Welcome to the North American Subaru Impreza Owners Club Thursday October 17, 2019
Old 08-16-2015, 10:33 PM   #101
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Originally Posted by encryptedballa View Post
I am running a silicone turbo inlet which is less than ideal.
Why?
This is considered an UPGRADE on every car I've seen.
wtdash is offline   Reply With Quote
Old 08-16-2015, 11:14 PM   #102
encryptedballa
Member#: 122189
02 WRX Wagon
Originally Posted by wtdash View Post
Why?
Strictly due to fitment. I was not able to connect everything as easy as stock. Im sure its most likely model specific. Its not a perrin or anything nice
encryptedballa is offline   Reply With Quote
Old 08-19-2015, 08:31 PM   #103
suprabats
Member#: 357908
I'm working with an engine importer on an EJ205 (w/acvs) and they told me they could sell me this ecu pictured here which DID NOT come with this engine. To me this looks like an aftermarket tuned ecu with the giant Zero Sports sticker on it. That has me concerned.
If it is aftermarket tuned, can I have it returned and use it with my EJ205? The seller also had an auto ecu (swapping the engine into a 5 speed USDM wagon) or do I look for another ecu elsewhere?
suprabats is offline   Reply With Quote
Old 12-14-2015, 02:46 PM   #104
lubbedsub
Member#: 286370
I did the exact same swap with one code. P1507 . I took the Idle air control valve apart . I found would looked like carbon build up in it. Cleaned it, put it back togther and code was gone . Those engine sit for a while before being sold i guess.
Hello Everyone
I just finished swapping in a JDM ej205 with AVCS into my bugeye. Everything went fine, car started first try. As I went to back it out of the garage, i got a cel for the Idle control system failure: P1507.
From what I have read, this would usually mean either the IACV or the neutral switch have failed. I have read other reports of air leaks potentially being the issue, but it seems like most people claim success after replacing either the IACV or the NSS.
Well, I happen to know my IACV was recently cleaned, but i still tried the other IACV that came with my swap. Neither helped the issue.
I tune with opensource, so I am able to see the NSS activity in romraider. It appears to be working correctly.
So finally, I started looking for leaks. I checked every connection on the intake and turbo (BCS included.). Could not find anything obvious. Checked the torque specs of the intake manifold, and all were within spec (18.1 ft lbs).
I tried to swap back in my USDM ECU, same result.
Other things of note, the car had sat for 7 mo. while i sourced the motor. It was already set up for E85, so that is what is in the tank. I had already ported over my previous tune to the jdm ecu via ecuflash. I am confident that my injector scaling/latency are correct for e85 as I ran this setup for 3 years. Could it possibly be the 7mo old e85 in the tank that is not allowing the car to idle correctly?
I am running a silicone turbo inlet which is less than ideal. If it is a leak, I am sure this part is the culprit. I intend to pressure test the system, just need to build a tester.
TL;DR has anyone had success fixing a P1507?
lubbedsub is offline   Reply With Quote
Old 12-18-2015, 05:36 PM   #105
suby02wrx
Member#: 427090
Can someone point me in the right direction. Doing a JDM ej205 w/ AVCS into an 04 WRX. I have the JDM ECU and wiring harness. Which wires can I use to activate the AVCS? Is it easier to just buy the wire kit?
I'm doing intake, equal length headers, uppipe and downpipe. Replaced timing belt, water pump, valve cover gaskets, spark plugs, upgraded sti oil pan and pick up. Anything else? Car will be tuned once I get it running.
Thanks
suby02wrx is offline   Reply With Quote
Old 12-19-2015, 11:53 AM   #106
ToneWrx02
Member#: 239095
2002 Wrx
Thanks
You talking about bulkharness? It would be easier to buy the kiy instead. Hardest part is feeding the wires thru.
