Welcome to the North American Subaru Impreza Owners Club Thursday October 17, 2019
Old 04-23-2009, 09:31 AM   #51
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Our 08 has helicoils in all mounts for the front calipers. Took all about about 2 months before that was needed. I've always been really disappointed that the Brembo put the threads right into the aluminum.
Old 04-23-2009, 09:42 AM   #52
peterjmc
Member#: 98688
2006 Legacy GT Ltd.
Satin White Pearl
I should have helicoiled the rest of the mounting holes while I did the fronts but just did one hole. Bump for this thread because it saved me hundreds of dollars when I was about to give up!
peterjmc is offline   Reply With Quote
Old 04-23-2009, 12:30 PM   #53
fullerton
Member#: 122030
Originally Posted by gills View Post
Ok,
ordered a helicoil thread repair kit.
Size of the bolt for anyone in the future with the same problem:
M12x1.50 fine thread
I'll be receiving it tomorrow morning and will be attempting to install shortly after. I will keep everyone posted.
Tom
Just to be 100% sure, is this thread size the same on front and rear calipers?
fullerton is offline   Reply With Quote
Old 04-23-2009, 02:01 PM   #54
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
No, the rear calipers are M10x1.5.
boost junkie is offline   Reply With Quote
Old 04-23-2009, 02:43 PM   #55
fullerton
Member#: 122030
Thanks, I thought that was the case but I wanted to be sure.
Old 04-23-2009, 03:44 PM   #56
BGPKR
Member#: 41842
2006 LGT LTD 5SM
This happened to me, but there was enough thread that allowed me to thread the bolt back in. However, I plan on using a helicoil during my next brake job...
BGPKR is offline   Reply With Quote
Old 04-23-2009, 03:54 PM   #57
fullerton
Member#: 122030
I have had some input that is is better to re-tap one size larger rather than use a helicoil kit. Any comments on that?
Old 04-24-2009, 12:29 AM   #58
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
No way. You will just run into the same problem later, steel bolt threading into an aluminum caliper. You are better off with helicoil, no question.
Old 04-24-2009, 08:04 AM   #59
fullerton
Member#: 122030
I see your point, but I don't think a helicoil is the best insert to use then. Time-serts would work better (IMO and other's opinions). That way you have a steel sleeve that can seize all it wants to the caliper while your steel bolt remains easily removeable.
Old 04-24-2009, 08:55 AM   #60
hostile silence
Member#: 163878
05 STi & CBR1000rr
OBP & Blue and Yellow
i did my helicoil yesterday and it went smoothly... im happy to have that issue taken care of
hostile silence is offline   Reply With Quote
Old 04-25-2009, 02:32 AM   #61
Drifting Away
Member#: 70165
2006 WRX STi
Teh Wineberry Legend
Subscribed because im going through this now
Drifting Away is offline   Reply With Quote
Old 04-25-2009, 08:23 AM   #62
fullerton
Member#: 122030
FWIW- I premptively ordered 12x1.5 and 10x1.5 time-sert kits in carbon steel.
Cost almost $200 for everything, including extra inserts, but it is worth it for the insurance. If I don't use them I can always return them (with a 15% restocking fee )
Old 07-28-2009, 01:14 AM   #63
eva
Member#: 203992
2005 STi
I just stripped out the threads in my right front STi Brembo. Turns out the torque spec in the 05 shop manual is incorrect when it says 114.3 ft-lbs. I should have known it was wrong when the rear was somewhere around 40 ft lbs. Turns out the real torque spec is 80 ft-lbs in the front according to the stickie on IWSTI. Just thought maybe you all would want to know too to prevent the stripping of these threads in the future. I'll be putting in helicoils tomorrow :-(
Here's a link to it: http://www.iwsti.com/forums/gd-braki...per-bolts.html
eva is offline   Reply With Quote
Old 07-28-2009, 01:14 AM   #64
eva
Member#: 203992
2005 STi
edited
Old 07-28-2009, 01:15 AM   #65
eva
Member#: 203992
2005 STi
I just stripped out the threads in my right front STi Brembo. Turns out the torque spec in the 05 shop manual is incorrect when it says 114.3 ft-lbs. I should have known it was wrong when the rear was somewhere around 40 ft lbs. Turns out the real torque spec is 80 ft-lbs (which happens to be 114 Nm) in the front according to the stickie on IWSTI. Just thought maybe you all would want to know too to prevent the stripping of these threads in the future. I'll be putting in helicoils tomorrow :-(
Old 07-28-2009, 03:56 PM   #66
ihadmail
Member#: 159315
2009 Cadillac CTS-V
The torque spec being wrong in the manual isn't the only problem here. Mine seized all the way around torqued to 85 ft-lbs. The real issue is that they use a steel bolt directly into the aluminum caliper in a high heat and high stress application.
