Welcome to the North American Subaru Impreza Owners Club Friday October 18, 2019
Old 08-11-2015, 05:07 PM   #601
Rbrate6
Member#: 427745
2006 Subaru WRX
Gray
im having the same problem with my 06 wrx. My friend recently put on the stage 1 power package from cobbs warehouse. just under a week the code came while driving to the gas station. my accessport says im still at 14.7 a/f. i reset the code on the accessport and then turned the car off, havent driven it yet but if it comes back what/where should i be looking primarily?
Rbrate6 is offline   Reply With Quote
Old 12-17-2015, 12:09 AM   #602
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
I removed all the emissions stuff from beside the alternator (also unplugged the box thing) and got a P0171. I think the reason it triggered was because instead of capping the intake manifold port I just connected it to the hardline coming from underneath the manifold. If I capped both instead of connecting them it might be ok.
Since there is no complete diagram listing all the hoses and ports and what they do I guess it's easier just to leave it all there.
Put all the emissions stuff back, reset ecu, and no code.
joek92 is offline   Reply With Quote
Old 01-26-2016, 08:19 AM   #603
WR9-2X
Member#: 386292
Wow, when this thread was started I didn't even have my driver's license yet.
Anyways, I keep getting that pesky PO171 pop up on my 05 Saabaru with a stock 2.0. Only mod otherwise I know of is the CAI which I've had for a long time without getting a code. Car has about 180,000 miles on it. The odd thing is, I only get it when I'm at the bottom of a very steep valley on my way to work. In that quick transition from downhill to uphill it pops up every time if I go fast enough.
I've checked all my vacuum lines, sealed any questionable seals on the CAI with a bit of RTV, I clean and replace the gasket on the IACV about once a year just for cheap peace-of-mind. Any other ideas? I'm guessing either the quick change in g-force when driving through the "dip" is either loosening up a vacuum line somewhere, or that my fuel system is having trouble pumping up through the g-force. Come to think of it my fuel filter is overdue....
Anyone else ever see anything like this? Car runs and idles beautifully for 180,000 miles other than this one issue going through the steep dip.
WR9-2X is offline   Reply With Quote
Old 02-04-2016, 11:00 AM   #604
lamping.ap
Member#: 439698
2008 Impreza, no mods, P0171.
Found no intake or exhaust leaks, sprayed MAF with cleaner and saw no change in the readings. Using my bluetooth scanner I see, at idle and car hot (coolant temp was good):
SAE.LONGFT = 29.7%
SAE.SHORTFT = 20%
SAE.MAF = 2.1 g/s
SAE.WO2S11.O2SV = 2.0 V
Any ideas? The O2 voltage is suggesting it is running lean and those trims are super rich. Is the MAF reading normal for the car hot and idling?
Car seams to run fine, but is getting poor MPGs. I also found it odd, that when I shut the engine off, car still on, the O2 voltage stayed the same. Shouldn't it drop?
lamping.ap is offline   Reply With Quote
Old 02-12-2016, 12:13 AM   #605
prohispano
Member#: 393739
Midnight Blue Pearl
Ive got this code after Engine wash , !no powerwash!,
Sympoms:
-Cold start hesistation and bad idle (after warm up and restar engine idle fine at 700rpms)
-Acceleration sluggish, even warm, at second gear it feels 0 power, but in WOT, feels as same as when it was good, no problems at full boost (stage 3 bugeye at 14 psi vf39).
-Vacuum at cold starts go to -15 and its accelerate by its own trying to stay alive.
-If i want steady 1500rpm for example, it goes to 2k and stumbles to 1000 rpm, and then it goes all high again.
What im doing?
- I clean MAF sensor with contact cleaner (OBD2 bluethooth scanner, tell me AFR at idle are 15-14:7)
-I have clean coil packs and connectors.
-I have clean IAVC idle controller
-I check all vacum lineas and negatives
-I clean even the spark plugs, they are one week new and are BKR7 NGK
-I test all Coils and they are good.
When i buy the car, it has bad Frontal o2 sensor and well, it has p0171, i install new sensor and CELS neve come back!
Please need some help.
Today i buy injector cleaners, i really dont know what it is?
PD: I even check Compression (cold engine and didnt wot ) and i get 120psi in all cylinders.