ToneWrx02 is offline   Reply With Quote
Old 12-21-2015, 07:08 PM   #107
jonpers172
Member#: 393893
2002 impreza WRX
black
Angry JDM swap- no crank issue
hey guys, this is my first post on nasioc ever so hopefully I'm writing in the right place. I just swapped in a JDM ej205 w/AVCS into my '02 WRX w/oAVCS. I left all JDM accessories, intake, cam gears on. I also swapped ECM's so I can maintain whatever JDM specs with all the JDM things. To my surprise everything hooked up except for the AC compressor (and obviously AVCS). I go to start it up for the first time and I run into a no crank/no start issue. of course it HAS to be electrical! sometimes it will crank over, usually it wont...So I've been troubleshooting over the last couple days. I have a brand new battery, my starter has been tested, it's good Ive even swapped into another starter, and scrubbed all of the surfaces to ensure a ground connection. I have good voltage all the way around from the ground to the positive, and I have power running to the solenoid from the starter switch. I've also connected a wire straight from the solenoid to the battery to bypass the whole ignition system. I've also tried swapping the ECM back to the USDM one. when I turn the key or connect the wires there's a loud clicking and the fuel pump I'm stuck and frustrated, I just want to take this thing for a drive already! (it sat in agarage since last year so I could save up the money for this swap.) Oh, and yes the JDM engine was pressure tested and it does turn over by hand. Any suggestions would be much appreciated. Or heck a phonecall or text would be great! 8479753480
Last edited by jonpers172; 12-21-2015 at 10:33 PM. Reason: additional info needed for adequate description/question
jonpers172 is offline   Reply With Quote
Old 12-22-2015, 04:43 AM   #108
ToneWrx02
Member#: 239095
2002 Wrx
Clicking? Starter then?
Old 12-23-2015, 10:44 PM   #109
jonpers172
Member#: 393893
2002 impreza WRX
black
Default JDM swap- no crank issue
Tone, thanks for the reply. I see where you thought so seeing that I ruled out the ignition system with a straight wire. I also have full voltage on the positive end on the starter, and every point I tested on the starter. however I have swapped in 3 separate starters that I know work (special thanks to That One Guy!), and all of them work with jumper cables and a screwdriver.
I looked at the 12lb(?) XTD flywheel I have on there. I had the same flywheel on prior to the jdm swap and it had no problem turning over and running. I also managed to get the starter to turn over a couple times. the one discrepancy that I saw was some chipping on the paint in front of the flywheel teeth. that indicates to me that the starter gear is shooting out to the flywheel but not turning.
the scientific process does not apply and I am officially in a twilight zone. any other other tips or tricks? on 26DEC, I am pulling the motor back out. FML. at that point I will mount my old tranny up to the engine, mount the starter and jump it to see if it will turn over.Im also assessing to see if this aftermarket flywheel may be the wrong one for my 5 speed tranny. any thoughts or ideas?
update: I pulled the motor mounted up my old tranny and starter to jumper cables. it turned over immediately. I only had a bad ground to the starter despite the attempts to fix that, and despite measuring 12.6? volts all the way around.
unfortunately, I got the engine back in and started with immediate knocking. I returned the engine, reinstalled another jdm engine and it runs ok. I notice the occasional misfire, and it smokes like a freight train, I suspect it's burning oil. the warranty period runs out in 2 more weeks, so I need to make a decision and fast on what I need to do. for now, I'm going to run it softly and see if I just need to burn up some carbon, also I'm going to swap in the USDM timing gears, and reinstall the USDM ECM. I'm using the USDM intake so I suspect the TGVs aren't wired up with the JDM ECM.
I have no clue how to tune, and any advice would be appreciated about the smoking oil smelling exhaust fumes. ( I have the catless uppipe until I can replace the EGT probe on the USDM uppipe.) my phone number is 847-975-3480.
Last edited by jonpers172; 01-22-2016 at 08:06 PM. Reason: additional info needed for adequate description/question
Old 03-22-2016, 11:11 PM   #110
xavier12
Member#: 443131
Originally Posted by Offroadguy View Post
Sorry for the delay, still new to this site.
The JDM engine had a flex-plate on it that bolted right up to my torque converter. Yes, mines an automatic
The turbo looks identical, so I used the JDM, waste gate and all.
The JDM intake manifold had no TGVS on it so I used the USDM one. I don't know how hard it would be to make the JDM intake work, it would flow much better for sure and the retune would be able to negate the DTCs being set.
I'm not sure what years of engines will work best.
You shouldn't have to change all the timing gears. I changed the crank gear and one cam gear, the ones with the sensors on them. I kept the JDM crank and cam sensors.