The only true solutions are to use a helicoil/threaded insert or convince Subaru and Brembo to get together and come up with a better setup from the factory. The former is going to be the only attainable choice.
ihadmail is offline   Reply With Quote
Old 02-02-2010, 09:36 PM   #67
FleaDog
Member#: 96267
'06 20G-XT'd STI
CGM & NT03+M
Yep, this happened to me too.
Ordered the helicoil kit from amazon for $50 shipped.
Heli-Coil 554412 M12 X 1.5 Metric Kit (18mm length inserts).
*** the front brembo caliper mounting brackets are 20 mm thick, so looks like the 18mm inserts will work great.
Just need to get a 31/64 bit.
FleaDog is offline   Reply With Quote
Old 04-14-2010, 01:45 AM   #68
JDM Junkyard
Member#: 31062
2012 Prius
looks like i need to do this too...blah.
JDM Junkyard is offline   Reply With Quote
Old 04-14-2010, 01:55 AM   #69
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
It's not hard at all. The helicoil kits are reasonable on eBay or Amazon. Search "Perma Coil".
Old 04-14-2010, 02:05 AM   #70
JDM Junkyard
Member#: 31062
2012 Prius
i know it's not hard, jsut 1 more thing to do while all my parts are laying around the garage...LOL.
just didn't want to deal with it right now.
Old 04-15-2010, 06:36 PM   #71
RSEnigma
Member#: 32326
'04 S2000
Suzuka Blue
Originally Posted by kursplat View Post
if your worried you could always drill 'em for safety wire while they're out
yeah that'll keep them in there for sure.
ugh, i still have nightmares about hours and hours of twisting safety wire from my open wheel days
RSEnigma is offline   Reply With Quote
Old 05-22-2010, 02:52 PM   #72
SEBBARU
Member#: 71774
2005 WRX STi
Platinum Silver
Default Time Sert Kit Depth???
What depth did you order? The Time-Sert inserts can't be shortened (cut) like heli-coils.
I'm in the same situation now with all 8 bolts, and need to order my kits ASAP
(Please, I'm desperate..)
SEBBARU is offline   Reply With Quote
Old 05-22-2010, 05:53 PM   #73
kpluiten
Member#: 120273
06 WRBWRXWGN
Measure the mounting tabs for thickness??? If the time-certs can't be cut then you MUST get one that's thinner than the mounting tab. Just the longest one that's still thinner and call it a day.
I think the time-certs are overkill though and not worth about double the price or more.
I got my kits on eBay for about $28 a kit or so. Search Perma-coil...
Old 05-24-2010, 03:22 PM   #74
fullerton
Member#: 122030
pming you.
Old 05-24-2010, 04:25 PM   #75
yamahaSHO
Member#: 73932
2005 STi EFR 6758
04 S2000 EFR 7064
pming you.
Is it a secret??
yamahaSHO is offline   Reply With Quote
Brembo Caliper mounting bolts 12mm x 1.5 aclver1 RMIC Private Classifieds 3 04-03-2009 04:51 PM
Thread pitch for rear brembo caliper mount bolt sti robot Brakes, Steering & Suspension 2 11-10-2008 06:32 PM
ATTN:STi front brembo caliper mounting bolt torque!! The_Prodigy Brakes, Steering & Suspension 2 05-07-2008 07:35 AM
Ugh! What did I do now? Help needed...stripped threads in caliper Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 3 04-12-2003 11:53 PM
Stock caliper mounting bolts question - can anyone help?? alfriedesq Brakes, Steering & Suspension 0 02-10-2002 02:28 AM
