Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 09-14-2019, 12:55 AM   #1
WRX_JAC
Member#: 324597
2017 STI
Smile 2015+ STI, RCE Yellow vs Eibach PRO Kit, your opinions
Hello guys,
I know that the general consensus here is that RCE are better than pretty much any other lowering springs for the STI, but what about the Eibach PRO Kit? After all, Eibach makes the springs for RCE. So here are the technical specs for both:
RCE
Drop: 0.75" F/R
Progressive Spring Rate
Spring Rate Front: 365lbs max
Spring Rate Rear: 360lbs max
AVG Price: $370
Eibach
Drop: 0.80" F/R
Spring Rate Front: 366lbs max
Spring Rate Rear: 400lbs max
AVG Price: $250
As you can see, the drop in height is very similar, SR in the front is also pretty much the same, the major difference is in the SR on the rear, Eibachs seem to be considerably stiffer.
I would like to see your opinions if you had tried both let me know how different they are.
And BTW I know, coil-overs are the way to go but there is no way I'm spending $2K for a set... wife would kill me if I do that.... seriously...
WRX_JAC is offline   Reply With Quote
Old 09-14-2019, 01:03 AM   #2
ayau
Member#: 332408
ayau is offline   Reply With Quote
Old 09-14-2019, 01:07 AM   #3
WRX_JAC
Member#: 324597
2017 STI
Originally Posted by ayau View Post
Thanks,
That's a nice setup, but I'm mainly trying to get some feedback on these specific springs as there is not a lot of info on the Eibach's for the STI.
Old 09-14-2019, 01:27 AM   #4
ayau
Member#: 332408
Originally Posted by WRX_JAC View Post
Thanks,
The rear OEM shocks are somewhat bouncy when you put an aftermarket stiffer spring. The Eibachs with stiffer rears will only accentuate that bounciness. I would say the RCEs will ride slightly smoother, but having properly valved shocks like the RCE Bilstein shocks will be even better.
Old 09-14-2019, 03:18 PM   #5
Boxer112
Member#: 78751
2017 Sti
ISM
I've had the RCEs on my 17 Sti for about 22k and i didn't have one complaint. I ultimately went on to coils for more adjustability.
Boxer112 is offline   Reply With Quote
Old 09-14-2019, 04:19 PM   #6
WRX_JAC
Member#: 324597
2017 STI
That'll be my plan, springs for now, coilovers later, not ready to spend the money atm.
Old 09-21-2019, 01:14 PM   #7
pdubbs424
Member#: 463766
2016 WRX
Are you positive on those rates for Eibach? I thought they were progressive springs with a range from 160 - 366 in Front. I would assume the rear has a range as well but could be mistaken.
I had the RCE Yellows on my WRX for a bit and those were not progressive. It makes a difference over the smaller bumps in the road. The car looked soooo much better with them on, but I ultimately went back to stock for the softer suspension.
pdubbs424 is offline   Reply With Quote