Got lucky, my engine knock was the timing belt tensioner rattling. I compressed the rod on the tensioner too fast and blew out the seal on it when I changed the timing components.
Here is a pic of the rear of the crank pullies, you can see the signal sent to the ecu is different.
http://i.imgur.com/SqWVWnr.jpg
Do you only change the cam gear or the whole cam shaft as well?
xavier12 is offline   Reply With Quote
Old 03-30-2016, 11:35 AM   #111
TwinkieTaxi
Member#: 311145
2003 wrx
sonic yellow
I'm relatively new so I hope I'm posting in the right area and this hasn't been covered but I haven't seen it exactly anywhere. I have a motor on the way for my 03 wrx. Its an ej205, and after calling dealship they told me based on the serial number it's a 2.5l shortblock legacy gt sti wrx. My question is based on this can anyone give any insight as to what I might need to change during the swap. I will not be hooking up avcs so using stock ecu, I understand I have to change over the IM and EM for sensors to read right, what about the cam gear? I'm also concerned about compression. Any insight would be amazing and thanks for the help
Update: For anyone thinking about doing this swap and considering where to get the motor I got mine from jdmracingmotors.com they change the cam gear and crank gear to usdm so that you do not have to change them yourself. I wasn't overly thrilled about having to take them off and change them so if you're looking for a more plug and play motor swap experience that company might be the way to go.
TwinkieTaxi is offline   Reply With Quote
Old 04-12-2016, 03:09 PM   #112
wrxnutjob
Member#: 444640
Default Old ecu new harness and engine
Originally Posted by elijah.botez View Post
Hi everyone! I have put a good amount of time in research about my issue here but still didn't find a solid answer.
I have 2003 WRX with all stock ej205. What happened was my turbo decided to go kaboom in the middle of a freeway. After I realized that it might of took out my internals I took the engine apart to see.
Sure enough I had a hole in piston 4. Also looked like it had a cracked camshaft. Basically a full rebuild is needed, which would cost me no less than 2k. On the other hand I've seen some good JDM ej205 engines for about $1k.
Let's say a JDM engine will have AVCS - will I need extra wiring or JDM Ecu to work properly?Or will it work with my USDM Ecu? I've seen people say yes and no so I am kind of confused. I am not considering any big power upgrades, so far I just want to go stock and make sure everything will work like it should. And yes I want to be able to pass emissions. I am a student so my budget for this project is minimal. Please help!
I am using 2002 wrx ecu and running 2005 JDM ej205 with avcs. Using new wiring harness, avcs not hooked up, swapped intakes (drive by cable) and DID NOT swap cam and sprockets. Modified the cam sensor harness, runs fine.
wrxnutjob is offline   Reply With Quote
Old 04-13-2016, 08:18 PM   #113
KiwiMike
Member#: 442557
Default Need swap too
Hi.
I also have an 02 with a motor in pieces. So if I get this right, an import engine will work fine as long as I retain intake, harness, and perhaps the pulleys? Is it this easy?
Mike (MA)
KiwiMike is offline   Reply With Quote
Old 04-13-2016, 08:21 PM   #114
KiwiMike
Member#: 442557
Default One cam gear?
Is it just the drivers side intake cam sensor and gear?
Mike
Old 04-14-2016, 04:56 AM   #115
ToneWrx02
Member#: 239095
2002 Wrx
Originally Posted by KiwiMike View Post
Hi.
Mike (MA)
Starting to get tired of the false information going around.
Anything pre 2000 motor needs to swap over intake and harness, some pulleys.
If you get the right JDM wrx motor that has AVCS everything will be plug and play. No changing anything and it will work.
Old 06-13-2016, 05:29 PM   #116
TOOQIKK
Member#: 366133
I swapped an jdm ej205 into my bugeye did not switch a single thing, simple plug and play, it fired right up the first try...2 years later still running strong....
i have not hooked up the avcs yet but do have a full uncut harness to harvest the wires from and a jdm ecu.
i bought my motor from dallasjdmmotors.com
i got complete motor with a harness and ecu included!
