08-29-2009, 06:44 PM | #1 |
Member#: 68448
NWIC
Vehicle:2008 WRX STi Cobb tunned by Surgeline |
learning view questions on learned afr's
hey guys and gals!
I have added meth/water to my car and I trying to understand the learning view program learned afr's. From what I can see I am not only taking some fuel but adding a lot? Please give me some insight on these numbers. I see the potential in this program, help me use it! Here is the shot This is on a 2008 STi XPT STG2 300cc nozzle progressive spray 9-19 PSI (19 target boost) Thanks!
08-30-2009, 01:23 AM | #2 |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
your concern should be the 40+ g/s section. Your running lean so your car is adding 12% fuel. When you go open loop, your ecu will still continue to add 12% fuel so you might not quite be hitting your a/f ratio targets under load and boost.
but richer is safer, while leaner is meaner |
08-30-2009, 12:12 PM | #3 |
Member#: 68448
NWIC
Its a % factor.. that is the info I am after. So I should be able to look at my map tables to understand why this number is so high.
Thank you for the reply |
08-30-2009, 03:54 PM | #4 |
Member#: 70395
You need to list all your mods. A wideband O2 sensor is the only thing that is going to really tell you whats going on in the "D" range.
08-30-2009, 07:20 PM | #5 |
Member#: 68448
NWIC
well the only mods I have is a 3" catless DP back to stock muffler , KN filter, water/meth injection
other than those few things its all in the laptop dyno AFR shows 11.2 clean up top dropping to about 10.5 to redline at 22 psi I have never delt with water/methanol so thta is why I think I am getting confused at the numbers I see. (meth was recommended by the dyno shop... meth and lower boost to 19) I have read that methanol and water will throw AFR numbers way off. That is why I am looking for input on these numbers. |
08-30-2009, 08:58 PM | #6 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
08-30-2009, 11:00 PM | #7 |
Member#: 68448
NWIC
on the nose.. thanks!
08-31-2009, 04:51 AM | #8 |
Sammo Hung
Moderator Member#: 10613
South East
Vehicle:2002 USDM WRX WRB |
which water / meth kit do you have?
i would follow the manufacturer's recommendation for afrs. yes water / meth will show a richening of afr. so if you're wideband indicated 11.0:0 you're actually at 12.0:1 without the water / meth. |
Learning view not opening on new carputer.... | sik03wrx | Open Source Reflashes | 7 | 03-20-2010 11:00 PM |
Learning View Questions | Jubert69 | Engine Management & Tuning | 2 | 03-01-2010 05:22 PM |
Another learning view question (FB related) | Kastley85891 | Open Source Reflashes | 3 | 04-26-2008 11:27 PM |
Romraider learning view table question...... | BBBsti LTD | Open Source Reflashes | 19 | 04-09-2008 05:29 PM |
Learning view - scan - FB if you could | Kastley85891 | Open Source Reflashes | 16 | 03-24-2008 10:42 PM |
