Welcome to the North American Subaru Impreza Owners Club Tuesday October 22, 2019
Old 08-17-2019, 12:52 PM   #351
4S-TURBO
Member#: 67807
.... missiles - when
they know wat they can do
Well goddam it. Supra it is.
Old 08-17-2019, 01:23 PM   #352
godfather2112
Papi Chulo
Member#: 53794
... 2017 BMW M2
2017 F-150
Originally Posted by Yoo Shin View Post
Yeah there's many a thread on the GM forums about leaky magrides. My brother's are starting to go on his 17 ZL1 at 30k miles and my rears are going out at 34k. They said leave it in "Sport" or the middle setting and you'll get lots of life out of them. Nope. Replacements are $350 per corner IF you can find them, and GM has managed to make these awesome little PITA harnesses that you almost have to destroy to connect the magride to the car.
If you go coilovers (which I guess I'll have to here soon), you'll need the magride deletes which run $400+ to fool the car's computer into thinking you have it still or you get all kinds of neat CELs and it'll default to "Touring" affecting the steering, brakes, bi-modal exhaust etc. Yay GM quality.
So a 1LT Z51 C8 is just a few $k more than a ZL1 1LE..hmm..
How much is an extended warranty? Iíd probably just opt for an extended warranty so if the suspension goes out, drive it in for replacement. Iíd have to imagine a good set of street coil overs for this car will run $4k plus. I guess you could always cheap out but that would be a shame.
godfather2112 is offline   Reply With Quote
Old 08-17-2019, 01:49 PM   #353
Kostamojen
Member#: 2272
1999 OBS Camo Wagon
That price isn't bad. Bilstein shocks are usually $1000+ for a set.
Old 08-17-2019, 01:59 PM   #354
Yoo Shin
Member#: 87327
2017 Heron White SS
OG Thread Killa
Which reminds me, there's a shop in Texas that's already setting manual conversions for the Supra!
Mine are not covered by the warranty because it's on springs and my brother was told they wouldn't replace them under warranty because he has mods, even though they're all power mods and none on the suspension. Tons of GM threads with all kinds of excuses used by GM on why they won't cover mag ride failures. A common one is the "seeping" from the struts is normal and not considered faulty or a failure.
All that being said, I won't mind going to coilovers eventually, I'll just find a good setting for them that gives me the same feel as the "Sport" setting which I'm in 80% of the time. Touring is way soft, but it closes the mufflers which is nice I don't want to be loud af, and the Track setting is just ridiculously hard and stiff for the street.
I'd like to see a wing delete on the C8 or maybe something like what's on the Camaro SS 1LE or C7 Z with a large lip like rear spoiler.
Yoo Shin is offline   Reply With Quote
Old 08-17-2019, 04:30 PM   #355
n2oiroc
Member#: 141952
18 golf arrrr!
magride fluid is abrasive, its inevitable that they will leak.
n2oiroc is offline   Reply With Quote
Old 08-17-2019, 10:05 PM   #356
BeepBoop
Member#: 496462
Sounds like more reason to go with good o'l fashioned stuff.
Cheaper? Check.
Easier to do maintenance? Check.
Less complicated? Check.
Less electronic garbo? Check.
More aftermarket options? Check.
Longer life? Check.
So you miss out on the ease of tuning your suspension at the twist of a knob (or in this case changing a setting via infotainment)? Big deal. Not worth the trade-off IMO.
For me to buy into something tech-wise, it has to be an across the board improvement. Not "Oh yeah, it's more expensive now... and it is also more expensive long-term!"
BeepBoop is online now   Reply With Quote
Old 08-17-2019, 10:10 PM   #357
4S-TURBO
Member#: 67807
My concern with with the standard suspension is lack of tuning. All R&D thrown into the magna ride and chassis setup tuned with it etc. Completely re-imagined Vette with bits in new places should concern anyone interested in one.
Old 08-18-2019, 01:41 PM   #358
Keshav
Member#: 1654
2019 GoCycle GX
MV Agusta Brutale S
I'm fairly certain that the engineers on the Corvette project are better at picking springs and dampers for this car than Trevor at GoFasturd Speed Shop.
Keshav is offline   Reply With Quote
Old 08-18-2019, 02:24 PM   #359
BeepBoop
Member#: 496462
I'm fairly certain that the engineers of the corvette also have a standard of NVH that is somewhere above what an actual racecar is, let alone what a lot of "hard-core" boy racers can stomach as far as ride height and stiffness. They still have to cater to their prime demographic of Grandpa Flatass, after all.
Also, have you seen the engineering work a lot of aftermarket parts providers put in?
Old 08-18-2019, 08:41 PM   #360
4S-TURBO
Member#: 67807
Trev's bro has an STI...
Old 08-19-2019, 02:12 AM   #361
PovertySpec
Member#: 437188
06 TR Stage 2
17 SS 1LE
Who would opt for a non magna ride car? I would not. So $75k it is.
I would... base model Z51 with the cloth race buckets!
PovertySpec is offline   Reply With Quote
Old 08-19-2019, 07:31 AM   #362
KC
Member#: 442
17 Imp Spurt
00 S2k
I know they build these cars in Bowling Green, but quite a few make it up to Detroit/Warren. How many of you have driven near/around the surface roads around the GM Tech Center in Warren MI? I have, many times. Mound, Van Dyke and all the other roads... SUCK. S-U-C-K. I swear they pay the towns/cities to NOT resurface them (although they have been) so they can do testing in a real world environment.
I'm sure they've done a good job also on the base suspension, which I think will be the suspension of choice for those that track the car (so it can be replaced much more easily with something more suited to on-track driving, higher spring rates/valving, etc...) The Magneride is excellent, yes. But track cars usually use something a bit more focused and switch out depending on the track.
