
[11:46:46.134] 1 user boot MAT area(s):
[11:46:46.141] 1 00000000-00001fff
[11:46:46.284] 2 user MAT area(s):
[11:46:46.292] 1 00000000-0007ffff
[11:46:46.299] 2 00080000-000fffff
[11:46:46.440] programming unit is 128
[11:46:46.572] one MAT programming supported at 00000000
[11:46:46.585] setting baud rate to 62500
[11:46:46.850] there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
[11:46:46.873] interface close
And this is the feedback from FDT 4.09:
OS: Windows 7 [Non-Admin]
FCF Settings Applied: SH/7058F, (C:\Program Files (x86)\Renesas\FDT4.09\kernels\ProtC\7058\Renesas\1 _0_00\)
FDT API initialised: version 4, 09, 02, 000
Clock Frequency (External) = 10.0000MHz, Clock Mode = 0, CKM = 4, and CKP = 2
Connecting to device 'SH/7058F' on 'COM3'
Configuration:
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Received immediate response from device: 0xE6
Detected generic boot device
Sending inquiry for getting line size
Buffer size has been set to default (128 bytes)
Sending selection of device command
Selection of Device - Device selected, code 0601
Sending selection of clock mode
Selection of Clock Mode - Clock selected, code 0
Changing baud rate to 57600 bps
Set baud rate value = 57600
Determining block usage
Connection complete
Warning - download 06WRX stock dada.bin file which exceeds the flash ROM size of SH/7058F device.
Processing file :"C:\Users\surpip06\Desktop\06WRX stock dada.bin"
Loading image file : 'C:\Users\surpip06\Desktop\06WRX stock dada.bin'
Operation on User Flash
Loaded the Write operation module
Writing image to device... [0x00000000 - 0x000010FF]
Writing image to device... [0x00001180 - 0x000020FF]
Writing image to device... [0x00002180 - 0x00096E7F]
Writing image to device... [0x000BD980 - 0x000BEEFF]
Writing image to device... [0x000BF180 - 0x000BF4FF]
Writing image to device... [0x000C0180 - 0x000C96FF]
Writing image to device... [0x000C9700 - 0x000D0AFF]
Writing image to device... [0x000DB980 - 0x000DC67F]
Writing image to device... [0x000DF980 - 0x000DF9FF]
Writing image to device... [0x000FFC80 - 0x000FFCFF]
Writing image to device... [0x000FFD00 - 0x000FFFFF]
Data programmed at the following positions:
0x00000000 - 0x000010FF Length : 0x00001100
0x00001180 - 0x000020FF Length : 0x00000F80
0x00002180 - 0x00096E7F Length : 0x00094D00
0x000BD980 - 0x000BEEFF Length : 0x00001580
0x000BF180 - 0x000BF4FF Length : 0x00000380
0x000C0180 - 0x000C96FF Length : 0x00009580
0x000C9700 - 0x000D0AFF Length : 0x00007400
0x000DB980 - 0x000DC67F Length : 0x00000D00
0x000DF980 - 0x000DF9FF Length : 0x00000080
0x000FFC80 - 0x000FFCFF Length : 0x00000080
0x000FFD00 - 0x000FFFFF Length : 0x00000300
680.25 K programmed in 141 seconds
Image written to device
Both say that my original file is too large. but this is the stock file i pulled from my car before my computer crashed during tuning. Dose anyone have a stock file for SH7058 the would be willing to send me? or any suggestions for me to try? I also tested the outputs coming out of my board i have 144Hz come out going to P407 have correct power and ground and have continuity between the TX/RX to the 232 chip. thanks for the help
https://imgur.com/V98dOaX
https://imgur.com/cnI5uzP
surpip06 is offline   Reply With Quote
Old 08-16-2019, 03:40 PM   #268
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
You should be able to pull the stock ROM from here under he US section:
http://www.scoobypedia.co.uk/index.p...patibilityList
I believe A8DH201X is the most recent version.
Old 08-17-2019, 11:58 AM   #269
surpip06
Member#: 399917
2013 STi
greay
thanks for the response TWRX, so i downloaded that file and i got this message from ECUFlash i used the "w" version since i have an auto.
[11:08:31.045] using metadata XML ID A8DH200W from file C:/TACTRIX/EcuFlash/rommetadata/subaru/Impreza WRX/A8DH200W.xml
which inherits XML ID 32BITBASE from file C:/TACTRIX/EcuFlash/rommetadata/subaru/Bases/32BITBASE.xml
[11:08:31.045] ---notes for 32BITBASE---
2014/06/20 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014.
---notes for A8DH200W---
2014/05/22 [Tactrix] Tactrix definition auto cleaned|merged w/ RomRaiderGitHubAlphaMay2014.
[11:08:34.246] FTDI Driver Version 2.12.28
[11:08:35.532] sending bit rate sync bytes...
[11:08:35.669] received bit rate adjust response
[11:08:36.200] got boot response
[11:08:36.346] 1 supported device(s):
[11:08:36.354] 0601 HD64F7058
[11:08:36.377] selecting device 0601
[11:08:36.632] 1 supported clock mode(s):
[11:08:36.640] 0
[11:08:36.654] selecting clock mode 0
[11:08:36.958] 2 supported clock type(s):
[11:08:36.966] 1 ratios for clock type 1
[11:08:36.974] x4
[11:08:36.982] 1 ratios for clock type 2
[11:08:36.994] x2
[11:08:37.143] 2 supported clock frequency range(s):
[11:08:37.154] 1 20000000-40000000
[11:08:37.162] 2 10000000-20000000
[11:08:37.302] 1 user boot MAT area(s):
[11:08:37.309] 1 00000000-00001fff
[11:08:37.460] 2 user MAT area(s):
[11:08:37.468] 1 00000000-0007ffff
[11:08:37.476] 2 00080000-000fffff
[11:08:37.618] programming unit is 128
[11:08:37.753] one MAT programming supported at 00000000
[11:08:37.767] setting baud rate to 62500
[11:08:38.033] there are more memory areas in this CPU that will be erased than the ROM file you have has data for. write process aborted.
