Welcome to the North American Subaru Impreza Owners Club Wednesday December 12, 2018
Old 07-15-2018, 02:26 PM   #1
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
Question OLM Silverline S4-style fog light bezels wiring help
I am still struggling with how to figure out how to wire up the OLM Silverline S4-style fog light bezels on my 2015 WRX in order to get the led bars to light up the way I want them to. I do have the Subispeed DRL harness, and they told me to tap into that, but I'm still a bit lost. Plus, I don't necessarily want these bezels to be on all the time as an all-day DRL when driving. I want them to be more of an accessory light. Maybe just have them come on when I turn the accessory switch to the first "on" position before my headlights come on. The fog bezels are mostly wired up, minus a remaining white wire that has a weird connector on the end of it that I assume will need to be cut off. Thanks.
striktlysubie is offline   Reply With Quote
Old 07-17-2018, 10:39 PM   #2
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
Nobody?
Old 07-20-2018, 10:14 PM   #3
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Can you post the installation instructions regarding the wiring?
Old 07-20-2018, 10:47 PM   #4
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
It didn't come with any instructions. That's part of the problem.
Old 07-25-2018, 06:36 PM   #5
Big-E
Member#: 123843
2016 STI LTD CWP
How are the lamps to be wired?
Do you have to connect each bezel to a controller first and then to your power source(s) and ground? Or is each bezel connected directly to the power source(s) and ground?
Are the wires labeled?
Could you post pictures?
Old 09-09-2018, 04:05 PM   #6
striktlysubie
Member#: 423516
2015 WRX Premium
Lightning Red
^ not really sure now. Did the install many months ago and buried some of the wires in the engine bay. Ground is all set. The only wire left if a white wire with a small clamp on the end that may need to be cut off, but not sure. Subispeed has tried to explain a wiring diagram to me, but it's still confusing. Someone else must have these installed and working. Help.