Edit two: My car is working now better than ever, i just use some injector cleaner, drive around, and now it never fails.
prohispano is offline   Reply With Quote
Old 03-03-2016, 03:28 PM   #606
ssjeff
Member#: 423268
Default 2014 STI p0171
2014 STI Hatch With Cobb intake
I have been pulling a p0171 code a lot. I cleaned the MAF and it looks good. It doesn't run bad so I doubt it is that. Dealer wanted to replace the upstream o2 so I did that myself with a NGK
Fuel economy seems to have picked up a little but it is still pulling the code.
Motor was just rebuilt by dealer with new short block but pulled code before this.
I have a Cobb AP but have pulled it off and still pulled codes with stock program.
Runs fine. Has the stumble at 3000-3300 but it seems that is normal for these cars.
I have narrowed it down to pulling the code while cruising at 80 mph which is right in the stumble area. It also seems to go fault when I am cruising ~80 and just start to go up a small incline on the highway.
I have been studying the web. this thread is great. I am considering making a smoke machine to check leaks and also cleaning the PCV and cleaning it.
I am almost certain it is the stumble though. I am entertaining the idea to put the cobb e85 kit on which
Any ideas?
ssjeff is offline   Reply With Quote
Old 03-24-2016, 03:16 PM   #607
ssjeff
Member#: 423268
Any ideas?
I think I have figured mine out and I figured I would post it to help others. I bought the car with a Cobb AP and the Cobb intake. The original owner put all the tunes on the AP. He had all the tunes in fact. I guess along the way of switching from 93 to 91 I put the tune in for the stock intake. I cleaned the PCV, new upstream O2 sensor, cleaned the MAF several times, and I cleaned the air filter but the code kept coming back. While pulling the datalogs from the AP I started looking at the tunes and figured out I was not running the "SF" tune. since putting the SF tune in I have not had any issues.
Old 04-13-2016, 06:05 PM   #608
ajj7885
Member#: 444716
Default Hellava time
Ah yes the elusive p0171 cel. I've been fighting this code and several mechanics regarding this issue and still haven't had it solved. I have a 2011 wrx sedan with a Cobb sf air intake w/o air box, Perrin recirculating bov, invidia high flow dp, and invidia catback exhaust with a Cobb ap v3 stage 2 tune 93 octane. I have seen 3 mechanics so far without any luck. I had the maf replaced and the front o2 sensor. So far 600$ invested trying to fix this issue. I'm wondering if my dp could cause the issue? Is it the tune? The cai? Code popped about a month after installing turbo back exhaust and Cobb stage 2 tune. The car bucks while driving at low speeds occasionally backfires and idles at either high or low rpms. I was almost positive the front o2 sensor was the cause but apparently not. The smell of exhaust fumes is very pungent although no black or blue colored smoke.
Any suggestions?
ajj7885 is offline   Reply With Quote
Old 05-25-2016, 09:23 AM   #609
cmiovino
Member#: 134005
2004 WRX Premium
I'll join in here. I must state, I don't have the P0171, however my AF learning 1A number is pegged at +15%. 1B and 1C are also relatively high at 6-10%.
2004 WRX, 124k miles, Cobb turboback, SF intake, Perrin inlet, STI uppipie.
The car has always had slightly positive LTFTs, even when I bought it with just the turboback and intake. These have increased over time, but no running issues or CELs.
I've changed out the MAF and front O2 with new Denso parts. Installed a new turbo inlet. Replaced all the vacuum lines around the turbo and others. Reenforced all other vacuum/boost lines with zip ties or clamps. Sprayed carb cleaned around looking for leaks. Replaced the uppipe (by a performance Subaru shop), with all new Grimmspeed gaskets. Replaced the fuel filter about 20k miles ago. Replaced the fuel pump with an STI unit.
... yet still massively positive fuel trims. I'm actually astonished the CEL hasn't tripped yet since AF learning 1 will go to 14.8 @ idle.
The only two things left I can see if the IACV gasket and cleaning the actual unit or the PCV. Both have never been cleaned/replaced. The PCV is a bitch to get to and the intercooler isn't fun to put back on with the plastic Y-pipe.
But yet, the car runs great, no CELs. Just another story that you will need to look and change everything to find your issue if you do have the CEL. I have a feeling the CEL is only triggered if the car is under load... IE the AF learning C range.
Old 06-21-2016, 10:39 AM   #610
prohispano
Member#: 393739
Midnight Blue Pearl
Well today i get p0171 after gas refill , then i have a gas leak in the gas filter close to intercooler.... another thing i make yesterday, i move the orientation of my short ram intake and the car doesnt feel the same...