[11:08:38.058] interface close
On FDT however, the warning went away and it went through the programming but it still wont work.
Opening file C:\Users\surpip06\Desktop\read image_stock.bin
File loaded: 0x00000000 -> 0x000FFFFF [User Flash]
File loaded: 0x00000000 -> 0x00001FFF [User Boot Flash]
Configuration:
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Received immediate response from device: 0x12
Attempting 4800
Received immediate response from device: 0x01
Attempting 2400
Attempting 1200
Received immediate response from device: 0x42
Configuration:
Loading Comms DLL
Loaded Comms DLL
Attempting 9600
Connection complete
Processing file :"C:\Users\surpip06\Desktop\read image_stock.bin"
Loading image file : 'C:\Users\surpip06\Desktop\read image_stock.bin'
Writing image to device... [0x00000000 - 0x00000EFF]
Writing image to device... [0x00000F80 - 0x00001EFF]
Writing image to device... [0x00001F80 - 0x00096C7F]
Writing image to device... [0x000BD800 - 0x000BED7F]
Writing image to device... [0x000BF000 - 0x000BF2FF]
Writing image to device... [0x000C0000 - 0x000D097F]
Writing image to device... [0x000DB800 - 0x000DC47F]
Writing image to device... [0x000DF800 - 0x000DF87F]
Writing image to device... [0x000FFA80 - 0x000FFAFF]
Writing image to device... [0x000FFB80 - 0x000FFFFF]
0x00000000 - 0x00000EFF Length : 0x00000F00
0x00000F80 - 0x00001EFF Length : 0x00000F80
0x00001F80 - 0x00096C7F Length : 0x00094D00
0x000BD800 - 0x000BED7F Length : 0x00001580
0x000BF000 - 0x000BF2FF Length : 0x00000300
0x000C0000 - 0x000D097F Length : 0x00010980
0x000DB800 - 0x000DC47F Length : 0x00000C80
0x000DF800 - 0x000DF87F Length : 0x00000080
0x000FFA80 - 0x000FFAFF Length : 0x00000080
0x000FFB80 - 0x000FFFFF Length : 0x00000480
679.88 K programmed in 142 seconds
After i got the program in the ecu from FDT i started up ECUFlash and it will still not connect to the ecu. or accept a nother tune.
[11:15:54.815] J2534 API Version: 04.04
[11:15:54.815] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[11:15:54.815] Device Firmware Version: 1.16.4769
[11:15:54.815] Device Serial Number: TA3PWfF6
[11:15:57.488] kernel get version
[11:15:57.708] interface close
[11:15:57.761] J2534 API Version: 04.04
[11:15:57.761] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[11:15:57.761] Device Firmware Version: 1.16.4769
[11:15:57.761] Device Serial Number: TA3PWfF6
[11:15:58.056] VIN read not supported
[11:15:58.172] interface close
[11:15:58.211] J2534 API Version: 04.04
[11:15:58.211] J2534 DLL Version: 1.02.4798 Jun 13 2016 17:17:10
[11:15:58.211] Device Firmware Version: 1.16.4769
[11:15:58.211] Device Serial Number: TA3PWfF6
[11:15:58.387] SSM2 init
[11:15:58.807] SSM2 init
[11:15:59.222] SSM2 init
[11:15:59.659] SSM2 init
[11:16:00.107] SSM2 init
[11:16:00.522] SSM2 init
[11:16:00.957] SSM2 init
[11:16:01.372] SSM2 init
[11:16:01.807] SSM2 init
[11:16:02.222] SSM2 init
[11:16:02.760] interface close
[11:16:02.772] interface close
this is what i get when i try to read the ROM via ECUFlash. any ideas?
Old 08-23-2019, 12:29 AM   #270
surpip06
Member#: 399917
2013 STi
greay
I figured out m problem with help from sick chips in AU, don't forget to pull your leads off the ecu before attempting to crank!! haha what a stupid thing to forget, but otherwise my adapter worked like a champ! Thanks to everyone who provided info to this thread so happy i was able to save my ecu!!
Old 09-17-2019, 06:59 PM   #271
luizguccione
Member#: 220786
Default 2005 USDM STI ECU Recovered
Hello.
Thank you very much for this thread.
I was great to be able to unbrick 2005 USDM STI ECU SH7058.
Fortunatelly I found all the components needed and just assembled the whole thing with the assistance of a Electronic Services Shop. I did all in the bench. Used an external 12v power supply.
I couldnt get it to work with Ecuflash (Latest Version).
So I tried Renesas and it was flawless.
Thank you again.
luizguccione is offline   Reply With Quote
How to Make an STI Look Like a Sleeper? FostersAFB General Community 92 10-12-2017 09:24 PM
How to remove an ecu Quackyboy Newbies & FAQs 9 04-22-2010 09:26 AM
How bad is it on the tranny to treat an auto like a manual? thrillho Transmission (AT/MT) & Driveline 8 06-07-2004 08:23 AM
Want to learn how to tune an ECU...and actually do it on a real dyno? 2000vfr800 Engine Management & Tuning 9 03-19-2003 02:20 PM
How long for an ECU to reset w/ no flash? Keith99RS New England Impreza Club Forum -- NESIC 0 08-22-2002 03:28 PM
