Welcome to the North American Subaru Impreza Owners Club Wednesday October 16, 2019
Old 11-20-2017, 08:27 AM   #1
2pot
Member#: 301042
Default WA/A2 04-07 GD GG STI Springs
While waiting for Eibach UK to release the WA/A2 springs, I've received a few questions. Hope the following helps.
I grabbed some images off the web, before Photobucket died. If it's your present/previous car? Thanks for the initial inspiration.
OEM STI
Prodrive 05 STI red S05/D5/001
JDM STI pinks
RB320 suspension
Spring tolerances are +/-3mm at ride height and +/- 7lb/in rate.
At ride height, oem sti spring rates measure 217 front, 171 rear.
JDM sti pink front measure 223, at ride height.
Required specs:
Daily driver/occasional track day.
F245lb/in R223lb/in at ride height
Linear spring rates, in their operational range.
Increase spring free length, to ensure no dislodging, at full droop - non-inverted dampers extend further, than inverted. Eg front Koni inserts are 35mm longer.
Revise the bump stops for inverted and non-inverted dampers: front - account for the lower front ride height, and rear - stiffen.
Don't go too low at the front - bump travel (and spoiler lips ).
Widetrack OEM sti front ride heights compared to :
Prodrive 05-07 sti red S05/D5/001 -18mm
WA/A2 -25mm
JDM sti pink -28mm
RB320 -31mm
Consider how the revised spring rates will effect ride frequency.
Take the extra rear weight of the wagon variant into consideration.
Keep the rear ride height close to the stock sti.
As utilised on the RB320 - increased positive rake:
A, relatively, higher rear ride height moves the roll centre rearward, increasing rear roll resistance.
That, in turn, makes the front end roll more - helping turn-in response and reducing understeer, without the use of stiffer bars.
You want the smallest bars possible, on a road car, to avoid 'roll-rock'.
Roll-rock:
If the spring rate is relatively low and the bar is too stiff, a suspension movement, initially, occurring on only one side of the vehicle, will be transmitted to the other side, inducing an unsettling 'roll-rock' motion and destablizing the tyre contact patch.
The bump stop selection also helps mitigate against understeer. On undulating/uneven roads, you may find the use of a bigger rear bar unnecessary/unhelpful.
2pot is offline   Reply With Quote
Old 11-24-2017, 05:30 AM   #2
2pot
Member#: 301042
RB320 - interesting article, on what Prodrive did with the '07 STI chassis:
https://www.pcadynamics.com/app/down...he+Insider.pdf
Old 12-17-2017, 10:49 AM   #3
2pot
Member#: 301042
Currently investigating, whether it's possible to remove 0.7 of a coil at the rear, and 0.2 of a coil at the front - to save weight, by changing wire diameter/materials. Yet still pass the longevity/stress tests.
Old 12-17-2017, 05:00 PM   #4
Vancouver98STi
Member#: 459287
1998 JDM Impreza STi
White GF8 wagon
Thumbs up I appreciate the advice you've sent my way
You've been quite helpful to me on a couple of different Subie forums, so I just wanted to mention the following in case you're unfamiliar with this "fix". Works great!
Originally Posted by Vancouver98STi View Post
I installed Photobucket Hotlink Fix 1.3.9 for Chrome two months ago, and since then have had no issues viewing embedded Photobucket images in forum posts.
Vancouver98STi is offline   Reply With Quote
Old 12-18-2017, 04:04 AM   #5
2pot
Member#: 301042
Thanks very much. I'll check it out.
Old 01-19-2018, 07:32 AM   #6
2pot
Member#: 301042
No, it's not possible.
Pre-production machine testing = 0.25mm increase in wire diameter. Slight increase free spring lengths.
Now in Eibach's manufacturing schedule.
Old 02-01-2018, 05:55 AM   #7
2pot
Member#: 301042
For those that asked:
Reducing the number of coils does reduce the coil bind/weight. But, increasing the coils, increases elasticity. The spring has to reach coil bind and return to its specified free length.
If the design/material exceeds its elastic limit, then the spring won't reach coil bind, or will take a set, and not return to the specified minimum free length.
The WA/A2 springs have an increased free length, compared to a stock STI spring - to accommodate longer length, non-inverted, struts - koni inserts, AGX etc. As well as inverted struts.
UK delivery - now due week commencing 19 March.
Old 03-30-2018, 02:36 PM   #8
2pot
Member#: 301042
Old 04-12-2018, 03:42 PM   #9
2pot
Member#: 301042
The blob/hawk top mount restricted the spring design.
Utilising the bug rear top mount:
No additional sprung weight, as the dead coils are at the top.
The 2 plane angularity of the bug rear top mount is a closer mirror, to the lower strut perch - a more constant/even pressure on the closed/ground top coil.
Old 05-01-2018, 06:35 AM   #10
2pot
Member#: 301042
Just waiting for the clip tubing to be fitted - next week.
Anyone buying Feal fixed perch struts?
I'd like to see a set of these springs, in that combination, wagon or sedan (no charge) - PM me.
I need your wheel size and et, tyre size and front + rear bar sizes.
Old 05-14-2018, 04:03 PM   #11
2pot
Member#: 301042
Positioning the clip tubing, at rear ride height. Just the fronts to go now:
Old 05-14-2018, 07:36 PM   #12
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
FWIW, I appreciate your efforts here. Nice job.
A-man07 is offline   Reply With Quote
Old 05-15-2018, 05:30 AM   #13
2pot
Member#: 301042
Thanks.
The GC/GF/GM springs have been good. Hopefully, the WA/A2 springs will find their niche in the market.
Old 05-16-2018, 11:48 AM   #14
2pot
Member#: 301042
Done:
Old 07-02-2018, 05:32 AM   #15
2pot
Member#: 301042
Have some feedback from a US '04STI + WA/A2 + 225/45 17 + Koni's + 6 speed. After 120miles: 364mm front, 360mm average rear.
New oem 04sti listed at 386mm front, 366mm rear.
^ OEM sti springs + 225/45 17: 374mm front, 342mm rear.
^ WA/A2 (just after fitting) + 225/45 17: 364mm front, 364mm rear.
Further height measurement after new alignment + bushes and dampers fully settle.
Old 08-17-2018, 02:51 PM   #16
2pot
Member#: 301042
Old 03-23-2019, 09:12 AM   #17
2pot
Member#: 301042
^ Ride height update:
Front 363mm
Rear 369mm with 3/4 tank (8mm difference full to empty).
KYB ultra sr inverted front
KYB ultra sr non-inverted rear - that'll stop any subsequent knocking The KYB inverted rears only used 40mm of bearings, as did the original Bilstein RB320 rears. The Bilsteins subsequently had a additional 20mm, 3rd, bearing installed.
Old 09-07-2019, 04:13 PM   #18
2pot
Member#: 301042
Feal FPS + WA/A2
Old 09-16-2019, 08:16 AM   #19
2pot
Member#: 301042
Inserts for inverted strut bodies.
Similar to above, should be doing some testing shortly.