--kC
KC is offline   Reply With Quote
Old 08-19-2019, 12:37 PM   #363
Keshav
Member#: 1654
2019 GoCycle GX
MV Agusta Brutale S
Yep. The real race suspensions will make the car faster on the track they are tuned for. They're also more expensive than the stuff Trevor will sell you that just makes the car ride low and stiff.
Old 08-19-2019, 01:13 PM   #364
KC
Member#: 442
17 Imp Spurt
00 S2k
I don't think Trevor is there anymore...
https://local.theonion.com/sick-boy-...lik-1837373360
Old 08-19-2019, 04:50 PM   #365
aschen
Member#: 30733
2007 tiny car
striped
Appropriate user name is appropriate
Samies here I don't think I would configure Magnaride either...........front axle lift would be nice as an option on base trim though.
aschen is offline   Reply With Quote
Old 08-19-2019, 09:30 PM   #366
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Adventure van
Actually......
I wanted the performance cloth because I find leather a bit slippy under cornering.
Buuuttttt I am a skinny ****.
Old 08-19-2019, 09:35 PM   #367
Yoo Shin
Member#: 87327
2017 Heron White SS
OG Thread Killa
Meh I'd still get it with magride even if it craps out eventually. Like any of the performance Chevys with it, it's tied into other performance aspects of the car that make it fun, like the steering, throttle, braking, and of course handling.
I'm really thinking that this C8 and the new Zupra (that damn car is growing on me more and more), will be game changers and challenge how those who can afford cars 2-3x more perceive a sports car, much like the original NSX. I can't wait to see what a Z06 will be like or whatever higher end Supra is planned.
Old 08-20-2019, 11:32 AM   #368
Keshav
Member#: 1654
2019 GoCycle GX
MV Agusta Brutale S
This does have NSX potential with the advantage of it being a domestic; pricing and attainability are much better.
Old 09-04-2019, 06:46 AM   #369
AVANTI R5
Member#: 73805
RUMOR MILL: 800-HP FLAT-PLANE TURBO V8 HEADED FOR THE CORVETTE Z06 OR ZR1?
2020 Chevy Corvette C8 engine rumors are swirling
The most exciting time in a new Corvetteís life is when itís first born. At that time, all we know are the facts about the base model (2020 C8 Chevy Corvette, 495 hp, dual-clutch transmission, rear-wheel drive, $60,000), while itís future is unscripted. That leads to endless rumors, speculation and innuendo, all of which we thoroughly enjoy.
Over the weekend, much of the talk was from Motor Trend, regarding a twin-turbocharged, flat-plane crank V8 making around 800 hp for the new Corvette Z06.
Muscle Cars and Trucks says there will be a DOHC V8 with a pair of turbochargers, and it will make around 800 hp, but it will NOT be for the Z06.
Instead, it will be the ZR1. The Z06 will get a naturally aspirated engine because, according to Muscle Cars and Trucks, ďdie-hard enthusiasts werenít too thrilled when the C7 Z06 featured a supercharger.Ē MC&T also says the Z06 will make around 600 hp, which is a little surprising considering the most recent Z06 delivered 650 hp. Would Chevy take a step back? We doubt it.
Old 09-04-2019, 09:26 AM   #370
SCRAPPYDO
Member#: 873
2018 Leg / Ridgeline
Datsun 71 240Z & 68 2000
totally agree bud. The base C8 is the NSX acura should have built. chevy one upped Honda on this one. Absolutely Nobody wanted that hybrid junk on the new NSX. They wanted a drivers car. We will have to see, but Chevy may have just built the affordable (and I use that term loosely) drivers car for enthusiasts with a normal pocket book.
SCRAPPYDO is offline   Reply With Quote
Old 09-04-2019, 01:12 PM   #371
White out
Member#: 46277
** LP640
Viper GTS
--kC
Oh god. Nightmares of taco wheels still haunt me. Sections of missing road between concrete slabs that were laid down in the 70's. Missing sections of bridges. 6"+ deep pot holes. Patchwork on top of patchwork on top of patchwork for 1000ft+. Good ole' Metro Detroit.
White out is offline   Reply With Quote
Old 10-01-2019, 06:31 PM   #372
WRXnick16
Member#: 447898
2016 WRX (traded)
2019 STI CWP
Smoking Tire's track day sounds from the 2020 Corvette C8 Z51.
Driving impressions embargo until November 16th.
WRXnick16 is offline   Reply With Quote
Old 10-01-2019, 06:45 PM   #373
TriAxis 6
Member#: 377862
2017 Z06/Z07 & Fozzy
Admiral Blue & CWP
Iím waiting to see it in Z06 trim. All the bells and whistles and boxes checked. Maybe theyíll sort out that horrible rear end and the rest of the car will flow seamlessly. Z06 trim widens and smooths the base model out quite nicely IMO.
Until then, Iíll just leave this here...
TriAxis 6 is offline   Reply With Quote
Old 10-02-2019, 03:09 PM   #374
heavyD
Member#: 194216
2018 M2 LCI
Most of us can agree that the latest NSX was a mistake but there's no way Honda could build a mid engine car like the C8 and sell it for the price GM is at least for the first year. It would have been a $75k+ car from Honda but it probably would have been much more successful than the current NSX that is priced in no man's land relative to its prospective buyers.
heavyD is offline   Reply With Quote
Old 10-03-2019, 12:00 AM   #375
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Toyota is making the opposite mistake with the Supra. Putting a measly 335 hp motor in what is supposed to be a quintessential sports car. I mean... the Ford Taurus SHO has 365, as does the Kia Stinger for crying out loud. Itís already 50k base. Why not throw another 5-10 on the cost and make it 400+?
bdubblu is online now   Reply With Quote
