01-16-2007, 04:12 PM | #26 | |
Member#: 95840
Vehicle:sold to a good bud awaiting next car |
bumping an old thread for pics of the drilling modification....
01-17-2007, 01:00 AM | #27 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
well for the oil pump, I should have one in about a week. It will shortly there after be disassembled with pics to follow.
01-17-2007, 01:01 AM | #28 |
Member#: 95840
08-05-2007, 10:55 PM | #29 |
Guest
Member#:
My head is spinning.
I give up, I'll just buy the Spec C crank and oil pump....DONE. |
08-06-2007, 12:22 AM | #30 |
Member#: 33782
ordered it from jap parts on here...got it right as I was leaving town for interviews in the Tampa area, so no time to mic it yet. I will be tearing down and working it over when I get home. So expect an update next wed or thurs.
09-25-2007, 06:24 PM | #31 | |
Member#: 42614
SCIC
Vehicle:0405 WRX STi/S2000 AspenWhite/Silverstone |
I'm curious to see what oil pressure you are seeing with the 12mm. stock crank or extra cross-drilled variety? |
09-25-2007, 09:05 PM | #32 |
Member#: 33782
still waiting on a few bits to come in before the motor goes in the car...
I'm really wondering whether to use 1 or 2 shims...I'll probably just run 2 and see what the pressure is. Better safe than sorry. |
09-26-2007, 06:22 AM | #33 |
Member#: 109527
Vehicle:1997 GC8 8.38@165Mph blue |
I use two shims idle psi (hot engine0 75-80psi anything above idle (950rpm) the pressure is >120psi this is on an ej22t with oil squirters.
Jon |
09-26-2007, 06:33 AM | #34 |
Member#: 120463
quick question, how did you fill up the rear side of the oil relief?
03-09-2017, 05:51 AM | #35 |
Member#: 419491
great information. I have been digging into any I can find for my 500+whp build I want it done right
07-26-2018, 11:29 PM | #36 | |
Member#: 485462
Mercury balance at balance masters
They biuld capilary tubes for active balance ,,came from jet turbine research in california Last edited by Mattpac3; 07-26-2018 at 11:31 PM. Reason: Heading |
07-28-2018, 04:51 PM | #37 |
Member#: 112759
Vehicle:2015 Stock OEM AsFu* 3.6r OMG S.C'd |
Old thread... bump? lol
Similar Threads | ||||
What is the paint code for the middle of the oem 3 part rear lip (02/03) | kogs | Interior & Exterior Modification | 0 | 04-10-2010 06:08 PM |
So whos checked out the oiling system for sohc head | VTsuby | Normally Aspirated Powertrain | 1 | 10-24-2009 12:03 AM |
Oil Consumption at High RPM | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 10-13-2005 06:16 AM |
Modified EJ20/25 cranks for high rpm.... | bugeyes | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-11-2005 07:27 PM |
Oil weight for high performance cars | Jon Bogert | Normally Aspirated Powertrain | 22 | 02-26-2001 12:36 AM |
