Welcome to the North American Subaru Impreza Owners Club Thursday October 18, 2018
Old 10-22-2016, 04:19 PM   #1
Jamtill
Member#: 436127
2016 WRX STi
Default LED control unit - 2016 STi
In June I installed the LED C-lights and multiple times I had issues with condensation in the passenger side headlight. I would open it up and reseal, but that passenger side kept giving me issues.
Well this latest time it knocked out the LED low beam. I took the headlight apart, again, and then tested each of the 2 LED low beams in the headlight, both work fine when connected to a 12V source. I am pretty sure the problem is the CONT ASSY LED HL unit. (Pictured)
I would really appreciate any advice on purchasing just that unit.
I hate the thought of buying a new headlight just to open it up and install the c light for it to match the driver side. I would go back to stock if anything which then I would have to buy 2 headlights, they are 800 a piece, which hurts to even think about.
Jamtill is offline   Reply With Quote
Old 02-03-2017, 08:31 PM   #2
uget2seconds
Member#: 282476
Ever find the replacement part for it? I have the same issue and needed to buy another headlamp assembly due to it being my daily driver. Took the old one apart after months of it being in a box and saw the same driver issue. I may rip the metal cover and see what's underneath to see if the damaged component itself may be replaced
uget2seconds is offline   Reply With Quote
Old 02-03-2017, 08:31 PM   #3
uget2seconds
Member#: 282476
And in your pic you can see the rust on one of the inside screw threads lol you must of had a lot of water
Old 02-03-2017, 08:52 PM   #4
uget2seconds
Member#: 282476
Here you can see my burned transistors and marks on the board...
Old 07-02-2018, 04:26 PM   #5
RiCKYSTi
Member#: 446304
2015 WRX STi
Crystal Pearl White
Im having the same issue did you ever get it fixed?
RiCKYSTi is offline   Reply With Quote
Old 08-04-2018, 01:45 PM   #6
Themis_wrx
Member#: 442912
Have you ever figured out this issue I just opened up my headlight and found that my control module is Rusted from the inside
Themis_wrx is offline   Reply With Quote
