Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 02-20-2008, 04:50 PM   #1
sidwin
Member#: 168099
2004 impreza sti
wrb
Default Whiteline roll center kit?
I have an 04 STI and i notice the other day that my ball joints are leaking grease. I notice that Whiteline makes the ball joint replacement. How well do these work with just stock suspension? Will the car sit higher?
I'm going to get the hotchkis competition sways and probably the tien s-spring soon.
Thanks,
Sid
sidwin is offline   Reply With Quote
Old 02-20-2008, 05:26 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
They work fine, and do not raise the car.
You do NOT want those springs. Read the stickies at the top of the suspension area.
Old 02-20-2008, 06:59 PM   #3
sidwin
Member#: 168099
2004 impreza sti
wrb
Thanks for the heads up.
Leh from GSC Motorsports told me to get the tien-s and the sways. I've seen leh drive and his outcome at Onelap made me think they are the ones to get but i'll pass if that is the case. I'll get the sways for sure.
I saw on IWSTI someone posted a chart that showed there was a height change when installing these.
Thanks,
Sid
Old 02-20-2008, 07:42 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Thanks,
Sid
So THAT'S one of the vendors still pushing those crap springs!!! I was wondering.
Old 02-20-2008, 07:47 PM   #5
skydes
Member#: 141347
2005 WRX
The Whiteline roll center adjustment kit is beneficial for all ride heights? I read through the long thread a while I ago and from what I remember it most beneficial for people how have lowered significantly.
skydes is offline   Reply With Quote
Old 02-20-2008, 07:53 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
It will still help. remember, no matter the height the suspension compresses.
We could start to go back round and round about ride height vs camber change, but I can tell you from experience that they help, even on a stock height car.
Old 02-20-2008, 09:44 PM   #7
sidwin
Member#: 168099
2004 impreza sti
wrb
Leh is pretty hard on suspension so what works for him probably wont work for my weak driving skills.
THose hotchkis look nice considering you get endlinks with them.
Old 02-20-2008, 10:03 PM   #8
nhat
Member#: 140163
03 STi
hellaflunctional
i bet he'd be faster with a good set of springs instead of the worst springs made for the impreza
read up on jdm pinks, rce black/yellows, and swift r specs.
Old 02-20-2008, 10:58 PM   #9
Butt Dyno
Street's closed, pizza boy
Member#: 17301
2016 FoST ST3
2006 Evo #17 STU
There is a list of threads you should read. And you should definitely hang out for a while before buying stuff.
Nine simple rules for Brakes/Steering/Suspension - Read this before posting!
http://forums.nasioc.com/forums/show....php?t=1326482
Lowering Spring FAQ
http://forums.nasioc.com/forums/show....php?t=1383366
Tein S-Tech FAQ
http://forums.nasioc.com/forums/show....php?t=1267918
Are you sure he wasn't recommending Tein SS or something? Not that that would be a lot better...
Old 02-21-2008, 12:19 PM   #10
bzbuzz
Member#: 116052
2011 STI ( Sold )
i definately wanna try this roll center kit when the weather gets better...
i am running rce v2 yellow + tokico d-spec
bzbuzz is offline   Reply With Quote
Old 02-21-2008, 09:41 PM   #11
antonch
Member#: 170384
2006 Sti
I wouldn't run them on a stock car height. Planning on installing them once I lower my car though.
Chart shown on IWSTI shows that it raises the roll,not ride center height-precisely what it is advertised to do.
antonch is offline   Reply With Quote
Need Help w/ Whiteline Roll Center Kit Install on 08 WRX Troa Brakes, Steering & Suspension 10 10-27-2009 08:55 PM
wtb alum control arms & whiteline roll center kit SubeSTIle SWIC Private Classifieds 5 06-22-2009 12:33 AM
Cusco Front Camber Plates & Whiteline Roll Center Kit Ver2 Token-Negro NWIC Private Classifieds 1 03-03-2009 06:16 AM
BNIB Whiteline Roll Center Kit KCA313, Max-C Camber Plates, Poltec Rear Endlinks! B16A2NR Suspension/Brakes/Handling 13 11-06-2008 07:01 PM
FS Northern VA: Whiteline roll center kit spinninhye Suspension/Brakes/Handling 2 11-02-2008 09:51 AM