I called them and spoke with them after finding them on ebay!
i highly recommend replacing the up pipe with an aftermarket one to remove the cat(this will save your motor from immanent destruction), also replace any and all gaskets, timing belt and water pump while the motor is out! along with new plugs. check all vacuum lines and any rubber lines on the motor, if you even have a doubt about them replace them!
TOOQIKK is offline   Reply With Quote
Old 06-13-2016, 06:12 PM   #117
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
Did you/they mention the recurring theme that the cam /crank sprockets need swapped?
If not then this just continues the confusion.
If yours has it plz post the Engine tag on t-belt cover.
Old 06-14-2016, 01:42 PM   #118
ToneWrx02
Member#: 239095
2002 Wrx
They do not need to be swapped.
Even bewteen 99-00 subaru GT engines which are EJ205 the crank and cam sensor are identicle.
They are different color sensors but they are interchangable.
How do i know this because i have swapped cam and crank sensors from 03 jdm wrx ej205 into a EDM/JDM 99 GT EJ205 and car ran perfect.
Old 07-12-2016, 12:57 PM   #119
MrChompskiWRX
Member#: 450591
Hey, So I have a 02 wrx and I'm swapping a 04 EJ205 w/AVCS into it. We did the whole swap put the motor in using the old 02 ECU and harness. The motor turned over no problem but after driving down the street for about 1 minute it started violently rattling. Any suggestions as what I could change or swap in from old motor? Also have JDM ECU and wiring harness if necassary
MrChompskiWRX is offline   Reply With Quote
Old 07-14-2016, 02:17 PM   #120
robmobile1970
Member#: 384907
Default ej205 in 06 baja
I'm considering buying a Ej205 to replace the 2.5 turbo that needs a valve job in my 06' baja. I've read that if I swap my manifolds and sensors that the 2L longblock will run just fine with the 2.5 ancillery items without throwing codes. Does this sound right?
robmobile1970 is offline   Reply With Quote
Old 07-14-2016, 02:24 PM   #121
wtdash
Member#: 59182
2002 WRX GG>>
2016 Focus RS
JDM 205 with single AVCS-maybe.
But why put another used "unknown" engine into the equation ?????
Fix the heads.
Old 09-07-2016, 05:00 PM   #122
Ksnow95
Member#: 415198
Default jdm ej205 not starting
I recently swapped a jdm ej205 non avcs and to my understanding it is a version 4. I was told to swap the cam gear, crank gear and crank sensor and it should start and now when I turn it over it sounds like it wants to start (making popping noises out the exhaust) but just wont fire up. The car has compression, fuel, and spark. Any suggestions? Thanks
Ksnow95 is offline   Reply With Quote
Old 09-08-2016, 12:42 AM   #123
jonpers172
Member#: 393893
2002 impreza WRX
black
Double check to make sure all of your sensors are in fact connected. Mine was oroginally in a limp mode because my cam pos sensors werent connected. Is it the correct ecu for the engine? How old is your fuel? Did you mess with timing at all? What intake is on it currently? Jdm drive by wire, or cable? Will it crank over with your foot on the gas?
Old 09-08-2016, 10:21 AM   #124
Ksnow95
Member#: 415198
I just have the stock to Usdm wrx ecu right now, my fuel is fresh just put some in during the this whole process, messed with the timing but seems right, I'm running the Usdm intake manifold and it does turn over with my foot on the gas. And I am not sure if it's a drive by wire or not how do I figure that out? Thanks kurt
Old 09-25-2016, 03:56 PM   #125
Skyteg970
Member#: 453845
Default Any exact answers???
I've been reading and haven't got an exact answer. So my 03 has a blown engine. And I would like a long block. Jdm is the better price. But will it actually work correctly. I have no problem getting a tune. My tuner is just 4 hours away so it will be a mission. Looks as tho jdm has the non avcs and avcs engines. Both 9:1 (no jdm has 8:1?) so can I take the avcs engine and swap my cams from my usdm motor? Block off the avcs completely? And is it the head that bumps compression? Rods? Pistons? Maybe the short block is different? Can you swap your heads on to the jdm short block? This would be my first ej motor experience. I have the fa20dit so that's what I'm familiar with. Any help is appreciated
Skyteg970 is offline   Reply With Quote