Old 07-25-2016, 07:46 AM   #611
Morario84
Member#: 361629
2012 impreza
Originally Posted by AlexWRXbruh View Post
Mario appeared to have a bad front o2 sensor; i pulled codes for a bad heater circuit, as well as the p0171 code after it cleared while he was driving over.
Sent from my iPad using NASIOC
Thanks for all the help before. Just got another 0171 this week
Any chance the replacement O2 sensor could go bad after a year?
Morario84 is offline   Reply With Quote
Old 07-26-2016, 06:42 PM   #612
Morario84
Member#: 361629
2012 impreza
Turns out my mpg is awful, and the p0171 is paired with P2097 Post Catalyst Fuel Trim System Too Rich Bank 1"
Some snooping around here makes me think the o2 sensor i replaced is bad already, or dirty MAF.. Think I'll order a new sensor and just return it if it doesn't make the code go away.
Old 07-29-2016, 06:21 PM   #613
Morario84
Member#: 361629
2012 impreza
So I yanked out the old O2 sensor and... holy ****
Covered in soot. So now the question is: Is the soot the result of a bad O2 sensor, or is the O2 sensor covered in soot from something else going bad.. Any ideas?
Old 08-03-2016, 07:58 AM   #614
Morario84
Member#: 361629
2012 impreza
Update on my codes- Cleaned the MAF (didn't look dirty), re-sealed the airbox and replaced the dirty, sooty O2 sensor and voila!
after ~100 miles or so MPG is back up to mid 30s and no more CEL
Old 08-03-2016, 09:22 AM   #615
joek92
Member#: 353938
2007 STI WRB
18x8.75 +35 225/40
Congrats. Thanks for following up. Hope this one lasts longer!
Old 09-08-2016, 08:33 AM   #616
maxpower45
Member#: 84445
2002 WRX Wagon
SRP
I've had the p0171 code for a few years now but it would clear itself periodically which would allow me to get the car inspected while it was off. This year it's gotten worse and no longer clears itself.
I'm working through the page 1 list of items trying to fix it. Per the ODB2 scanner, the EVAP SYS test is the one that fails but not the Oxygen Sensor test. Can I assume that means the Oxygen Sensors are good in this case? I replaced the front sensor (the wide band one) a few years ago for a different code.
2002 WRX with ~130k miles.
maxpower45 is offline   Reply With Quote
Old 03-02-2017, 06:10 PM   #617
JHurtado
Member#: 434399
2004 WRX Wagon
Wanted to share my experience on this thread because it was incredibly helpful for me when I had this problem. I was driving home one night and car was running great so of course I decided to give her one good pull before I got back to my house. Once I got parked and idling for a minute it started to idle very very rough and the engine was running all wonky, almost like I had after market cams in. I thought it was strange but maybe just leaving it overnight would sort everything out. Next morning when I start the car it's the same problem only this time it throws me the CEL with the p0171 code. I wasn't sure where to start but luckily I have a very good family friend with a shop nearby so I took it in to him. He suggested we run a smoke test to see if all the vacuum lines are connected properly. We start the test and immediately notice smoke pouring out of the EGR. The line had become completely detached from the housing. We also noticed the turbo inlet was slowly trying to wiggle itself off the turbo so we also got that snugged up nice and tight. Problem was completely gone after that and the car has been running perfectly since then. I'll attach a picture so y'all can see where the line became undone, alternator is in the far of the shot for reference.
JHurtado is offline   Reply With Quote
Old 05-16-2017, 08:47 PM   #618
giozara
Member#: 467783
Default P0171
This Friday the car goes the dealer to hopefully straighten this all out. Here is my story on my 05 wrx. I bought my 05 wrx and everything was good until my oil pump went bad on a trip to Portland took out the bearings and internals on my motor, luckily I did have warranty. Motor had been replaced with one with 27k miles on her. Okay so the car had come back to me everything is okay but idle was re learning and it did fix it self but than I would get a oil burning smell turns out pcv valve on it was stuck open. That had been replaced everything was okay. And I do mean only okay because the car was feeling sluggish in wide open throttle and idle won't re learn it's always idling rough to almost stalling but fixes itself before it does. Code popped up with the p0171 lean code.
This is new to me and mods that I can see is a short ram intake, catless down pipe. The motor replacement is stock. My fluids are all clean and no excessive oil consumption and no coolant consumption either. The maf had been cleaned out, even replaced. Tps had been replaced even tho the new tps reads 7.9% at idle and the old read 11% at idle I would think it would read 0 since it's closed throttle. The af sensor had been replaced too the old ones wires were badly exposed and the sensor itself was white very white. At idle the car would be reading 3.9 volts. I know I'm taking it to the dealership anyways but thought I would make this post as a feeler maybe get some insight on stuff I missed wasn't sure how to post video
giozara is offline   Reply With Quote
Old 10-30-2017, 05:06 PM   #619
cobrakin00
Member#: 476733
bump
I'm getting this stupid code now as well.
Vehicle 2002 wrx
Checked for all vacuum leaks, there is no vacuum leak anywhere.
Cleaned the MAF
Mods to the car are a Borla Cat Back and Cobb VS
cobrakin00 is offline   Reply With Quote
Old 01-13-2018, 08:25 PM   #620
Shanec1121
Member#: 480563
Default 2009 wrx P0171 bank 1
I got this code today after replacing my clutch. Friend said it could be my AFR setup reading the o2 sensor wrong so I followed the innovate motor sports LC-1 to calibrate it and now atleast my AFR reads down to 15 when I hit the gas but at idle it is at 22. Also at idle it is really choppy and idles low. Please help!
Shanec1121 is offline   Reply With Quote
Old 02-03-2018, 10:54 AM   #621
volks6433
Member#: 477571
02 WRX
Couple of days ago my 02 wrx threw a PO171 code while driving to work, Ill start trouble shooting today to see if I can figure it out. Ill post my findings, great read. Thanks.
volks6433 is offline   Reply With Quote
Old 02-03-2018, 10:58 AM   #622
volks6433
Member#: 477571
02 WRX
My 02 wrx threw a PO171 code the other day while commuting to work, Ill start trouble shooting this morning. Ill post my findings, great thread! Thanks.
Old 02-04-2018, 04:29 PM   #623
volks6433
Member#: 477571
02 WRX
After doing some trouble shooting today to figure out my PO171 code, I found the entire leading edge of the air filter seal had pealed off. from the last person that installed it. I'm the second owner and it pulled this code after about 7000 miles or so while commuting to work the other day. The coupler between the MAF housing and the turbo inlet goin under the intake manifold looks pretty janky to and showing some cracking. Going to order a COBB hose unless anyone knows of a better one? Ill reset the ecu and see if it comes back. Thanks
Old 02-10-2018, 09:16 AM   #624
volks6433
Member#: 477571
02 WRX
The faulty air filter was my issue that was causing my car to throw a po171 code, commuted all week with no problems and the car runs great. Crazy how sensitive the turbo motor is... Anyway all the information that's on this forum was and is super helpful. Thanks.
Old 05-14-2018, 09:11 PM   #625
jawang213
Member#: 485977
Default help????!?!?!?!?!?!?!?!
having the same issue as you guys. i have an 06 wrx with a p0171 only mods i have is an AP with stage 1 91 octane tune map and a invidia down pipe heres what ive replace/checked
replaced upstream a/f sensor
replaced downstream 02 sensor
replaced leaking intake manifold gasket
swapped/cleaned MAF sensor (swapped with good reliable one)
checked fuel pressure 38-40psi 50-52psi with return line clamped
smoke tested intake system (found no additional leaks)
replaced pcv hose
cleaned throttle body
replaced air filter
noticed that this code only appears when im at idle. checked my fuel trims with obd tester and found that its sitting at max correction +25% which would indicate lean but when analyzing 02 sensor it indicates rich condition (which you can noticeably smell) looking for any ideas of anything to check or replace code came on out of nowhere no major repairs or no tune changes. please help!
jawang213 is offline   Reply With Quote
Everything you ever wanted to know about anything ever made......ever Hester Prynne Off-Topic 12 11-05-2008 05:57 PM
OT Non-Gun Nuts: Everything you ever wanted to know but were afraid to ask (or try) Janq Off-Topic 47 12-29-2006 01:23 PM
Everything you ever wanted to know about exaust systems Back Road Runner Normally Aspirated Powertrain 9 10-24-2006 09:59 PM
('93-'01) Everything you ever wanted to know about Subarus... Porsche914boxer4 Impreza Forum 15 07-23-2001 09:17 PM
Everything you ever wanted to know about WRX exhauasts (old model) --> rao Normally Aspirated Powertrain 5 02-12-2001 08:56 PM
